Question about Panasonic Lumix DMC-FX9 Digital Camera
Can I use 4gb sdhc card on lumix fx-9 - Panasonic Lumix DMC-FX9 Digital Camera
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Panasonic Master
  • 102,366 Answers
No. The DMC-FX9 works with SD cards, not with SDHC cards.
Posted on Nov 02, 2012
SOURCE: Message: Memory Card Error - Memory Card Parameter Error on 4gb SDHC card
I recently bought a DMC-TZ3 and have been researching memory cards. Several sites sell cards with the camera and list the card type. I would suggest buying one of these cards. Any cards larger than 2gb must be SDHC type SD cards. There appear to different types of SDHC cards, 1.0, 1.1 and 2.0. Check out Wikipedia.org for a description. 2.0 cards are not compatable for devices developed prior to 2.0 so that may be the reason for the camera problem. So far I haven't seen anything that states what type SDHC card the camera requires. I found a computer memory site that that sells memory that they say will work. There may be others.
http://www.mymemory.co.uk/compatible-memory/Digital_Cameras/Panasonic/Panasonic_Lumix_DMC-TZ3
Posted on Dec 27, 2007
I think your camera is not compatible with the SDHC card you bought. Check this: http://panasonic.jp/support/global/cs/sd/connect/dsc/dsc.html
Posted on Mar 03, 2008
DR NITIN
  • 221 Answers
SOURCE: Lumix lens retracts and extends
Belikes, any external object is trapped in between your Lens Motor and Camera Body. You should consult Authorized Service Personnel to handle this trouble.
Posted on Jul 28, 2008
actionreplay
  • 73 Answers
your sd card is sadly corrupted if you downloaded the pictures to your computer your in luck then get a new sd card and download all the pictures from the computer if its a labtop put the sd card on the bottom hope this helped vote thumbs up for more answers hope this helped
-Yashar G.
Posted on Aug 24, 2009
  • 11967 Answers
SOURCE: sandisk sdhc 4gb memory card wont work with my
You need to format the card in the camera to optimize it.
Posted on Sep 24, 2009
I have a Panasonic Lumix DMC FX30. Why aren't there SD memory cards in 4gb or higher? Can I substitute any of the other SDHC cards?
There are no SD memory cards 4GB or larger because the Secure Digital standard limits card capacities to 2GB. While SDHC cards will fit into the slot, they are electronically incompatible and will not work in the DMC-FZ30. You will need to stay with SD cards 2GB and smaller.
Feb 25, 2011 | Panasonic Lumix DMC-FZ30 Digital Camera
What is the largest memory card I can use with this camera? Is 16g too large? I get a memory card error message when I put one in and I cannot format it.
The problem is that your camera is only compatible with SD cards, not SDHC cards. You bought a larger card for your older camera, not noticing that it was SDHC (or not knowing that it mattered). The new card doesn't work, not because it or the camera is broken, but because it's not compatible.
Cards up to 2Gb are generally SD.
Cards of 4Gb are generally SDHC.
Cards over 8Gb have to be SDHC.
(There are exceptions. Sometimes, manufacturers make 4Gb SDHC cards but some have errors; they disable half of the chip and sell it as 2Gb, but it's still SDHC. 4Gb cards are almost always SDHC because they're cheaper, but 4Gb SD cards do exist. They are so rare that I've even seen a guru on this site claim they don't. I did own one once, but it was very expensive and turned out to be so unreliable that I had to return it. I don't recommend looking for one, because of the problems.)
Your solution is to go find a 2Gb card, and be extra sure that it doesn't say "SDHC" on it.
Jan 21, 2011 | Panasonic Lumix DMC-LC33 Digital Camera
I bought a SDHC 4GB card and introduced in the camera. When turn on, came the message "memory error". What should I do?
Check your instructions, is a 4GB SDHC card compatible with your camera.
if you don't have a manual, just google "panasonic lumix dmc-fx01 manual" several options will appear.
Page 16 deals with card compatibility, it states that the maximum you can use is a 2GB Sd card, no mention of SDHC.
Nov 19, 2010 | Panasonic Lumix DMC-FX01 Digital Camera
What is the maximum size to use for an sd card for lumix dmc tz3
The maximum size SD card you can use is 2GB because that is the maximum size SD card you can buy. Cards bigger than that are SDHC (Secure Digital High Capacity) cards. Fortunately the TZ3 is capable of using SDHC cards of 4GB and larger.
Apr 13, 2010 | Panasonic Lumix DMC-TZ3 Digital Camera
Panasonic DMC--LZ2 gives me ''memory card error'' message if i put a SanDisk SDHC 4GB card in.
The DMC-LZ2 is specified to work with SD cards, not SDHC cards. While SDHC cards are physically compatible with SD cards, they will not work in SD devices. SD cards will work in SDHC devices, but that doesn't help you any here.
It's a hardware incompatibility. No firmware update can get around it.
Apr 05, 2010 | Panasonic Lumix DMC-LZ2 Digital Camera
Lumix FX10 - 4gb card reports "card error"
I think you need a SDHC 4GB card. SD is only supported to 2G.
Jul 28, 2008 | Panasonic Lumix DMC-FX12 Digital Camera
4gb Sandisk sd card -
this camera will only take up to 2gb
Feb 29, 2008 | Panasonic Lumix DMC-FX01 Digital Camera
SDHC Memory Card error
I had exactly the same problem with a 2 year old LX-1. The card worked fine on the computer, formated no problem but would not work in the camera.
I took a can of air and used maybe 3 one second bursts to blow out the card slot. Card immediately started working.
-prmolina
Feb 19, 2008 | Panasonic Lumix DMC-FZ18K Digital Camera
Panasonic Lumix DMC-FX9 Digital Camera Logo
77 people viewed this question
Top Panasonic Cameras Experts
Computer Links
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
