Question about Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter
Device could not be started
HI ALl, suddenly during working my connection got lost...i am able to connect thru ethernet. In device manager..my device manager is showing an excalamation mark over the network adapter with error code as 'Device can not be started' when i am uninstalling and resinstlaling the driver two drivers are coming Intel pro wireless 39454BAG and Intel pro wireless 39454BAG-Miniport work scheduler..The second one when double clicked showing fine. but the first onw is getting installed everytime. Please help
  • 1 more comment
  • saurav sarkar May 19, 2007
    Hi Sandrew,
    thanks a lot for posting.....
    yes the third point it true...when i am double clicking on the adapter from device manager its giving me 'Adapter state not founnd in regidtry'.
    thanks again.
    i am trying what you suggetsted the first point
    i checked the bios....
    the wake up on lan option is disabled.
    I did not find menu for wireless lan.
  • maxyxmax Sep 10, 2008
    just the same exact problem
I am having this same problem. When I go into the bios, it says "Restore" in grey for the wireless lan. How do I change this?
Posted on Aug 06, 2008
    President:
  • 2,961 Answers
This sound like its a bios problem, check in the bios F2 or Del on boot up and look in the menu for your internal wireless adapter as it may have been dissabled. This is the only way your notebook can possibly have to keep installing it, as the device is there but not being recognised next time you boot, check to see if the cmos time is correct, as other things may be incorrect. The only other thing is that the card driver is not correctly loaded as when the pc boots it should find the hardware then install the driver for the wireless reciever straight away, if its asking for a driver then the driver has not been registered in windows and cannot be found.
Posted on May 19, 2007
How do I switch from WIFI to ETHERNET which function key (symbol) MSI U230 ?
First try keystroke fn+f10
If that doesn't work, try the following:
Follow this sequence to reach Deviceicon1.png Manager.
1. Click on Start Menu / Right-click on Computer / Click on Manage.
2. Click on Device Managericon1.png on the left column, and then double click on Network adaptersicon1.png.
3. You should see 2 adapters, double-click on your wireless adapter to enter property.
4. Go to Advanced tab, select Radio Power and make sure it's set to Disable.
5. Try your Ethernet connectivityicon1.png again.
You should now be able to use strictly your Ethernet.
Aug 22, 2014 | MSI U230 Light087 Netbook
Lost internet
You will have to open up your network connections. Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled. Click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow Question / Exclamation mark ? ! or a Red X you will need to update/reinstall the driver for the device Make sure you Ethernet/internet is enabled in bios. Restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals look for SiS On Chip Pci Device press Enter make sure its enabled then recheck the driveri t should be there k the driver it should be there make sure its enabledPci device arrows key scroll to nstalled if you computer came with a motherboard disk the driver could be on it or this disk provided by your ISP provider Internet Service Provider or you might have to download one http://download.cnet.com/wireless-atheros-ar5b91-7/3000-2112_4-202570.html http://download.cnet.com/Realtek-RTL8139-Family-PCI-Fast-Ethernet-NIC/3000-2112_4-91313.html if these packages are not the right http://download.cnet.com/2000-20_4.html On the home page you should see a search tab just type in what you are looking for tick in the box for windows software or all software box IE: Motherboard name Wireless or Ethernet driver you might have to try a few times to get it right
Hope this helps.
Jan 23, 2013 | Computers & Internet
Can not connect to the internet because no ethernet driver
you will have to open up your network connections click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark you will need to update or install the driver or it could be firewalled
click start control panel administration tools computer management device manager look for network adapters + expand Ethernet driver if you see a yellow question exclamation mark or a red X you will need to update/reinstall the driver for the device
make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to press to enter set up (BIOS) press and hold that key to enter bios using arrow keys scroll to intergrated peripherals
look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its enabledimake sure its enabledPci device arrows key scroll to nstalled
hope this helps you
Oct 19, 2011 | MSI K8N NEO2-Platinum (MS7025) Motherboard
I have a Canon with a USB connection. Can I connect this to a Ethernet connection on my wireless router? (I had it working thru USB port of apple airport router, but new Verizon FIOS wireless router does...
You might have to uninstall the printer restart your computer then reinstall your printer
click start control panel administrive tools computer management device manager scroll to ports(COM&LPT) + to expand you should see a communication port and Ecp printer port you might see a yellow?question mark this will mean you need to install a new driver for this device right click you will have options to update driver,disable,uninstall or select properties again you will have the similiar options also you can troubleshoot the device
hope this helps
dont forget to vote
Feb 27, 2011 | Canon PIXMA MP600 all-In-One InkJet...
My wifi does not work it doesnt allow me to search for wifi in the area the only way i can get enternet is if i connect it to the Ethernet
click start and right click on my computer click manage click device manager click network adapter this is the network device right click device and uninstall connect it to the Ethernet restart computer windows should find hardware and install it. Then check for windows update
Jul 27, 2010 | Computers & Internet
How can i connect a toshiba runniung windows me. to the internet via ethernet cable? is it possible with just the cable and no card? is there a programe i can download to help my laptop? what can i do?
It should have a LAN (network card) built in to the laptop.
First of all make sure you have the LAN (network drivers) installed. You can do this by checking in device manager.
To open device manager click Start, point to Settings, and then click Control Panel.
Double-click the System icon. Click the Device Manager tab and look in the list for network adapters/controllers.
If the driver is installed you should be able to directly connect the ethernet cable to your laptop.
I'm not quite sure where the ethernet port is on that particular laptop but it will be on the back or sides of the unit and it will be the only port the ethernet cable fits into.
From there you should be good to go, if you can't get a connection reset the modem by removing power from it for 2 minutes, connect the power again, wait another 2 minutes for the device to settle and try the internet connection again.
Regards.
Oct 01, 2009 | Toshiba Satellite 1715XCDS...
Cannot connect to internet thru ethernet jack on computer
It could be. Check your Device Manager and make sure the device isn't disabled. Also each adapter has its own TCP/IP settings so make sure yours on your ethernet adapter are set the same as your USB adapter that is working. If it does turn out to be bad you can always add a new ethernet card for cheap.
Jan 05, 2009 | Dell Dimension E521 (D10E16) PC Desktop
Acer 5100 lost dvd/cd drive
Is the DVD drive listed in device manager under CD/DVD drives at all? If so, remove it and reboot. Windows might be able to re-detect and reinstall the drivers for it, but odds are the drive is bad. You can try removing the drive from the computer, and use compressed air to blow out the area where it connects to the laptop. Also check the connection on the DVD drive to make sure there isn't any physical damage, bent pins, etc.
Hope this helps - remember to rate!
Sep 30, 2008 | Acer Aspire 5100 Notebook
The ethernet port is not working, and the network card is not being detected in device manager
Hi
My system Network adapter is not working. so i checked another one external card connect , at the time internal card automatically worked? how ? pls tell me i am very confuse
Feb 10, 2008 | HP Pavilion dv6000z Notebook
Intel 3945ABG (WM3945AGM1WB) 802.11a/g/b Wireless Adapter Logo
283 people viewed this question
Top Intel Computers & Internet Experts
Alun Cox
David
David
Computer Links
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
