Question about Dryers
Gas dryer doesn't heat properly
I own "Simplicity" gas dryer (Model No. SGD4510 made in U.S.A.), which I purchased in 1997. When the dryer is first turned on the burner goes out after 2-2.5 minutes and then after 15-30 seconds I hear a click but nothing is happening (the igniter doesn't glow and the burner will not ignite). Once out, it won't re-light for the duration of the cycle. There is another thing, which puzzles me the most but might be helpful. Whenever I stop the dryer or let it finish the cycle and then try to run it again the igniter doesn't come on at all and subsequently fails to light the burner. But ... when I disconnect the wires (or even one of the two) from the flame switch and push them back in right away the dryer repeats the same process as I described above. So far I've thoroughly cleaned the venting system (including dryer blower) and replaced Valve Solenoids (Coils). Any ideas on what the problem might be? Any help would be greatly appreciated. Thanks, Liz
  • Elizabeth Seremak Nov 08, 2012
    Hello Richard, Yesterday I changed the flame sensor as you suggested and ran a quick test. It appears that this took care of the problem. Thank you very much for your advice, Liz
  • Richard Roth
    Richard Roth Nov 08, 2012
    I'm glad I was able to help you. Thanks for using FixYa!
    Top Expert:
  • Dryers Master
  • 9,472 Answers
You need to replace the "flame sensor" on the dryer. If this is faulty, it will give you problems like you described. Here is the part to order.
Keep me posted!
Posted on Nov 03, 2012
jsrock516
  • 5911 Answers
SOURCE: After a few heating cycles the burner does not ignite
The problem you are describing is usually associated with a bad gas valve coil. The dryer runs normally until it gets hot, then starts making a strange clicking noise. After it cools down, the dryer runs normally again. The gas valve coils (there are two of them) usually run about $20 a piece. I recommend replacing both of them at the same time just to be sure. I hope this helps.
Posted on Apr 29, 2007
the dr
  • 447 Answers
SOURCE: kenmore gas dryer 80series model 110.c72852101
90% of all gas dryers lighting intermittently is resolved with new coil packs on the gas valve. The coils are replacable fairly easily and inexpensive.
Posted on Oct 04, 2007
Illeagle
  • 525 Answers
SOURCE: dryer wont heat
About all that is left to replace is the flame sensor mounted at 9o'clock on burner flame tube, but I would double check your airflow, This is CRUCIAL to the normal operation of the dryer.
Also, a lint filter with an invisible coating from fabric sheets can cause an airflow disruption, try running without clothes and the filter removed.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
docjohn174
  • 943 Answers
SOURCE: Maytag Neptune MDG300aww Gas Dryer Heats On and Off
hI YES THE COILS IS WHAT YOU HAVE TO CHANGE thANKS FOR THE QUESTION tHE APPLIANCS DOC
Posted on Sep 12, 2008
TheMobilian
  • 8220 Answers
SOURCE: Inglis gas dryer heat loss
Replace these solenoids on the gas valve. Feel them if you can. They get hot and quit.d910ca8.jpg
Posted on Feb 04, 2009
My whirlpool dryer comes on and runs good but it wont get hot can you tell me whats the problem
Hello there and welcome to fixya there are several things that could make this dryer not heat up
Here are the most common things
Thermal Fuse
If the dryer doesn\'t heat, but the drum
turns, check the thermal fuse(s). The thermal fuse protects the dryer
from overheating and helps to prevent fires. If the thermal fuse is
blown, it will have to be replaced.
Enter your model number to see parts for your dryer.
Help me find my model number
Gas Valve Solenoid
The gas valve has two or more electric
solenoids which open the valve to let the gas flow into the burner
assembly. If the dryer doesn\'t heat one or more of the solenoids may be
defective. If the igniter glows for 90 seconds but the burner flame
doesn\'t light, replace these coils as a set.
Dryer Igniter
If the dryer doesn\'t heat, the igniter might
be burned out. Check the igniter for continuity with an ohm meter. Dryer
igniters burn out over time, similar to a light bulb.
Heating Element
The heating element on an electric dryer can
burn out over time. If the dryer doesn\'t heat, the element should be
checked for continuity. The heating element cannot be repaired and must
be replaced if defective.
Heating Element Assembly
the heating element assembly on an electric
dryer can burn out over time. If the dryer doesn\'t heat, the element
assembly should be checked for continuity. The heating element assembly
cannot be repaired and must be replaced if defective.
Flame Sensor
Gas dryers have a flame sensor to detect the
heat given off by the flame. If the dryer doesn\'t heat, the flame sensor
might be defective. Check the flame sensor for continuity. This is not
as common as a burned out igniter or thermal fuse.
High Limit Thermostat
Although not common, if the dryer doesn\'t
heat the high limit thermostat can be defective. It can be checked for
continuity. If the thermostat is "open" the dryer doesn\'t heat.
Cycling Thermostat
The cycling thermostat regulates the
temperature of the air in the dryer. If the dryer doesn\'t heat it may be
caused by a defective cycling thermostat. This is not common.
Main Control Board
The main control board is normally not at
fault when the dryer doesn\'t heat. Check all of the other components in
this troubleshooting guide before replacing the main control board. The
main control board cannot be tested easily and must be replaced if it is
defective.
Timer
The timer is normally not at fault if the
dryer doesn\'t heat. In many situations where timers are replaced they
end up being returned. Check all of the more common components in this
troubleshooting guide before replacing the timer
Oct 14, 2013 | Dryers
I have a Maytag Neptune gas dryer, model #MDG4000AWW, Serial #10793672WF. The unti is operating but doesn't heat up. Do you think it is the igniter and/or the heating element? Also, can I replace...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 11, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Dryer spins but doesn't get hot. Model #11077522600
heatman101
Sep 09, 2011 | Kenmore 73952 Gas Dryer
My daughters "Kenmore Elite Gas
heatman101';
Sep 01, 2011 | Dryers
Hi I have a GE Profile DPGT750GC gas dryer and it doesn't heat. I've had this model for a few years and it worked fine until about last year. The drying wasn't good at times but didn't...
heatman101';
Aug 11, 2011 | Dryers
My amana electric dryer model number "NED7200TW" wont heat up. Everything else works it just don't heat it just puts out cold air. The exhaust was somewhat clogged outside but even after...
heatman101.,./
Jul 27, 2011 | Dryers
Frigidaire dryer model fern7800ds0 doesn't heat
heatman101
Jul 14, 2011 | Frigidaire Electric Dryer
Our Frigidaire Dryer Model FERB7800DSO turns but doesn't heat. I checked the breaker and turned it off and back on with no fix. I see where some say it could be a clogged vent, bad thermostat, or...
heatman101';
Jul 05, 2011 | Dryers
Dryer runs but doesn't heat up?
heatman101/,m.,./'
Jun 24, 2011 | Frigidaire GLGR341AS Gas Dryer
I had the " dryer
heatman101
May 07, 2011 | Roper RGX4634KQ Gas Dryer
Dryers Logo
80 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
