Question about Water Heaters
Draining down in winter
Draining down system for winter
  • Water Heaters Master
  • 5,245 Answers
Which type and brand water heater?
Tankless?
http://waterheatertimer.org/pdf/How-to-drain-tankless.pdf
Tank type?
http://waterheatertimer.org/Water-heater-will-not-drain.html
Boiler, solar, indirect, hybrid, combo, heat pump, etc?
Most have a drain valve.
Posted on Nov 03, 2012
I NEED THE MANUAL FOR THE SUNNYBROOK 276 FWSCS! WE CAN'T FIND THE HOT WATER BY PASS VALVE TO WINTERIZED IT!
Winnebago bought sunnybrook ... contact them ...
For example the valve(s) might be below a bed ....
Drain plugs on outside behind the service door...
Sep 26, 2017 | Water Water Heaters
Boiler,heating and water all working OK but manual override to turn heat on before preset time caused dripping under boiler.Cause and solution?
Did the boiler winter over with the heat turned off and no winterization? If so, then the boiler may have frozen and cracked. Replace it.
If it WAS drained down and winterized, and you just filled it with cold water before firing it, it may be condensation.
May 05, 2017 | Water Water Heaters
I'm going on 2 month vacation during ny upstate winter. I'm shutting off all water at the main house inlet. Rather than emptying my gas water heater, I'd like to keep in in "vacation"mode. Will that work?
Since it will not be boiling it will not lose any water, however I would be concerned about the low temperatures allowing mold or Legionnaires in rare cases to grow, I would call a local plumber for their opinion as to drain or not for your area.
I would drain it and leave it open at the drain and the T and P valve if possible.
Jan 10, 2015 | Water Water Heaters
We have a Bosch AQ125BNG gas water heater. The pilot goes out in the middle of taking a shower and has to be relit. We have had this problem for a couple of years, but it only happens during winter months...
The problem is excessive down draft or condensation. Air flow is important in combustion appliances. Too much airflow down the chimney can blow the pilot out. This is readily apparent when it gets cold and there is air rushing down the chimney in the winter. There may be an air leak in the room with the water heater. While there should be a combustion air supply that is sufficient, there should not be a place for the air coming down the cold chimney to go. That would eliminate the draft. Another thing is if a furnace is in the same room and does not have enough air to supply the burners. IF it is an older furnace without a combustion exhaust fan or has its own flue, the air being drawn into the furnace burners may be blowing the pilot out. Last but not least is the condensation issue. When cold water enters the tank it can cause water to condensate on the outside and drip down into the burner and put the pilot out.
Jan 29, 2018 | Bosch AquaStar Indoor Natural Gas Tankless...
How do you winterize Model GE20P06SAG? There is no drain at the very bottom...?
Thank you for including model number for EZ identification of water heater
To drain tank without drain valve: Remove TP valve at top of tank and siphon out the water. Then reinstall with correct pipe configuration shown in product manual.
Product manual shows drain valve is not supplied with this unit.
http://waterheatertimer.org/pdf/GE20P06SAG-under-counter.pdf
Product manual shows the Installer should add both shut off valve and drain valve on cold water inlet line.
http://waterheatertimer.org/images/GE20P06SAG-under-counter-60.jpg
More resources:
http://waterheatertimer.org/How-to-install-under-counter-water-heater.html
Sep 30, 2012 | RELIANCE 19.9 Gallon Electric Compact...
I have a Park Model RV with a Rheemglas Fury model 81VP205 with no bottom drain. How do I drain the water heater to winterize for the cold Northern Winters?
Make sure it's off (hydro) and open drain at cold line going in bottom wherever you find a drain (usually close to it) going down through floor and outside under trailer. Follow cold line back until you see a line "T" and one line going down under trailer, and open it up underneath. Then open pressure relief valve at top of tank to allow for faster draining .
Oct 14, 2011 | Water Heaters
How do you drain the Ariston GL4
is there a pet **** on the bottom under a plastic cap? you might have to take the cover off and I would recomend putting some boiler drains in the line for future draining,, all units of water heaters have drains and looking at the picture I see something sticking down on the bottom see if thats not the drain
Jun 09, 2009 | Bosch Ariston GL4 GL4 Point-of-Use...
Water Heaters Logo
65 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
