Question about Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
Spa goes to drain mode when in spa mode - Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System
    Top Expert:
  • Jandy Master
  • 8,688 Answers
Make sure actuators are on and on the correct number and that the handles are locked in
Posted on Jun 07, 2015
3 Suggested Answers
  • 368 Answers
SOURCE: Spa won't heat unless in spa mode, and if it is in
On the automated valves there are tiny switches on one end or under the valve actuator. When you switch to the spa mode the suction valve should should move to fully block pool drains. The return valve should fully block the pipes to the pool returns and spa fountain. If one or both of these valves is not fully blocking the pipes to the pool then the tiny switch on that valve is in the wrong position or an operator is defective. The middle position of either of these switches turns the operator completely off so it cannot move. That is the position to avoid unless you want to operate it manually. One of the other switch positions caused the valve to move in one direction and the other switch positions causes the valve to move in the other direction. If you set the switches so when in the spa mode water is circulating only in the spa then you have the valves in the right position. Next, place the system into the pool mode. Both valves should move to the other position. If not then the valve operator that doesn't move has a problem. It could be the operator, the wiring, the control panel or a stuck valve in that order. All of this sounds complicated but once you know how the operators should act when you flip those tiny switches and how the valves should act when in the spa and the pool mode then getting the switches set right is simple. I hope this helps.
Posted on Aug 08, 2011
  • 11 Answers
SOURCE: spa drains when turned on
The problem is in your plumbing. Someone put a valve in an incorrect position. I would have to see a picture of your plumbing but if you can follow the flow of water. When you put it in spa mode, look at which valves turn and which ports open up. If it is doing anything other then sucking water from the spa and returning it only to the spa, then that is why it is draining. Again it would be great if you had a picture. What I have seen before is somebody plumbing in the pipe for a pool cleaner after the valve that send water to the spa. This would result in water from the spa slowly draining out of the pool sweep line. Good luck.
Posted on Jan 28, 2009
I have a Jandy Aqualink pool system. When I turn on the spa and heater, the spa drains..I've never had this happen but don't use the spa much. What should I check?
His is not typically a control panel issue but more likely a valve issue.
Your valves are set as follows wih a few minor variations.....
Pool mode- sucks from pool skimmer and or pool vac line and returns water to both the pool and spa.
Spa mode - self contains the spa , meaning water is sucked from the spa and returned only to the spa.
If your spa is draining then most likely one of your electronic valves is failing...most likely it's the return valve so what is happening is the water is sucked from the spa and returned to the pool instead of self containing the spa.
Easy check is to be next to the equip when spa mode is selected and two valves should move and align properly, the return side valve is most likely not moving or it is not moving into the correct position.
The fix is either adjusting the valve acuator or buying a new valve acuator.
Another thing to check is on the main panel circuit board to ensure the return and auction 3 pin plug ins are still connected.
Apr 05, 2015 | Jandy Aqualink Rs4 One Touch Control...
How do I turn on the spa on AquaLink rs8
go down on controller to equipment highlight it will give you all your equipment pool mode spa mode then make sure your pool and spa heat is activated if you want it to be heated hit the button once then it goes to a 10 minute safety shutdown before the other mode comes on
Jul 24, 2014 | Jandy AquaLink RS OneTouch RS8 Pool or Spa...
Viking spa
Check to see what mode the spa is in. It sounds to me like the spa may be in the Economy mode.
If you can check to see the mode you spa is in...you may need to change the mode back to standard mode and that will allow you to change the temperature.
us parts center
Sep 22, 2013 | Pool & Spa
My viking spa is in sl mode and not heating
It is in sleep mode, press the "temp" button then the "light" button, to change modes, ST will be your standard mode.
Apr 03, 2013 | Pool & Spa
I have a pool with a built in spa and I need to Isolate the spa from the rest of the pool. So I can heat it and not the whole pool. I don't know how to add pics so I will describe the best I can. I have 2...
the actuator at the intake of the pump divides spa intake and the pool intakesmake sure switch on actuator is on 1 or 2 if in pool mode the off should be at spa intake the out inpool postition the off should be to the spa outlet
Feb 18, 2011 | Jandy Pool & Spa
I want to heat the pool from the spa. I have the spa and spa heat on but the spillover wont come on when I have the spa on. When I turn the spa off the heat goes off. What do I do
When your system is put into Spa mode the system draws water from the spa only to the heater to keep the spa at temp, this is why the overflow doesn't work and why you can not heat the pool in spa mode. If you could heat the pool this way it would take a very long time, since the spa is smaller then the pool. You can heat the pool and spa at the same time in pool mode. Water is pulled from the pool, heated and goes back into the pool and spa.
Mar 27, 2010 | Jandy AQUALINK RS TELELINK KIT
Spa drains when turned on
Jan 26, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Jandy Aqualink - Rs24 One Touch Pool / Spa Combination Control System Logo
87 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
