Question about Refrigerators
Want to change door handle from left hand to right hand
Hi hope you can help i am re doing my kitchen and want to change my left handled smeg fridge freezer to a right handled one !
is it possible to move the handles from one side to another ?
thanks and happy new year
aborcass
  • 2651 Answers
SOURCE: Loose handle on fridge freezer door.
that handle is just pressure fit on the clips securing to the door. grab hold ad PULL.and i mean PULL the the right. it will snap off just make sure you really PULL it. after that you cantighten the brackets on refig and inside the handle as well
Posted on Mar 12, 2008
SOURCE: Freezer Door handle came off after 1 yr.
I had this problem with the bottom freezer door of my Amana.
What I did was slide off the entire door handle by applying pressure pushing toward the right to get the handle off. Once the handle was off, I slid the clip (which was still clipped on to the door) off and screwed it back on to the handle. Once the clip was tightly secured to the back side of the handle, I carefully slid the handle bar back on to the door by sliding it to the left back on to the door clips until it clicked securely back into place.
Posted on Mar 28, 2008
ginko
  • 19396 Answers
SOURCE: May Tag Referigerator
The MBR1952KES Has the hinges on the right only, you need to order a custom made door to move hinges on the left.
Here is picture
Posted on Jul 27, 2008
ginko
  • 19396 Answers
SOURCE: Door Handle on right side
If the handle is lose, it should be replaced.
If you want to do it yourself, you find replacement parts, and mountage diagrams here
If you need to call a technician instead, you can use the phone number printed on the user manual.
Posted on Oct 02, 2008
SOURCE: Fisher Paykel fridge door handle loose
Yes hello, I had the same problem - similar fridge model.  Mine was the fridge (not freezer) door handle ie. the upper door.  There are no small holes on the bottom of my fridge handle.  Working from the outer door edge, I gently prized loose the plastic trim located under the door.  I didn't take it completely off, just loosened about one quarter of the length, enough to flex the trim downward so that I could then access the phillips head screw that secures the fridge handle from the inside of the door.  The trim will prevent you from using a conventional screw driver to tighten the screw.  I used a screw driver bit which is only 25mm long.  It has an hexagonal end to which I applied a small spanner and voila - the handle is once more secure.  Good luck.
Posted on Nov 15, 2008
A very difficult to open fridge door
is it level
do you wait
for the cold air to balance inside the fridge after opening it and closing it often
try vasaline on the seal edges
if the handle or hinges are the problem
will require replacement parts or adjustment
Sep 13, 2016 | Smeg FAB28
Here is picture
Jul 27, 2008 | Maytag Refrigerators
Door and handle problems. Smeg fa311x
sounds like your door is sprung. take door off and lay flat on a table outside of the door down. loosen screws on door liner . screws are hidden under door seal. when all loose not removed make sure door is flat on table. tighten the screws being careful not to move door. reinstall door and it should be ok. this is usually cause be either someone leaning or hanging on the door when it is open. or putting to heavy of items in the door trays.
May 26, 2012 | Smeg FA311X Top Freezer Refrigerator
I have 2 schlage door handles that are suppose to be able to be used right or left handed. I can't get the handle to turn to the opposite direction. (if it is set to be installed as right handed, I need...
How does the door handle even know if it is in a right or left handled door?
The handle should retract the latch with a quarter turn clockwise OR counterclockwise, so it should make no difference at all.
The only thing that is right or left handed is the direction the latch bevel points, so that it will retract when you push the door shut.
And the latch has nothing to do with the handle.
Are these circular door knobs, or is this a handle that has to then point at the hinges?
Because it seems to me that if the direction the handle points is the problem, you simply put them on the wrong side of the door.
Aug 17, 2010 | Garden
How do i remove the handle of my whirlpool fridge?
you may need a new door,,or use the top door just up-end it and put it on the bottom?
Jul 04, 2010 | Refrigerators
I want to switch the doors from left to the right side
Hi, The parts are interchangeable (hinges & handles)
You should have some small plastic plugs/caps that are covering the holes already drilled for the change. Once you remove the doors and then remove the plugs, just reinsert the plugs into the old holes and switch hinges and door handles to the opposite spots.
I hope this helps you. Please let me know if I can assist you further.
Thanks
Vic
May 26, 2009 | Frigidaire FRT17G4B Top Freezer...
Can you change the handle on fridge? from left to right
Yes you change which side you want the handle You have to remove the plugs that are at the top of the fridge and at the the top of the doors. And also at the bottom. Exactly where you have the dorrs conected now look at the opposite side and in the same positions you will find these plugs. Just remove them and reverse them to the oteh side. I hope this helps. Don't forget to rate my answer, thanks
Feb 15, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Fridaire model frt181l6d50
You'll need to remove the top hinge cover from whatever side it is on currently and then lift the door off the hings post ( set the door aside) .. then the top of the fridge will have small removable caps that hide the nuts for where you fasten the hinge to that side. Reinstall those caps to hide the holes in the top of the fridge where the hinge used to be. Next, you will have to transfer the handle on the door to the opposite side ( same process as the hinge) .. You wil find small plastic caps that hide the holes you'll be using to secure the handle to the opposite side,. use the same process for the freezer door too..This process only applies to top/bottom type freezers and not side by side. Hope that helps
Aug 03, 2008 | Frigidaire FRS26R4A Side by Side...
Loose Oven door handle
You may have to get some loctite brand paste in a tube for applying to the threads of the bolts that hold it on.
This will prevent the screws from loosening.
Another way would be to get some spring washers or star washers at your local hardware store such as menards.
Jul 02, 2008 | Smeg SE399X/5 Stainless Steel Electric...
Refrigerators Logo
240 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
