The charging light is on but i push the power button and it wont come on? What could be the problem
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you. Just like you sometimes need a mechanic to repair your car, sometimes you do need a technician to diagnose and identify the fault or faults on your computer. Not only does a good service technican have the experience to deal with this type of problem, they also have the equipment that allows them to look at things the average computer user can't see, and he has a collection of replacement parts that can be used to quickly test individual components on your computer.
SOURCE: charges battery, but will not power up when button pushed
Check battery condition: double click on battery icon in Power meter.
Change battery if battery is than 3 years
SOURCE: push power button and it wont turn on on my
try charging the battery again and take the battery out and put it back in. the only other thing is the on/off swich has broke?
SOURCE: my hp pavillion dv1000 wont turn on
Problem with your charger, try this :
1. Check whether the charger plug is properly inserted in the Power port/jack of your Laptop!
2. Check the power cord (any cuts OR torn-out)!
3. If above steps don't work, replace your charger.
SOURCE: my aspire one acer notebook
Hello.
The most common reasons for power issues are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement. If a power jack problem, it should be addressed by someone knowledgeable.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
SOURCE: My laptop wont turn on and yet its fully charge.
Hi.
This sounds like there is a problem with the battery.
Remove the AC mains power and take out the battery from the laptop. Plug AC power back in and try booting the laptop up.
If it boots up let it boot into Windows/linux and then shut the computer down as normal. Remove AC power and re-insert the battery. Plug AC back in and power it up, see if it does the same thing. If it does the same thing the battery is faulty. If it boots up with the battery in then there was a glitch.
Regards.
How old is it?
