Question about Kenmore 24032\24036 Top Load Washer
I have a KENMORE WASHER 110.28882790. I turn the timer dial to the setting and pull the knob and NOTHING happens. what does happen is u can hear the water inlet valve humming. the washer just stopped. it was full of water with clothes. I took the clothes out and wet vac the water out. I've had this washer apart for the drive coupler twice so i familiar with whats what. I am very handy so I dont want to call a repair man. when i did empty it and tried to start it the water did pump into the washer. but when it was full all u can hear is the water inlet valve. i also put an ohm meter on the motor it seems to check out fine and the starter cap also checked out fine .Also the breaker has tripped in the past., While i have been doing the last couple of tests it has popped to! but not saying it could still be one of those two things. or is it the TIMER? well i probably repeated myself but i hope i made it clear what my problem is!!! I HOPE U CAN HELP ME! Thanks Mike
the dr
  • 447 Answers
SOURCE: Plese help
Its hard to diagnose these motor problems...takes a volt-ohm meter with a capacitor checker.... and a lot of knowledge if youre up to it, ill try to help.
Posted on Jan 24, 2008
SOURCE: Kenmore 22956 top loader quit running after agite cycle
If the timer cycles your lid switch is ok.
most likely: motor Switch (on Motor), condenser next to motor, motor itself, or wiring going from the time to the switch,
It is probably cost efficient to replace the unit rather than trowing parts at it .
AB
Posted on Apr 13, 2008
canbruce75
  • 1776 Answers
SOURCE: Kenmore 70 Series Washing Machine Drains, But Won't Spin
Yes sir, a bad motor coupler could cause the machine not to spin. You did the right thing in checking out the lid switch and the pump first. It sounds as if the motor coupling is worn and may be slipping. I will attach a link to a video that may assist you. Hope this helps and best wishes.
http://www.youtube.com/watch?v=WLPGs2UMUJc
Posted on Aug 27, 2009
blueextc3221
  • 15935 Answers
SOURCE: machine will not work, motor hums
It appears your motor/motor controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
richroth
  • 9472 Answers
SOURCE: We used your solution to
The problem with your washer is you need to replace the brake pads, brake cam, and the clutch assembly on your washer. Over time the cam will not totally release the brake and it will cause the pads to drag (that is what your smelling) and not come up to the operating condition and in turn, since the pads are dragging, it will also cause the clutch assembly to become worn. Replacing the brake and clutch assembly's will take care of your problem and since you replaced the motor coupler, your machine will have had a complete overhaul of the agitate and spin assembly. If you could please post your model number, I will be able to direct you to the parts you need and the repair process.
Posted on Feb 05, 2011
I pull the knob to do a regular wash and nothing happens, no water no agitation. However, when I turn the knob to rinse it that works. This suddenly happened, was working before. Is it the knob?
Rinse on most washers is cold water your wash cycles can be cold hot and even warm. Problem You may have is a bad water feed valve Or Timer and possible bad wire harness at motor to timer
check water valve Turn washer to regular wash cycle pull knob on will washer fill ?
if water starts to fill then change washer temp if washer has this.
if water comes out on all settings water valve is fine.
Check the water both hot and cold that it is turned on;at faucet.
Your Kenmore Most likely has a bad water valve check for hot water side clog or not working.
Apr 25, 2015 | Kenmore 2982 800 3.5 cu. ft. Top Load...
What is wrong and how do I fix my kenmore 600 series washer?
If this is a top load washer; then the "LID Switch" is broken. Go to www.sears.com/parts, enter your model number and you'll see the switch listed.
Aug 26, 2014 | Kenmore Washing Machines
WHAT HAPPENS IF A TIMER IS OUT ON KENMORE WASHER
you push the timer in and turn it to the setting you want,when you pull the timer knob out the washer should run
Jun 20, 2014 | Kenmore 24032\24036 Top Load Washer
Maytag stacked unit LSE7806ACE. dryer is fine , the washer will not fill or run, if I manually turn the timer to drain the tub spins and the lid switch works fine. But the unit won't do anything f
You have a timer problem, the contacts are welded in spin mode.
This is almost always caused by advancing the timer by hand when the dial is pulled out in the "ON" position, causing arcing of the contacts.
Sep 22, 2017 | Maytag LSE7806A Top Load Stacked...
Stopped operating after filled with water for rinse
Have you tried moving the timer dial to other settings? will it work then? if not I would suspect a bad timer. If you are hearing the motor try and run but nothing else is happining you might want to have the couling to the motor and transmission checked out, these are common problems with these washers. Can you move the drum around freely? If you were hearing a grinding noise before this happened I would suspect the coupling, if not I would start with the timer.
Nov 13, 2010 | Kenmore 24032\24036 Top Load Washer
Kenmore 70 Series Washer Won't advance in the
Bad timer. Try to find a used one if possible, this item is a little expensive.
Aug 23, 2010 | Kenmore Washing Machines
Control knob will not turn to desired setting
the timer knob has a clip that will allow you to remove the knob from the timer. it is between the knob and the dial. what happens is the knob has gear like teeth that will become stripped out.it is easy to replace but alittle hard to remove. you need to get a small screwdriver and go behind the knob, pull on it alittle and you will see the clip, then use the screwdriver to push the clip out of the knob, then the knob will pull of and you can replace it.
Dec 28, 2008 | GE WJRR4170E Top Load Washer
Kenmore washer will not drain
I would check the lid switch first using a pen open the lid set into spin and depress down on the lid sw if you dont hear it click then it is bad
Aug 17, 2008 | Kenmore 24032\24036 Top Load Washer
AB
Apr 06, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
94 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
