Won't boot up and not recognised when connected to PC
I tried to upgrade Maxian M800 player's firmware. part way thru got interrupted. now player doesn't boot up nor recognised by PC (running XP). Maxian is Korean. Their English version of the website is a piece of ****. Would really really appreciate someone helping me to resolve problem.
Many thanks
    Problem Solver:
MANUAL FIRMWARE UPGRADE PROCEDURE:
During the upgrading of the firmware, if you turn off the power of M800, either by manually switching off the power or removal of the battery, the file system of M800 will be damaged, which will lead to booting failure problem. When this happens, you will not be able to turn on M800. Booting failure problem can be easily repaired by “manual firmware upgrade”. The procedures for manual firmware upgrade are as follows:
1. After firmware upgrade, only the blue LED under LCD is on, but LCD display is not turned on, please proceed manual firmware upgrade.
2. Remove the battery.
3. Put the battery back into the player again.
* Notice ! : Do not turn on the power.
4. Connect the player to your PC.
5. While pressing the volume down button, power on the player.
6. Now PC should recognize M800 as one of its hard disks.
7. Download the latest firmware file into the root folder of the player.
8. Disconnect the player from your PC.
9. The blue light LED under the LCD display will flicker.
10. Wait for about one minute, blue LED is off. Turn on the player.
The manual firmware upgrade is now completed.
Posted on Jan 05, 2009
Hello, i have the same problem and i made everything you said but still the PC dont recognize the PMP, please help me!
Posted on Mar 10, 2010
I reset my samsung sgh t109 phone but it dosent accept card
the memory card should have been formatted before use..try to format it in pc and then connect it.. Use FAT 16/32..if it gets recognized in PC after formatting but still your phone is not recognising it then try to UPGRADE your phone Firmware. .
Use PC SUITE to upgrade/reinstall the FW.
any interruption in FW installation my brick your phone so be careful.
Feb 28, 2011 | Samsung Cell Phones
I reset my phone but it dosent accept card
Philips DVDR3450H. How format the HD?
Found a document DVDR3450H_3452H_3460H_eurp FWUpgradewk635.pdf Describes procedure of firmware update and disc formatting. Some cut'n'paste from the document:
2. Preparations for new HDD
In the event when the set unable to boot up or recordings not stored due to an defective HDD, the HDD will have to be replaced with the steps describe below:
1. Replace the Faulty HDD with a new HDD.
2. Before connecting the new HDD on the Digital Board ,the jumper pin at the connector of the HDD is to be removed.
3. Connect the new HDD to the Digital Board.
4. Power up the set . It will open the tray and prompt to load the upgrading disc.(the upgrade disc is
the same disc under firmware upgrading.)
5. The set will display
“Load”.
6. Put the upgrade disc and close the tray and the set will show
“Copy” ……… “Boot”
7. The rest of the procedure follows the software upgrade given in 1B -Procedure to apply the firmware upgrade.
*Note : 1)Do not press any button or interrupt the main supply ,otherwise the set may
become defective.
2)When the HDD formatting is successful ,the set will go to standby mode.
Jan 17, 2010 | Philips DVDR3450H DVD Recorder/HDD...
It says boot error shutting down and my pc won't recognise it
I have also had the same problem. Go to Google mail and type "MMP8567 boot error" in the search. You will get results where there is links to get the firmware. Especially, from FixYa. Down load the firmware and install it in your PC. Then it will format your player and install the new firmware. Your recorded songs will be lost.
Sep 06, 2008 | Memorex MMP8567 MP3 Player
CANT TURN POWER ON
Download the firmware updater from the mobiblu site
Install the software, connect the player via the USB cable, set the switch to hold and run the updater. When it is finished, stop the device and disconnect it. When you power up, it will be back to factory settings (any data/music will be erased).
Aug 12, 2008 | Hyun Won mobiBLU DAH-1900 MP3 Player
Iriver h10
This is straight out of p. 67 of the user's manaul, available on iRiver website (it may not work if the computer does not recognize the device):
Initializing H10
67
Additional information
Firmware upgrade
66
What is firmware ?
It is the operating system that works in the H10.
iriver provides you with the latest and best features through Firmware upgrade.
You can choose manual or automatic upgrade function.
For information on automatic upgrade, refer to the iriver plus instruction manual.
Manual firmware upgrade
Select [Option - Firmware Upgrade] from the menu in iriver plus.
Do not disconnect H10 during firmware upgrade.
Internet must be connected for the "Firmware Update" function.
Change to "Player must be connected to the PC for Firmware Upgrade function.
Note
Please initialize H10 player in the following cases.
All music, pictures, text, and data will be erased from the player during this initialization.
- if there appears to be corruption on the internal hard drive.
- if an error message displays and the player doesn't boot properly.
1 Connect the player and PC using the cable supplied with the player.
Open iriver plus.
Select [Option-Portable Device Initialization]. 2
Click [Start] to begin initializing.
Initializing H10
A
A
B
B
May 30, 2008 | iRiver H10 MP3 Player
Zen vision m firmware problem
Dear All this problem is caused if the computer has windows media player 11 installed. I googled this for days trying to fix it - & was relieved when i finally sorted it - it's very easy. Just do the following.
Use a computer that has XP (either pro or home edition) (forget about vista....). go to add/remove programs - uninstall windows medi player - on my PC it does a roll back to WMP version 9. There's also a program called "Windows media format runtime 11" which comes with WMP11 & you need to uninstall this too - otherwise it still won't recognise the player.
Then restart your PC. Then make sure you have downloaded the lastest firmware version - just google it - trying to find the right one on the creative website is not easy - their website is poor - there are quite a few other places you can download it from.
Then I clicked the "reload firmware" option in the recovery mode (I had already deleted it 4 days ago). Then when your PC has restarted plug in your Zen, it should come up something like "MTP device recognised". Now when you double click on the firmware downloaded to install - it it will recognise the player & you can click the upgrade button. It does the upgrade & puts the firmware back on the ZEN. I got a message saying "firmware upgrade failed" at the end although when I started the player - it booted up as normal & I was able to reload & play my music.
This sure beats the "send it back to John Lewis, pay 60 quid & wait 6 weeks for it to come back " option - if like mine it's out of warranty
Feb 17, 2008 | Creative Labs ZEN Vision:M Digital Media...
System initializing
Initializing H10
67
Firmware upgrade
66
What is firmware ?
Note
Open iriver plus.
Initializing H10
Dec 18, 2007 | iRiver H10 MP3 Player
Usb connection issues
its not your computer its the firmware you can go to samsung .com and get a older version of the firmware and put it in yourself you might haft to put it in the wma only mode to do this
Apr 25, 2007 | Samsung Yepp YP-Z5AB / YP-Z5AS MP3 Player
421 people viewed this question
 Grubhead
Grubhead
