I have a frigidaire gallery washer model # fws446ghs0 it will not let cold water run in very good ( very slow ) but warm water is good. the hoses are not kinked and vavles are open. what can this be ?
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
Will not fill with water cold or hot
Good Afternoon Friend,
I understand that your Frigidaire washer, model# GLWS1339EC, will not fill with cold or hot water. I also see that you have tested the valve, the water pressure, and made sure that there wasn't any blockage in the water hoses. I suggest contacting your local authorized technician for further assistance. They will be able to diagnose your appliance and determine why your washer will not fill with water. Hope this is helpful.
-Best Regards-
WP
Jun 15, 2014 | Frigidaire Gallery GLWS1339EC Top Load...
My Frigidaire Gallery Top Load Washer will not run ANY cold water!
I would replace the cold water inlet valve at the rear of the washer (pull the washer away from the wall), it is easy to do and the part is less than $20.00
Jan 26, 2012 | Frigidaire FWSB5700DS Top Load Washer
My (gallery) front load is making my load dirty after the wash. I noticed that if I wash in cold water is not as bad as when I wash with warm/hot water.
Sounds like deposits or dirt coming from hot water tank or line running to washer.Turn off water supplies to washer and remove the hoses from the back to see if the filters/strainers in each port are dirty.If not add a little CLR to the washer and let it run a cycle.Hope this helps.Wouldnt hurt to check the drain strainer either on the bottom of the wassher if you remove the little access panel, might be something in there making water dirty
Jan 20, 2011 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
I have a frigidaire gallery series front loader washer model gltf2940e it keeps giving error e10 what do i do
E10 means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Sep 15, 2010 | Frigidaire ATF6000ES Front Load Washer
I have an frigidaire front load Mod.# GLTF2940ESO with an recurring E10 error message. HELP!!
E10 code indicates there is no water supply.This can be confirmed by :
  1. Shut off the faucet to stop water supply to the washer.
  2. Disconnect and pulling the supply hose off the washer to confirm the E10Code
    • Opening the faucet and watch for running water
E10 also means that your cold water is coming in too slow, disconnect the cold water hose and check to see if the screen on your washing machine is clogged. If the screen is clean and the hose has good pressure then you will need to replace the water valve on your machine--- this is the piece that the hoses directly connect to.
Apr 11, 2010 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire Affinity ATF6000Es1 washer- Keep getting an alarm and an E10 code and have to restart the washer each time the code comes up.
Oct 18, 2009 | Frigidaire Affinity ATF6000F Front Load...
Wash starts, then stops postin E10 and now soap does not dispense
Aug 02, 2009 | Frigidaire GLTF2940F Front Load Washer
Water inlet
Have you checked the little mesh filter that may be in the hose? Sometimes sediment and other debris can build up causing slow filling. Turn the water valve fully off. Remove the hose from the valve and the machine. Check for a mesh screen in both ends of the hose, possibly even in the inlet to the machine. Remove and clean. You could also have a kink in the hose, bad hose (seen this too many times, just swap the hot and cold and see if the problem moves) bad solonoid valve, bad supply valve, etc.
Jan 04, 2009 | Frigidaire Washing Machines
Frigidaire Affinity Front load washer, Starts to Fill, then Flashes E10, Was wondering what this code is referring to
May 19, 2008 | Frigidaire ATF6000ES Front Load Washer
Frigidaire gallery
The choices are: cold hose kinked, water supply valve closed too far, cold water solenoid stuck or bad or clogged.
Mar 28, 2008 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
53 people viewed this question
Top Washing Machines Experts
