Question about GE Washing Machines
Wbsr3140d0ww Does not turn on only hear the timer ticking
2 Suggested Answers
  • 34 Answers
SOURCE: Kenmore Dryer 70 series Problem:
Sounds like your door switch has gone bad. This is a very simple and ever so easy repair. It will require you to access the internal workings of your dryer. There are step by step instructions on this website of "how to open your dryer" that are really good. A quick search should locate them. Usually a dryer switch is just a couple of screws and a molex (special type of plastic molded electrical connection) or a few spade/wire terminal connections. Make sure the dryer is unplugged before you work on the internal areas or the control panel. Popping the top up is usually done with either a screw driver or putty knife. You should be able to see a small portion of (2) clips where the top meets the rest of the body in the front. A bit of effort is required to get these clips to release. Once open, you will probably have two screws--1 on each side at the top left and right just down a short ways from the top. Removing these should allow the front to come off. Be careful when you remove this. The drum usually rides on the front portion of the dryer and will shift down when the front is removed. Just make sure when you put it back on that it is seated where it should be. The dryer front/door section should lift up off hinges at the bottom. Some of these have screws that attach at the bottom front. You may have to remove these. Once you have the front door off, the door switch should be on the back of the front panel of the dryer. From there it should be a matter of a few screws. If you have a meter, you can check if for continuity. If it has none and the dryer door is still closed, it needs to be replaced. Look for the link for dryer access on here if your dryer is a bit different. A door switch is only about $10 - $20 dollars on line. Make sure you have your model and serial number handy. It is either on the back or on the inside of the dryer door/lip. Hope this helps.
Posted on Feb 05, 2011
Dryer will not start but timer ticking
If the start button is an "ON - OFF" button (meaning, you can turn the dryer off manually instead of resetting timer in order to switch it off), try turning the dryer ON...then switch it back to "OFF".
Hopefully the dryer will continue, and the thermostat will kick in.
Dec 01, 2013 | Dryers
Will not start but its making a ticking sound
Electric or gas dryer?
Depending on where the ticking sound is coming from, without more specific information, many dryers use a timer within their dial for timed drying. If the switches are malfunctioning, the ticking of the "timer" can still continue.
If you can hear a whirring sound, which would be the motor, then it may be the drive belt. If this is the case, then the ticking of the timer may be more noticeable due to it being quieter without the spinning drum.
If you have a gas dryer and the ticking is from below, then it may be the ignitor that's faulty. However, that shouldn't cause your dryer not to turn on. It that case the dryer would spin, but not get warm.
With more information, I may be of better assistance.
Feb 14, 2012 | Dryers
My dryer wont start when I push the start button. You can hear the tick, tick when turn the timer on. Is it the start button or thermal fuse?
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Nov 22, 2010 | Dryers
Kenmore 70 series
positon sensor or timer issue replace
Mar 09, 2010 | Kenmore 63942 Dryer
The toaster oven does not toast. the oven and timer work, though
Your selector switch may be broken if the oven works on selections other than toast.
Jan 05, 2010 | Black & Decker TRO390 1200 Watts Toaster...
Dryer Won't Start
Make sure it has power. Then:Check the door switch. A little lever sticking down through top right of door opening. If it is not there you will need new door switch(sometimes the little lever breaks off). If it is there and does not click when you press it in you need a new door switch. if it clicks when you close the door then you have a bad thermal fuse.The thermal fuse is found by taking the back of the dryer off. The fuse is an oblong white plastic piece with 2 wires attached.
Door switch part number 3406109
Thermal fuse part number 3392519
May 27, 2009 | Kenmore 73952 Gas Dryer
Whirlpool dryer will not stay on. I can hear the timer ticking but when it turns on it only stays on a minute or so and then buzzes and turns off.
Change your timer. Your timer has gone bad. If you give me the serial number and make and model I can give you some places to go to buy a new timer. They are fairly cheap about 25 dollars or so
Apr 09, 2009 | Dryers
Washing Machines Logo
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
