Question about Iomega ScreenPlay Plus 34499 Digital Media Player
Sorry! install screenplay fail! fill up install data fail! write Error
Iomega screenplay director firmware
Iomega i ScreenPlay Director SPDHD - Lenovo Community
forums.lenovo.com > ... > Iomega Desktop Network Storage
Nov 16, 2013 - 5 posts
Hola, tengo un iomega screenplay director y hasta ayer me ... aqu?: Versi?n 1.4.0.92 del firmware de ScreenPlay Director: Leer primero Iomega Screenplay Director HD doesn't work on TV
Mar 15, 2015
Firmware Iomega screenplay HD500
Feb 9, 2014
How to find, download and install firmware on my i...
Jan 14, 2014
Iomega ScreenPlay Director error 12
Jan 10, 2014
More results from forums.lenovo.com
Dec 25, 2015 | Iomega ScreenPlay Director 1TB HD Media...
I formatted the screenplay director hd drive and just have a screen saying :sleeping waiting for usb keys:
ScreenPlay Director Partitions
There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files.
The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection.
The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface.
Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
************************************CAUTION!************************************************ Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
Conclusion: If you have deleted or formatted any of the first 4 partitions on the unit that is not the data partition. You now own a BRICKED ScreenPlay which HAS to be replaced. No if ands or buts about it. YOUR DEVICE IS DEAD.
Dec 19, 2010 | Iomega ScreenPlay
Screenplay plus partition not found ok so whenever i turn on my screenplay plus it just gets a partition not found error
1. download firmware update
2. create partition and format to ntfs
3. update firmware, when finish connect to tv it will still say partition not found just wait a while
for installation to begin. after installation finish everything will be working
Nov 24, 2010 | Iomega ScreenPlay Plus 34499 Digital Media...
I have accidentally formatted the default partitions
*******************************************CAUTION!*********************************************************
Oct 09, 2010 | Iomega ScreenPlay
How can I format my Screenplay Director?
Formatting the Data Partition
The data partition on the ScreenPlay Director is formatted with an NTFS file system and will appear as a read-only volume under Mac OS X unless special software is installed on the Mac. If you need to transfer files to the ScreenPlay Director by direct USB connection on a Mac, you must reformat the data partition to FAT32 (see instructions below).
NOTE: On a network connection, Mac OS will see the ScreenPlay Director as a shared SMB volume. This means you can use the network to copy files from a Mac to the ScreenPlay Director without changing the format from NTFS to FAT32. (Recommended if available.)
If you reformat the ScreenPlay Director data partition for use with a Windows PC, it is recommended that you use the Windows format utility to reformat with NTFS. Right click on the drive letter for the data partition and select Format.
CAUTION!
  • Do NOT change the partitioning on the ScreenPlay Director as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition can be viewed or played on a TV.
  • Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
May 19, 2010 | Iomega ScreenPlay
I deleted some of the partitions and now the
ScreenPlay Director Partitions There are five partitions on the ScreenPlay Director's hard disk. Three partitions are grayed out and will list as "Healthy-Unknown" in Windows Device Manager. These partitions contain the ScreenPlay TV interface and system settings and are not available to store media files. The two active partitions both appear as "Untitled". The larger partition is formatted with an NTFS file system. Use this partition to store your media files when you connect to the ScreenPlay Director from a networked computer or transfer files via direct USB connection. The smaller partition is formatted FAT32 and is used only when updating the ScreenPlay Director firmware. Do not place your media files on this partition! If you accidentally store media files on the FAT32 partition, you can use a computer to move them to the larger NTFS-formatted partition. You will not be able to see media files on the FAT32-formatted partition when using the ScreenPlay TV interface. Formatting the data partition will erase all existing data! If you have files on the ScreenPlay Director you want to save, move them to another drive or volume before reformatting.
*******************************************CAUTION!********************************************************* Do not change (format or delete) the partitioning on the ScreenPlay Director hard disk as this will remove the firmware that enables the ScreenPlay Director to communicate with your TV set. Only media files stored on the active data partition (the largest partition) can be viewed or played on a TV. The ONLY partition that can be formatted is the data partition (the largest partition).
May 06, 2010 | Iomega ScreenPlay
I have bought a IOmega Screenplay Pro 1 TB. I was able to see some partition in the HD. Accidentally all these partition were removed. So i need to create those partitions and the size details of each...
Feb 22, 2010 | Iomega ScreenPlay
Iomega Screenplay Pro HD - No Menu
I had the same problem with the Screenplay Pro HD. My Iomega was working fine and one day after exchanging files with a friend I got the logo, then the loading message and then it went into a black screen while the blue light kept blinking.
Obviously the connection to the TV was fine because the logo appeared.
I solved the problem by downloading and reinstalling the firmware.
I downloaded the firmware from the iomega web site.
Notice that during the installation process you get the message that it will delete your data and then shortly after you have the option to delete or keep it. Hang in there. This part is a little nerv wrecking.
Hope this helps.
Rainer
Jul 10, 2009 | Iomega ScreenPlay
No matter what type of disc I insert, including store bought movies...player says ''does not recognize disc''
Mar 15, 2009 | Televison & Video
Iomega ScreenPlay Plus 34499 Digital Media Player Logo
276 people viewed this question
Top Iomega Audio Players & Recorders Experts
juanmireles1
Tom Chichester
Are you an Iomega Audio Player and Recorder Expert? Answer questions, earn points and help others
