Question about Fusion FUS42DVD TV
Auto scan is not working - Fusion FUS42DVD TV
New GPX TV is stuck on Auto Scan.....Help
Make sure the antenna is connected properly. If that does not work and it is new. Take it back where you bought it.
Oct 17, 2017 | GPX Televison & Video
Auto scan not working??
Make, model, and year please.
Jan 22, 2016 | Televison & Video
What do I do to get auto scan to work?
The scanned programs is not storing. Check and replace its main system control memory IC. Contact any service technician.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 14, 2014 | Televison & Video
It ask to please run channel auto scan
just press the key that displays on the screen when it ask run channel auto scan or go to menu and channels find auto scan then press enter
Aug 26, 2012 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
When setting up a new TV, it keeps telling me to "Please run channel auto scan." But it also states that if I sellect Cable/satellite, that the tv does not need to run the auto scan. When you...
you need to select cable from off your remote and run the auto scan.even if it says you does not need to run auto scan still run the auto scan.good luck.
Sep 25, 2011 | Dynex Televison & Video
How do you scan the channels on the PDH42L40? I need to go to a certain channel on the TV to get my Dish Network to work. It is not hooked directly into a box, it is on a secondary receiver. Please...
hello and good day to you!!!!
if you wish to scan your TV to go for a certain channels..
you need to reset auto scan on your TV...
this are the procedure on how to reset auto scan...
  1. Get your remote control..
  2. press the menu button on your remote
  3. go to the settings..
  4. try to find the auto search.
  5. after you find the auto search press enter to scan the channels.
Note: Please complete the 100% scan for better results..
Jul 12, 2011 | Televison & Video
I just bought a sanyo dp42841. I used to have the same tv in a smaller size. The first tv was hooked up to the cable and worked fine. When I attached the same cable to the new tv it's not able to find...
Be sure your cable is hooked up good and if you did not auto scan you must do this (auto scan) Found in the menu setup. Use the remote and press menu and it is usually found easily. Highlight the auto scan and start the scan usually by pressing volume +
May 20, 2011 | Sanyo 42 in. LCD TV
It shows an ABS light and check engine soon light but mechanics say everything is ok
HAVE VECHICLE SCANNED I HAVE SEEN IF ALTERNATOR VOLTAGE OUTPUT DROP TO 11.0 VOLTS THAT WILL CAUSE ABS AND CHECK LIGHT TO COME ON.DRIVE BELT COULD BE SLIPPING.BUT TAKE CAR TO AUTO ZONE OR ANY AUTO PARTS STORE THEY WILL SCAN CAR FREE TO SEE WHAT CAUSING CHECK ENGINE LIGHT TO COME ON.ANY TIME WARNING LIGHTS TURN ON SOMETHING WRONG WITH CAR.IF AUTO ZONE OR AUTO PARTS CANT SCAN FIND PROBLEM TAKE CAR TO DEALERSHIP LET THEM SCAN VECHICLE.BECAUSE WHEN ABS LIGHT COME ON ABS BRAKE SYSTEM NOT WORKING THE ABS UNIT IS PART OF THE MASTERCYLINDER WHICH IS THE PART MAIN PART BRAKING SYSTEM.
Nov 03, 2010 | Infiniti G Cars & Trucks
After auto scan, channels are not being displayed
Yes try factory reset if still not working make sure in the country
Oct 26, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Epson CX4200 scanner
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan.
Jul 10, 2008 | Epson Stylus CX4200 All-In-One InkJet...
Fusion FUS42DVD TV Logo
21 people viewed this question
Top Fusion Televison & Video Experts
Lawrence Oravetz
ray gallant
Are you a Fusion Televison and Video Expert? Answer questions, earn points and help others
