Question about KitchenAid KGRS505XSS double oven convection gas range
Kitchenaid KGRS505XSS wont light manually in power outage
I have read this is due to a factory installed gas lock out during power failures. anyone else aware of this, and is there a way to bypass or disengage it?
2 Suggested Answers
cefelker
SOURCE: my kitchenaid kgrs505xss oven says feature not available
I had this problem. Turned off the circuit breaker about 5 minutes. When breaker turned back on, was able to reset
Posted on Oct 27, 2012
Kitchen aid gas range KGRS807, 901 or 907
The only time that the oven door should be locked is during the internal "Self Cleaning Cycle," due to the high temperatures used. Make sure that the display does not indicate that the oven is not in it's self-cleaning cycle, and try wiggling the door slightly to see if you can dislodge the sticking lock pin.
If this does not help, then I suggest that you Call the KitchenAid Customer eXperience Center toll free: 1-800-422-1230
Aug 30, 2015 | Kitchen Ranges
Err 01 little sister ses
This is a power failure alarm, meaning the prior cycle failed due to a power failure/ outage.
Verify your power supply is correct for this unit's needs.
Check the fuses.
Beyond that, it may be a wiring/power supply issue. Call for service.
Jan 29, 2014 | ESCHMANN Little Sister Autoclave Tabletop
HOW TO LIGHT OVEN WITH A MATCH
Look up product manual on internet.
Look at label located inside oven door, and add .pdf to search parameter to help find manual.
Then read section about lighting appliance.
If power is out, then pilot will not have any gas >> if gas control is electronic.
Many electronic gas controls require electric power to operate circuit board.
In old days, you removed the bottom tray on oven to access burner and pilot orifice. Then you pushed down switch to release gas through pilot tube, and put lit match into the gas stream to light pilot. Hold down switch until pilot flame heated tip of thermocouple which caused magnetic switch to stay open inside gas control. Release switch and pilot stayed lit.
Safety concerns and vast advances in manufacturing cheapness have changed gas appliances so they are more inconvenient for do-it-yourselfers during ordinary power outage.
Cook hamburger over metal bucket with newspaper, and grease on newspaper burns enough to cook hamburger.
People always buy generators and flashlights, but nobody suggest buying barbeque briquets and starter fluid as way to keep warm and cook.
Oct 29, 2012 | General Electric GE 24-Hour Power Strip...
My 2001 vw jetta wont pass smog, failed on emissions part..check engine light is on for multiple things do I need to fix all to get car to pass smog? Fuel injectors and O2 sensor.
ALWAYS PERFORM TESTS AND REPAIRS ON THE FIRST DTC AND RETEST AFTER EACH STEP.ONE SENSOR OR COMPONENT FAILURE CAN CAUSE OTHERS TO FAIL AS A RESULT.MEANING THE FIRST CODE COULD HAVE CAUSED THE OTHER CODES TO CYCLE.SO ALWAYS DIAG THE FIRST CODE STORED AND EACH ONE AFTER AS THEY WERE READ DURING THE SCAN
Oct 09, 2012 | 2002 Volkswagen Jetta TDI
My kitchenaid kgrs505xss oven says feature not available
Apr 15, 2012 | KitchenAid KGRT607HBS Gas Kitchen Range
Rheem Power Vent 50 gas water heater will not come out of vacation mode! Have tried turning on and off, resetting and following directions on the side of the tank. Will not come out of Vacation Mode. Had a...
Water inside tank-type water heater can remain hot for some time.
That's one advantage of well-insulated tank-type water heaters.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Power outage can be related to failure of gas control.
Unplug stuff when power goes out. And then plug back in after power is restored.
Water heaters with electronics are not protected from surge.
Electronics can blow out during and after power outage. For example nearby lightning strike will cause current to run along household wires. With ordinary power outage, once power is restored, the surge can affect all kinds of electronic circuitry such as timers, water heaters, water softener, treadmill etc.
Sounds like you have intellivent gas control valve:
Open following link to identify gas control, and download typical manual, and download intellivent service manual with troubleshooting, error codes, etc.
http://waterheatertimer.org/How-to-adjust-temperature-on-water-heater.html#intelli
Take a moment and vote on answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Aug 26, 2011 | RHEEM 50 Gallon FVR NATGAS Water Heater...
What does the sign "control lock" mean?
Here is what the manual for your oven says about control lock.
Let me know if you have questions.
Control Lock
The Control Lock shuts down the control panel pads to prevent
unintended use of the oven(s). The Control Lock will remain set
after a power failure, if set before the power failure. The only time
it is not available is during the Sabbath Mode or Self-Clean cycle.
When the control is locked, only the TIMER SET · START, TIMER
CANCEL, OVEN LIGHT and CANCEL OFF, UPPER OVEN
CANCEL / OFF or LOWER OVEN CANCEL / OFF pads will
function. On double oven models, CLOCK SET · START will also
function.
The Control Lock is preset unlocked, but can be locked.
To Lock/Unlock Control: Press and hold CONTROL LOCK for
about 3 seconds, until “CONTROL LOCK” and a picture of a lock
appear on the display. Repeat to unlock and remove “CONTROL
LOCK” from the display.
May 13, 2010 | KitchenAid SGL OVEN T/C
How to use kenmore gas range during power outage
just use a match to light top burners, the oven will not work or pass gas if you have a electronic ignition range
Feb 06, 2010 | Kitchen Ranges
KitchenAid electric range KERS807SSS02 -in the middle of cleaning cycle, NO power outage but panel went black and door remains locked even after cooling. Circuit breaker not the problem. Top elements work.
We have a Kitcheaid gas stove and have had 3 new thermostats installed. After the 3 time it finally did it's first full cleaning cycle.
So three service calls later, (first was after the warranty) and three thermosats and over $500 and the stove has done it's first full cleaning.
Lots of examples of this same problem but it seems no recall on the stoves.
Jan 08, 2010 | KitchenAid KDRP407HSS Dual Fuel (Electric...
After a power outage our 500 series quit working.
lights only need 110 volts.. try turning off and on you double pole dryer breaker again(may need replaced)
Mar 15, 2009 | Kenmore 72062 Gas Dryer
KitchenAid KGRS505XSS double oven convection gas range Logo
90 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
