Question about GE / GFSF6KKYBB
Loud fan. On ge French door refrigerator where is it located
jgwhomeequip
  • 1902 Answers
SOURCE: Refrigerator is getting no power
Check the relay and the compressor with a volt meter. Make sure that you are getting proper voltage. 110 - 120 volts at both the relay and the compressor. If nothing happens or everytime you try to test and the circuit keeps popping first check for bad wiring make sure nothing has come loose. If all the wiring checks out including the ground then the only thing that will pop a circuitbreaker is a bad compressor meaning it is drawing to many amp and you will either need to have a company replace the compressor for around 600 dollars or get a new unit
Posted on Feb 21, 2009
Sea Breeze
  • 4655 Answers
SOURCE: GE Profile Knocking
Unplug and closely examine the area for a loose fan blade or anything that may be causing the noise. Better now than to get damage that could be prevented. Let me know what you find, Thanks, Sea Breeze
Posted on Mar 23, 2009
  • 5 Answers
SOURCE: there is a loud knocking noise from inside or the
This is normal. It is the actuators adjusting the temperature between the freezer and the fridge.
Posted on Dec 21, 2009
SOURCE: Temperature display lights do not
I have the same problem as well, although the temperatures seem to be holding, you just can't read them.
Posted on Dec 30, 2009
SOURCE: GE Profile Refrigerator door latch broken
I need a door latch for a 1932 GE refrigerator
Posted on Apr 25, 2011
GE Profile French door not cooling 70degrees
The thermostat allows power to flow through to the compressor, evaporator fan and condenser fan. If the cooling system fans and compressor are running, but the refrigerator or freezer is not cooling correctly check for an airflow or defrost system problem.
in other words is there ice frozen all inside if so unplug and take a hair dryer and melt the ice thouroghly
GE Profile French door not cooling Google Search
Feb 04, 2018 | GE Refrigerators
GE Profile refrigerator Model # PFSF6PKXCWW motor is noticeably louder
if you are talking about the motor in the freezer the ice build up could be causing the fan to beat against the ice... could be a defrost cycle problem,,,, if ice is building up on rear freezer wall you have a defrost cycle problem and the ice is forminf around fan causing fan blades to hit the ice (loud noise)
Aug 28, 2014 | Refrigerators
Loud buzzing from samsung french door fridge
Hi Debbie , sound like the evaporater fan blade is hitting the ake the back panel of the inside of the freezer and with the refrigerator off take off the blade and put back on . If that doesn't help replace the fan motor and blade . GOOD LUCK APPLIANCES R EN
Apr 28, 2014 | Frigidaire Professional 27.8 Cu. Ft....
French style GE refrig. Sounds like a fan is making noise from the back of the refrigerator section. stops when door is opend. Starts a few seconds after door is closed. Very loud.
FREEZER FAN MOTOR MAY NEED REPLACED. THE EASIEST WAY IS TO TAKE OFF THE BACK PANEL IN FREEZER AND REMOVE THE FAN
MOTOR, TAKE IT TO THE NEAREST APPLIANCE PARTS STORE WITH YOUR MODEL NO.
EASY JOB.
I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
need more help go here:
http://www.applianceaid.com/procedures.html
MORE TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Sep 19, 2011 | GE Profile PFCS1NJWSS Stainless Steel...
Fan is making a loud noise. When I open the door, the fan stops.
Here is a tip that I wrote about refrigerators and the fan noisethat they develop sometimes...
RefrigeratorFan Noise
heatman101
Apr 23, 2011 | Samsung RF265AA Bottom Freezer French Door...
My Ge profile refrigerator is making a loud fan noise what is causing it?
Ice is built up and hitting the fan...
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 27, 2010 | General Electric Profile PFSF5PJX Bottom...
Loud buzzing sound. warm fridge and freezer
Could not find info for the model listed could it be PFS22SBASS...any way the most common reason for your issue is the main motherboard part #WR55X10942
prices vary $180 - $200. The circuit that operates the compressor is most likely at fault. Most boards are located at rear of unit lower right, it controls all refer functions. Not hard to instal,l but due to the cost most electrical parts bought are not returnable.
Ric
Mar 09, 2010 | GE PFS22SBSSS Stainless Steel French Door...
Loud buzzing/rumble when running
Try this website "appliance partspros.com" You enter your model numer and the have compete breakdowns with pistures and how too instructions. the best part is if you join the websites blog......there you ask questions and an expert appliance reapir person sends you a reply. I have used the website for a few years and have never been steered wrong.
Jul 22, 2009 | GE Profile PFSF6PK Bottom Freezer French...
GE French Door 22 cu ft (PFSW2MIXSS). Loud buzzing from behind the freezer. Ceased cooling.
The model number you post appears to be incorrect.
The buzzing was from the evaporator fan blade hitting on some ice build up. Getting to it on a bottom freezer refrig is a bit of a pain in the back side. If your model has a pull out freezer drawer, that has to be removed, the icemaker removed, one side of the drawer supports from the freezer wall, all to allow you to remove the back wall of the freezer to get to the fan. You may be able to just thaw out the fan and surrounding area then which will get your refrig cooling again, if the ice was just around the fan area. On the pain in the but repair scale of 1 - 10, this one rates at least a 7.
May 30, 2009 | GE PFS22SBSSS Stainless Steel French Door...
Comppresor stoped working
Go to the back of the machine and take the lower rear plate off. Taking this plate off will expose the compressor. Check to see the compressor is humming or is hot. If niether take off the relay (located on the side of the compressor) Shake it and if a loud rattling noise is heard replace it. If no rattling noise or the compressor is hot or humming then the compressor is bad.
Jan 15, 2009 | GE Profile PFS22 33" Artica French Door...
GE / GFSF6KKYBB Logo
97 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Ilia Bichin
