Question about KitchenAid KGRS505XSS 30" 5-Burner Freestanding Double Oven Gas Range
Kitchenaid KGRS505XSS double oven gas stove/cooktop wont light in power outage
I have read this is due to a factory installed gas shut off safety. is anyone else aware of this or how to bypass / disengage it/
fridgetech
  • 473 Answers
SOURCE: Kitchen Aid KESC300 smooth top electric stove
Look on the back of the oven for a tech sheet. This will tell you what the code means and what to check. May be an oven temp. sensor or oven control bad. Can't remember what f7 is without looking at the tech sheet.
Posted on Oct 06, 2007
SOURCE: Kitchenaid Superba Gas Range
It appeared to be something to do with the plenum and cleaning - repair man came - cleansed and it was okay. MK
Posted on Aug 31, 2008
SOURCE: kitchenaid gas oven
kitchenaid is the biggest piece of ****.
completely unresponsive to their faulty appliances
can someone start a class action ?
Posted on Oct 10, 2008
  • 4 Answers
SOURCE: KitchenAid oven shut down during self-cleaning
I've had the same problem and have had the thermo-protector switch replaced four times. After the last time I was so ********** I wrote to the CEO at Whirpool/Kitchen Aid in Benton Harbor, MI with my complaint. Today I received a call from an extremely nice lady in his office who said that they were sending me an updated kit for repair free of charge. The part number is 9759243. She offered that this was a known problem but was limited to just one production run - my luck!
If you are having this problem with your KGSA906PSS write to the CEO at Whirlpool!
Posted on Feb 02, 2009
zazonker
  • 68 Answers
SOURCE: kitchenaid oven kdrp467kss09 no elecrical power
I had the same problem. There's a thermostat before the control panel. You need to remove the knobs and the front panel to get to it. You'll also need to remove a couple of trim pieces to keep from bending the panel. The part number is Whirlpool W10017820, sells for about $40.
Posted on Jun 03, 2009
I have a kitchenaid model kgrs505xss double oven. The flame in the bottom oven comes on and burns for a very short time, then turns off before the oven comes up to temperatures. What is wrong?
Any gas cooker has a thermocouple that keeps the gas valve open; if the thermocouple no longer generates current (which feeds the coil of an electromagnet) then the gas valve closes and the flame will go out. So check thermocouple. In normal conditions the voltage generate by the thermocouple is low but the current is high.
Nov 14, 2017 | KitchenAid Ovens
Had power outage & when electric company put new transformer on, stove came on with this error f11 error, when open oven door it mesg goes off & on, oven wont work now
I appreciate your post, Katherine!
Based off the information you have provided your Frigidaire range is displaying an "F11" error code after a power outage. An "F11" error code stands for a shorted keypad. I would suggest performing a reset on your range and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does not work you may need to have a professional technician out to provide proper repairs. This will prevent you from any unnecessary part purchases. Hopefully this is helpful. -Matt
May 02, 2015 | Frigidaire Stove/Oven/Range Cooktop -...
Electronic ignitor on propane stove wont start
  1. Close all valves, including the one on the supply tank.
  2. Open valves SLOWLY starting with the tank. Safety valves are built in to prevent escape og gas if vales are broken off.
  3. Turn on ONE burner valve and, depening on the ignition type of your stove, light it. (some have an electric spark generated by a power outlet (120v) and make a sort of poping sound, some have a spark generated by a push button type mechanism.
  4. Once one burner lights, the others should light easily. Sometimes air gets in the lines, and this may have to bleed off, but it should only take a few seconds. -PS, make sure the stove is level, since gas tends to flow to the high spot.
Feb 20, 2014 | Frigidaire Stove/Oven/Range White Cooktop...
Error message
try resetting the 40 amp double breaker in the panel
Nov 19, 2013 | Kenmore Frigidaire Glass Cook Top...
My kitchenaid kgrs505xss oven says feature not available
I had this problem. Turned off the circuit breaker about 5 minutes. When breaker turned back on, was able to reset
Apr 15, 2012 | KitchenAid KGRT607HBS Gas Kitchen Range
Constant clicking from electric pilot connection. won't stop after leaving for long time, unplugging overnight, cleaning all burners, running gas by lighting with match and letting the flame run. ...
Hi nancypp,
The ignition switches probably got wet.
Please follow my below Tip on how to fix it:
GAS STOVE CLICKING PROBLEM...
Kind Regards
JEDEMEYER1
* If this solution helped you, please accept it
Sep 04, 2011 | KitchenAid Cooktops
Cooktop burner switches do not ignite when turned onn
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 15, 2010 | KitchenAid 30 in. KGCS105GSS Gas Cooktop
My KitchenAid KGRA806PSS Stove's Burners won't light. And the stove gets up to 200 degrees but no further.
Bad power source. Not getting 240 volts to oven. reset breaker by turng off the back on for the stove. 240 volt double breaker. If this doesn't work problem will be where stove plugs in.
Feb 01, 2010 | KitchenAid KGRA806PSS Gas Kitchen Range
Kenmore gas stove - oven won't ignite
hi gud day,do u think the gas is ok or every time u open is come out, or check ur control gas line valve maybe it close or authomaticaly close due to some laekage. chect it by smeling every turn on ur knob,but unplug the item b4 u do.
tnx gerbee
May 27, 2009 | Cooktops
Disassembling kitchenaid gas cooktop to replace the ignitor switch
heatman101
Jun 09, 2008 | KitchenAid 31 in. KGCS105 Gas Cooktop
KitchenAid KGRS505XSS 30" 5-Burner Freestanding Double Oven Gas Range Logo
114 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
