I purchased onkyo 606 receiver and Polk RM85 speakers and Polk PSW110 subwoofer. When I turned the volume on my receiver to max, the system shutdown. When I turned it back on, the sound is very low from the speakers. I replaced the receiver with the same model but the problem is still there.
    Novelist:
  • 146 Answers
Sounds like you popped the voice coils in the speakers when you overloaded the old receiver. The system shut down to protect the speakers, but it didn't shut down in time.
Time for new speakers or to have the old ones re-coned.
Good luck
Posted on Jan 04, 2009
How do you take the back plate off my PSW110 to replace fuse?
try under neath bottom of the speaker if there are no screws or pegs to remove the back or underside the unit my be a sealed unit.
Oct 15, 2014 | Polk Audio PSW110 Subwoofer
Burned amplifier and we cant determine what exactly it is,a capacitor or resistor or something.
Hi, capacitor burning is a seldom case. most burns happens on resistor for they handle currents and suffer resistance.
Feb 26, 2011 | Polk Audio PSW110 Subwoofer
I have an onkyo tx-8255 receiver and i bought a psw-505 polk audio subwoofer to supplement my Boston acoustics cs-26 bookshelf speakers but i cannot get more than the deepest of bass to emit from the sub. ...
The problem is you are dealing with two different brands of speakers, I know because I ran into the same issues you are facing now, I had a Bose sub matched up with two Radio Shack Satellites and sound was not balanced it was awful. Finally I broke down and bought a pair of Bose Satellites and I have never regretted it since. The point I'am making is that when you mix brands the sound will be unpredictable, the problem with most subs is they have a very low roll off frequency even without the crossover making almost impossible to match speakers.
Feb 05, 2011 | Onkyo TX-8255 2 Channels Receiver
New polk psw110 sub for rca rt2250 reciever
Hi there.
To answer your question;
There is no problem in using both subs at the same time. As a matter of fact you could split your signal in ten and have a sub for each one of them.
You`ll just have to set the subs levels so they match each other and i`d say the more sound to the larger sub.
Just try it at different sound level and you`ll find the correct setting.
Have fun Happy holidays
Dec 29, 2009 | Audio Players & Recorders
Reciever turns off
Powering off usually points to issues with speaker setup. You should read pages 42 and 96 of the 606 manual.
Page 42 covers impedence settings. Check your impedence settings for your speakers. The 606 handles speakers from 4 to 16 ohms. There are two impedence settings on the 606 - 4 ohms and 6 ohms. Set to 4 ohms if your speakers are 4 ohms or more but less than 6 ohms. Set to 6 ohms if your speakers sit between 6 and 16 ohms. Incorrect settings can result in the 606 going into power protection after prolonged use or at higher volume.
Page 96 covers testing for unexpected power protection. You should switch off your AV at source and leave for an hour. Disconnect all cables to speakers and other peripherals (TV, DVD et al). After an hour turn on AV and turn volume to MAX, If the AV remains on, turn down volume to min, switch off AV and reconnect all devices. Make sure the speaker cables are properly connected and that no bare wiring is exposed.
Once you have done this switch on the AV and turn to volume to MAX. If the AV stays on then problem solved. If the AV switches off then you should contact your supplier.
Nov 24, 2008 | Onkyo TX-SR606 Receiver
Not working until the power switch is toggled
Try turning up the sub output on the onkyo.
Aug 05, 2008 | Velodyne CHT-10 Subwoofer
How connect subwoofer to onkyo 8522
does it have speaker wire in and out use then from fronts
Feb 04, 2008 | Onkyo TX-8522 Receiver
Onkyo TX-SR304
Onkyo offers access to manuals at their web site. HERE is a link to the receiver line.
Personally, I'd connect the speakers to main left/right. The subwoofer to subwoofer out. The Go VIdeo unit to VCR/Video 1, the cable box to Video 2 and the video output to the Sony TV composite input. No need to connect the TV audio out to the receiver since the audio feed comes from the cable box.
Jan 13, 2008 | Onkyo TX-SR304 Receiver
Onkyo HT-R501 7.1 reciever issues
i have the same problem with a onkyo tx ds494
Jan 05, 2008 | Onkyo TX-SR605 Receiver
276 people viewed this question
 Grubhead
Grubhead
