Question about Fisher Price My Little Lamb Cradle N Swing Baby Swing
The swing stopped playin all together
I added new batterys an the swing still didnt work..its been used twice for 30 seconds each my daughter hated it.. i cant return it bc it was a gift so i have no recite to it.. i took all the bolts out an lifted to top and a black wire had been cut or such! what is that black wire for ? an if i put them back together the swing all works fine. just wondering what that wire is for!!! thank u for ur time!
    New Friend:
  • 57 Answers
Usally if its house power black is hot wire white is neutrel green is ground if its 12 volt powered black is ground and white is positve so the black wire has to be grounded for it to work.
Posted on Aug 03, 2017
3 Suggested Answers
  • 35 Answers
SOURCE: Hi, I have a fisher
You can purchase replacement motors from Mattel (Fisher Price's parent company).
It will be one of the following 3 products, just pick the one that matches what you have now:
Posted on Mar 10, 2011
SOURCE: I have added live batteries
It could be the brand of batteries. I had one that wouldn't work unless it was name brand batteries such as Energizer. Check the brand and make sure they are installed correctly.
Posted on May 16, 2011
Fisher price my little lamb baby swing will not swing
If it makes a sound but doesn't swing then the metal rod inside the motor casing was probably bent. If it makes no sound then it could be several different problems.
If it does make noise (my daughter did the same thing) then you can fix it, though it's not the easiest fix. Unplug it/remove batteries, and you'll need to remove the legs. Start removing screws to get to the motor casing, the first ones you'll need are in the battery compartment. Be careful as you're doing this, once you get the plastic casing off things can move around. Have someone as a second set of eyes if you need it.
Once you can see the guts look for a thin metal stick, no thicker than a telephone cord. Yup, that's what moves the swing. The metal is easily stressed. You can carefully power it up if you want to see how it works or make sure that little thing is moving. There's a small gear underneath all that, but you don't need to get to it.
Instead, you'll need to beef up that little stick. I used a leftover rubber gasket from a ceiling fan first, then I was so amazed it worked I took it back apart and used a longer piece of rubber tubing with a harder plastic tube over it (it's a very tight fit). It will still need to rock back and forth in it's little hole so don't go too crazy.
The one drawback is that I think it has a louder operation now, but the one thing that both my kids adored with the swing was the rhythmic tick-tock. If baby is happy, mama is happy.
Anyway, FP will sell you a whole new motor, or if you an find the exact part number you might be able to get a new pendulum. But I like fixing stuff, and I like free better, so if this is what yours needs I hope it helps. If this is but you don't follow what I've written I'm happy to try and take pictures of mine.
Aug 30, 2012 | Fisher Price My Little Lamb Dreamy Motions...
Swing stopped working
Had the exact same issue, so I called FP. I had already taken the motor housing off to see if it was something obvious, like a loose connection or broken part. I didn't see anything wrong so I just cleaned it up and put it back together. When I called they offered to sell me a new motor for around $80. Then the lady I was speaking to (who was typing as we talked) said "hey, wait, there's a note in here about this issue..." She said to do what I had done, lightly clean it out with something like a keyboard cleaner, then using the plug (not batteries) set the speed to two/center. It somehow resets it.
That worked for me, and it was free. If that doesn't work then yes, you can get a motor directly from FP. Call the customer service number listed on the back of your manual, if you have it, or 800-432-5437. You'll need to have it nearby so you can give them the model number and year that is listed on the back of the motor housing (open the battery compartment if it isn't on the outside).
You can also get motors online, especially ebay, from any of the papasan swings FP makes. I love this swing so much that I think it's worth it. I've used it for four years now and plan to use it in the future.
Aug 01, 2012 | Fisher Price Starlight Papasan Cradle...
I bought the swing for my daughter and put new batteries in. Music works but it won't swing at all. What is wrong? I hate that I spent 60 dollars on something that doesn't work.
It's likely the motor gone bad. The contacts inside the motor can get burnt out and prevent the motor from turning. Did you buy the swing brand new, or was it used? If you bought it new you should return it for a refund.
Dec 14, 2010 | Summer Infant Just One Year Travel Swing...
My Acer One notebook won't operate on electric power or charge the battery. I recall reading an on-line article about holding down the power button for 45 seconds and that worked once or twice, but it no...
Try this first, Unplug the power cord, remove the battery, Hold down the power button for 30 seconds, reinstall the battery, try to power it on, If it doesn't try to power on, The battery needs replaced, plug the power cord back in and power it on, If it still won't power up, then it's the power supply.
Nov 29, 2010 | Acer Aspire One PC Notebook
Acer Aspire One Notebook - 30 sec Shut Off issue.
This sounds like a system board problem and is almost impossible to diagnose remotely.
However, if you can't solve the issue and want to recover your data I would suggest removing the hard drive, buying a USB external 2.5 inch enclosure (just a few pounds/dollars on ebay - make sure you select ATA or SATA) and connect the drive to another computer to recover your files.
If you want some more help on that please ask by adding a comment here.
Mar 29, 2010 | Acer Aspire One Netbook 8.9" Notebook
My daughter received the art academy air brush artist for christmas. we installed brand new batteries and it appears to be working properly, however, when we install the marker, firmly in to the receiver,...
I don't have a solution, but my daughter also received this as a Christmas gift and while most of the markers worked at first, after only a few uses they have stopped. If you get an answer, I would like to hear it.
Dec 26, 2009 | Playgo Ltd Toys
How do I start my Pulsar watch? The instructions said to swing it side to side for 30 seconds...that didn't work. Checked the battery and it's ok..even exchanged the watch but this one's the same...I...
If you're supposed to swing it, that means it's an automatic or kinetic watch and it charges it's battery using an internal winder that moves as the watch moves. Try wearing it for a while, being mindful of moving your hand, or if that doesn't work try using a watch winder. If none of that works it probably needs a new movement. Take it to your dealer to submit for warranty.
Dec 20, 2009 | Watches
Baby swing......graco doesn't swing
I had the exact same problem the motor worked fine but when we took it apart the gear inside was stripped. i hate saying it but best thing you can do is buy a new swing. i personally recommend its a little bit high but so worth the money. my 8mo old baby girl loves it. it also has a AC adapter so no more batteries and an ipod hook up as well so you can pick what music you want your baby to listen to. best of luck.
Mar 29, 2009 | Baby Gear
Buttons stopped working
Probably you changed battery youself. If that's right, then open watch again, take battery out and check it with tester if it is fully charged. If yes- put battery back in place and secure the contact. Now carefully check for AC sign on movement. When found- take fine tweezers and connectAC with battery+ for 3 seconds.
Watch should work now, but resetting is needed. Use your watch manual to reset all watch functions.
NOTE: Some movements require connect AC and+ twice. This should be written inside caseback or on battery cover.
Good luck.
Dec 15, 2008 | Casio G-Shock GW500A-1V Wrist Watch
Front Load Washer - Error F30
Jun 16, 2008 | Washing Machines
Fisher Price My Little Lamb Cradle N Swing Baby Swing Logo
57 people viewed this question
Top Fisher Price Baby Gear Experts
Lyle Siemens
Lyle Siemens
Jennifer Rock
Jennifer Rock
Are you a Fisher Price Baby Gear Expert? Answer questions, earn points and help others
