Question about Canon iR 1600 Copier
Canon ir 1600 error e733
Have first changed laser unit after a few copies it come back then changed the main motor and some thing happened then today l changed power supply unit and the main board after abt 30 copies it shows error e733 l swicth off and on it goes but after few copies it comes again
  • 121 Answers
SOURCE: Canon IR 1600 Error message E000
You'll need to replace the fuser unit. Not exactly the cheapest part of the machine...
Unless, that it, you were taking things apart and happened to unplug something accidentally. If you take the cover off where the paper comes out, look at the connectors directly inside there under the black piece of paper that you'll see. If one of those are pulled out, it could cause the problem.
Otherwise you need to replace the fuser unit.
Erice
Posted on Nov 23, 2007
SOURCE: Canon IR 1600 error message
Note: To reset E000, E001, E002, E003, go to service mode 4. select SET, go to "#7 PRINT-ER," in service mode. Then press Execute "#4 PRINTER RESET." Power the unit off/on.
Posted on Jan 12, 2009
old marine
  • 2005 Answers
SOURCE: I use a Canon ImageCLASS MF4350d Laser All-in-One
I think that error code means a problem with the scanner/lamp. Any type of Exxx code means the machine needs (repair) service. This is a fairly new product and should still be in warranty, so I recommend you contact your regional Canon service agency.
Posted on Nov 11, 2009
SOURCE: error code e000007-0000 in caonon ir 3300
my canon ir 3300 shows error e-000007-0000 how can i solve this problem
Posted on Feb 11, 2010
SOURCE: canon IR 2020 showing system Error E007 printer
my canon ir2020 is displaying system error E007
Posted on Jul 20, 2010
I have brother DCP 7055 it shows print unable 71 error pls suggest
This is due to Polygon Motor Error in the Laser Unit.
Pls try one of these:
1. Input the correction value of the laser unit correctly.
2. Check the harness connection of the laser unit. Try re-connect them.
3. Replace main PCB Assembly.
4. Replace the laser unit.
Mar 02, 2015 | Brother Dcp-7055 Laser Print Copy Scan...
I have a Xerox Phaser 3300 MFP wITH BLANK COPY i CHANGE MAINCONTROLLER, LASER UNIT pOWER SUPLYANY iDEA
If you can print any internal report from the machine or from your computer then the problem is in your scanner.
If you cannot perform any print function then probably the laser assembly has failed.
Mar 14, 2012 | Office Equipment & Supplies
Copies fading on Aficio 2020D even though toner is full
Hello!
First i need to know if that symptom is just in copies or also happened when you make a print.
If it is just in copy you have dirty on the exposing lamp of the scanner.
If it happened also in printing it could be several things.
I can give you same tips:
-The glass of the laser is dirty (this glass is under the tonner supply unit)
-The drum unit need to be changed.
The question is: When was the last time that you did a preventive maintenence????
Probably this is the best help i can give you; make a PM.
See you!!
Aug 04, 2011 | Ricoh Aficio 2020D Copier
Bought a Packard Bell Onetwo L5851 yesterday. Unable to switch it on....Blank screen with a few lights below,thats it . Nothing responding.
I have a similar problem with a Packard Bell OneTwo S PG4G1TU01 : when switching it on, it work a few minutes and suddenly shutdown, as a brutal power down. But the green light at the bottom still working. I have changed the extern power supply and now it work fine... The new power supply is a 90W model, not a 65W like the original one. Maybe it can help ?
Dec 28, 2010 | Computers & Internet
What is err0r code E 7 02 IN ARM 450 COPIER
The E7-02 means the beam detect sensor never received a beam from the laser. As the previous poster stated you'll need a new laser unit. Meaning that you need to change the whole laser unit but not the polygon motor.
E7 02 Content Laser trouble
Detail BD signal from LSU is kept OFF, or ON.
Cause The connector of LSU or the harness in LSU
is disconnected or broken.
The polygon motor does not rotate normally.
The laser home position sensor in LSU is
shifted.
The proper voltage is not supplied to the
power line for laser.
Laser emitting diode trouble
PCU PWB trouble
Controller PWB trouble
Check and
remedy
Check for disconnection of the LSU
connector.
Use DIAG (SIM 61-1) to check LSU
operation.
Check that the polygon motor rotates
normally or not.
Check light emission of laser emitting diode.
Replace the LSU unit.
Replace the PCU PWB.
Replace the Controller PWB.
Mar 15, 2010 | Toshiba E-STUDIO 650 Copier
Konica minolta bizhub 162 have error C0000(main motor malfunction) i try with another motor but same thing! any ideas?!
could be master board (pwb-a) or power supply unit (pu-1) or something that the motor turns is locked up try to you turn the motor by hand whil it is installed in the machine if you cant turn it by hand something is locked up
Nov 30, 2009 | Office Equipment & Supplies
Copies are black . Changes toner and cleaned corona wire, but still coming out black & blotchy
(2) All black At the scanner
Check the following components:
- CIS harness
- CIS unit
- Main PCB
At the printer side
 Clean the high-voltage contacts for the grid and charger on the
drum unit, main cover, and high-voltage power supply PCB.
(Contacts and in the illustration given on page 6-28)
 Clean the charger (corona wires) itself.
 Check the connection of the laser flat cable on the main PCB.
 Replace the drum unit.
 Replace the high-voltage power supply PCB.
 Replace the main PCB.
Nov 24, 2009 | Brother IntelliFAX 2800 Laser Fax
Xerox DC12 gives error 14-372 please HELP!!
ERROR 14-372 ROS MOTOR FAIL , ITS THE MOTOR THAT ROTATES THE POLYGON OF THE LASER BEAM , ITS LOCATED , BELOW THE SCANNER UNIT AND OVER THE COPY/PRINT CTG. 13R557/13R558 . IT CAN BE ONE OF 3 THINGS THE ROS ASSY. (LASER SCANNER UNIT OR ROS) , IOT DRIVE PWB(THE PC BOARD BELOW THE NVM AND IOT-SYS) OR A PROBLEM ON THE WIRING HARNESS / POWER SUPPLY. WE CAN REPAIR THOSE UNITS OR I CAN PROVIDE YOU THE PART NUMBERS IF YOU WANT TO ORDER THEM NEW FROM XEROX . diesco_cxl@hotmail.com
Mar 23, 2009 | Xerox DocuColor 12 Printer
DP-190 Blank Copies
By the write unit i guess you mean the LSU. If you've already ruled out the the image drum and transfer roller you're only left with a few possibilities. I'm also guessing this fault only happened after you replaced the LSU??
1 is there something obstructing the beam from the scanner to the image drum.
2 have you damaged one of the 2 harnesses going into the LSU (check the contiuity) also check the connections on the system board.
3 The high voltage power supply may be faulty.
4 The system board may be faulty.
I repair lots of the DP180's the european version
Aug 24, 2008 | Panasonic DP190 All-In-One Laser Printer
Xerox workcentre xd105f
Guest.
The L6 indicates the machine is not seeing the motor in the laser, that rotates the mirrors.
There are 3 possibilities, I will list them in order of probability.
1 The Laser unit itself.
2. The cable connection on the Main Board.
3. The Main Board itself.
The laser depending on the lens, Curved or straight is $323 and $393.
the main board will cost in the $250-$400 range depending on the vendor.
That is without labor.
Oct 29, 2007 | Xerox WorkCentre M123 Copier
Canon iR 1600 Copier Logo
799 people viewed this question
old marine
old marine
