Question about Quantum 24 TB DXi7500 Hard Drive Array
Failed hard drive Quantum DXi7500
I need the CLI for replacing a failed hard drive in a Quantum DXi7500
2 Suggested Answers
gripfitter
  • 557 Answers
SOURCE: I want to replace my dead hard drive with a
No. Ther is no driver needed.
Posted on Dec 08, 2009
Quantum Fireball LM30. I can see the drive in device manager and the disc is spinning. It doesn't show up in file explorer. I am running XP
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up a computer hard drive
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your "((MOTHERBOARD TO YOUR HARD DRIVE))" make sure they have a secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty even the electrical extensions or just replace them they could be faulty a computer needs its connections to continue its cycle and have an end so any faulty leads will end up with a computer error even something as small as a faulty electrical extension or fan lead can cause this problem
follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every device and to have an end to be able work properly
a motherboard and a hard drive any leads between them will fail before your motherboard or your hard drive if its a flat ribbon 40 pin type IDE replace it this will be the first to fail check all electrical extensions make sure they are securely seated even the cd/dvd floppy drives need to have current go through make sure these drives are working
hope this helps
Jun 03, 2011 | Quantum Fireball Plus LM 30 GB ATA-66 Hard...
SMART Failure Predicted on Primary Master QUANTUM FIREBALLP AS20.5 Arturo Sghedoni
This error message is a warning that the hard drive may fail in the near future. It is advisable to backup your data frequently so that when the hard drives fails you will not lose your data.
Oct 14, 2010 | Quantum Fireball (LM20A011) 20.5 GB Hard...
Different WIndows operating systems on two hard drives
main Dell Optiplex
Slave (cable select)
Quantum Fireball
once you have installed them physically into your comptuer like that, start it up.
Format Quantum Fireball
Now you still have windows xp, and you have a clean 2nd hard drive.
You do not need to install windows xp on the 2nd drive
Quantum Fireball .
Dec 13, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
I am looking for a Quantum Fireball 20.5 GB hard
The board alone is not available for sale. To recover the data you will need to buy a 20GB Fireball with same board and swap the control board.
You can buy a 20.GB Fireballl QMP20000AS-A from links below:
QUANTUM QMP20000AS-A - Buy Now at Cuetech, Inc.
QMP20000AS-A DELL 20GB 3.5" IDE 7.2K HARD DRIVE
Quantum QMP20000AS-A Fireball Plus 2 QUANTUM FIREBALL PLUS AS 20GB HARD DRIVE QMP20000AS-A -
Oct 22, 2009 | Quantum Fireball Plus AS (QMP20000AS-A)...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Help please to restore the failed raid
Well if your data is gone at this point, you mines well just proceed with rebuilding a new RAID 5 set with your replacement drive. Even if one drive fails in a RAID 5 set, your logical drive should still be accessible. Goodluck.
Jun 14, 2007 | Quantum Guardian 4400 120 GB Hard Drive...
Hard Disk Quantum QML20000LD-A
Hi, may I offer an alternative solution? You may want to try and replace the entire PCB assembly rather than repair. I would assume that the Quantum QML20000LD-A is a few years old and so many of the same brand/model would be lying around computer repair shops. Even if defective, these drives can be: 1) direct parts source; and 2) remove/use the entire board. You can even find this kind of HD from old CPUs (166-550 MHZ.) I believe you can get them relatively cheap and faster. Hope this somewhat helps. Cheers.
Apr 16, 2007 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Quantum 24 TB DXi7500 Hard Drive Array  Logo
91 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
