Question about Crock Pots & Slow Cookers
Defective part Forgot to wash inside the removable black pot for my Cook's Esstenial pressure cooker, so a white moldy fungus grew. The white-whatever-will not scub out; it can still be seen even after 4 SOS pads. The white moldy fungus bubbled the black finish on the inside of of the removable pot so the finish is flaking and the "bubbles" will not scrub off. Shouldn't cookware be antifungus or moldy washable. I am very concerned that this can occur in a Cook's Esstenial product. How do I get the removable black pot replaced? Model CEPC660
  • Anonymous Feb 24, 2009
    I am missing the pot to my 6 qt. Cooks Essentials Oval Pressure Cooker....and also the manuel.. HELP!!
To better address the problem with your nonstick pot... I need more information on the steps you have used to clean the pot and the extent of damage to the pot itself.
You indicated that the damage has occured between the pot and the inner surface of the cooker base? Is this a corrosive damage or a build up of material on the inner liner of the base?
Often times a build up of 'hard water' minerals accumulates on the inner surface due to condensation and occasional overflows from the foods being cooked. They can appear to be a type of fungus or mold.
Posted on May 18, 2009
Can you use crock pot liners in a pressure cooker
hi Carol.
this is all i could find out.
Can you use a slow cooker liner that Reynolds offer for the 6Quart pressure cookers? I'm not sure since the lid is a twist on/off. I successfully put a Reynolds Slow Cooker Liner in the instant pot and use the slow cook function. The liner seems to work equally well as it does in my slow cooker.
Amazon.com: Customer Questions & Answers
https://www.amazon.com/ask/questions/Tx2QMG4RH5VUT9U?_encoding=UTF8...
Can you use the liner of a crockpot in the oven?All Crock-Pot® Slow Cooker removable crockery inserts (without lid) may be used safely in the microwave and the oven set up to 400°F. If you own another slow cookerbrand, please refer to your owner's manual for specific crockery cooking medium tolerances.Oven & Microwave Safety - Crock-Pot®www.crock-pot.com/...how-to-use/.../help-and-how-to-use-oven-and-microwave-safety-...Search for: Can you use the liner of a crockpot in the oven?
or go to this link.
Can you use crock pot liners in pressure cooker Google Search
Nov 29, 2017 | Crock Pots & Slow Cookers
Della 12 Quart 1600-Watt Electric Pressure Cooker Multi-Functional Timer Slow Cook XL Part number: 048-GM-48261 Unable to get this cooker to slow cook.
it is possible that you have misunderstood the instructions
for a slow cooker you have low medium and high
press slow cook and on low and in 8 hours the food is cooked
I see from your statements that you expect the cooker to be set on slow cook but cook at a high temperature fast
if it says slow cook --9 hours and the temp is 125 degrees , have you waited 9 hours to see if it is cooked as the slow cooking process is by the gradual build up of heat in the container that is not expelled by radiation to the air
in a pressure cooker , that build up of heat also builds up pressure and so it cooks better
other solution--- if it is not right return it for a warranty refund or if out of warranty , junk it and get a different make
Mar 25, 2017 | Crock Pots & Slow Cookers
How do I cook a 3 lb boneless chuck roast in my pressure cooker not the Instant Pot using Coke, Ranch Dressing packet, and Au Jus packet. Need to know how to put it together and how long to cook.
put roast in. hit beef button. let pressure cool. hit beef button again.let pressure down on itself. enjoy do not forget that you still need enough water to make steam. That water also you will need to make GRAVY.
Feb 14, 2017 | Crock Pots & Slow Cookers
Where can i find a manual for ultrex pressure cooker?
The company had a major recall and went out of business. No manuals appear to be available on the web.
Here are some general instructions you can use:
1 Set up your cooker. Place your Ultrex Pressure Cooker on the stove. Remove the lid and pour in no more than 2 inches of water. Depending on what you are cooking the amount of water will vary. More water will ultimately cook larger amounts of food, but you will need to refer to your specific model's instructions on this matter.
  • 2 Put in the food you wish to cook. Close and lock the lid firm to the pot. Make sure it is locked securely so none of contents boil out of the top.
  • 3 Turn on your burner to high heat for approximately ten minutes. Allow the water to boil.
  • 4 Turn the stove down to a low setting after the water is boiling in the cooker. Flip the pressure valve closed and allow your food to simmer.
  • Set the pressure valve to ten pounds. For vegetables, cook 30 to 45 minutes. For meats, cook 45 to 60 minutes.5
  • 6 Open the pressure valve and allow the pressure to discharge. Unlock and remove the lid to find your fully cooked meal.
  • Aug 25, 2014 | Ultrex Crock Pots & Slow Cookers
    Oxtails
    The pressure cooking time for Oxtails is 45 minutes at high pressure. Here is a detailed chart with cooking times for all types of pressure cookers:
    http://www.hippressurecooking.com/pressure-cooking-times/
    Jun 21, 2013 | Wolfgang Puck Electric Pressure Cooker...
    Replacing my crock pot lid
    GO TO A THRIFT STORE, AND BUY ANY LID THAT LOOKS LIKE IT WILL FIT...OR USE ONE FROM YOUR OWN KITCHEN...REALLY...IT'S ONLY A LID...THE CROCKPOT WILL COOK WITH ANY LID.
    Mar 10, 2009 | Crock Pots & Slow Cookers
    Cooking PLAIN rice
    Here is my recipe - enjoy and please rate my answer as a fixya!
    Raw Rice - 2 Cups (400 gms.)
    Water - 6 Cups.
    (The ratio of rice to water is 1:3)
    PROCEDURE
    Step 1:First wash the rice in water thoroughly and drain the water.
    Step 2:Take a vessel ,the capacity of which is double the quantity of raw rice that is to be taken.
    Step 3:Now,add the washed rice into this vessel and pour 6 cups of water into it .
    Step 4:Now, place this vessel containing rice with water in a pressure cooker and add the pressure weight on the cooker top.
    Step 5:Heat the pressure cooker for 20 minutes only.
    Rice has been cooked.
    NOTE:
    *After heating the cooker for 20 minutes,donot open the cooker immediately.Wait for 15 minutes and then open ,otherwise the cooker would burst open.
    Feb 16, 2009 | Wolfgang Puck 5-Quart Electronic Pressure...
    Corningware Electrics Crock Pot Model SCO-150 Replacement Ceramic Bowl
    Wanna sell your lid? I broke my sisters at a family reunion and I hate to leave her with half a cooker.
    Margaret in SC for family reunion.
    414-630-0040
    Oct 04, 2008 | CorningWare K5607 Slow Cooker
    Crock Pots & Slow Cookers Logo
    146 people viewed this question
    Top Crock Pots & Slow Cookers Experts
    tsalagi152
    charles
    Irene Tulloch
    Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
