Question about Zanussi ZHQ575 Electric Double Oven
Zanussi cooker zpb1260x is on safe mode how do i get it off!?
The cooker has been on safe mode the last couple of days i have tried turning the oven of for a while but it still is'nt working!!!ihave lost the manual and would like to know is there anyway i can fix it myself
5 Suggested Answers
  • 236 Answers
SOURCE: Cooker power has gone.
has it come back on? if not it may be a connection going into the back of the cooker or if it has come back on it may be an overheat stat kicking in -check the blower (cooling) fan is ok.
Posted on Mar 16, 2008
barkencoa
  • 3463 Answers
SOURCE: fan oven on zanussi electric cooker does not heat up
From symptons, I would say the fan oven element is faulty, more so if the fan is working. Remove inner rear panel of oven and see if element gets warm, let it run for a minute, switch off and feel if element is warm, if not, then replace.the element.
Plz rate this solution.
Thanks.
Posted on Dec 27, 2008
barkencoa
  • 3463 Answers
SOURCE: bottom oven stopped working on my zanussi built in
If it is a fan assisted oven, and the fan is working o/k , then it is more than likely the oven element has failed.this is located at the rear of the oven behind a removeable cover.
Hope this helps.
Posted on Jan 10, 2010
barkencoa
  • 3463 Answers
SOURCE: i have a zanussi cooker model no zcg7690xn and the
Yes it is easy enough to replace, simply grasp the knob firmly, and pull it towards you, it should come off o/k.
Please rate my solution.
Thankyou.
Posted on Jan 13, 2010
THE GRILL ON MY ZANUSSI ZXC662GXC COOKER WILL NOT STAY ALIGHT
you will need to contact your local Gas Safe service engineer, you are not permitted to repair this yourself. check the Gas Safe website to find your local service engineer.
Sep 03, 2016 | Zanussi Ovens
Glass door for top oven
Really bad but how we are supposed to help you? Find a shop where they sell parts for Zanussi ovens.
Most I can do for you is to provide you some websites selling parts for zanussi: ovens
Official Zanussi Site Parts Accessories for Appliances
Zanussi Cooker Oven Shop
Find Zanussi Spares and Accessories
Zanussi Cooker Oven Spares
Oct 25, 2015 | Zanussi ZDQ695 Electric Double Oven
Will Details about Zanussi ZCG7901XN Cooker Top Oven Glass Door fit my ZCM7901XN oven?
I think yes, because spare part number 311407328/5 of outer glass door is the same for both oven.
Dado
Mar 03, 2015 | Zanussi Ovens
How long should an igniter last on a gas cooker
depends if its a batteie or mains if battrie change when it stop working if its mains any time its light a light bulb and they cant be fixed you have to replace it 4-5 years some times but new cookers dont last long at all 2 years some times ok
Oct 17, 2012 | Zanussi Ovens
Oven will not heat up
This tutorial will show you how to check your Zanussi element and how to replace your Zanussi cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Zanussi manual.
  2. If you\'re Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
Jul 04, 2011 | Zanussi ZBF260 Electric Single Oven
I have a zanussi built in oven model no zbf 860b which the fan is still working but the oven is no longer heating up?? Thanks
If the red light is coming on when you turn on the oven control then the thermostat is ok.You will need to remove the grids from inside the oven then remove the inside rear panel 4 screws, be carreful not to damage the thermostat as you remove the panel.When you have removed panel you will see the ring element,now remove the 3 screws holding in the element and gently pull it towards you,remove the 2 cables off element but do not let them fall into the back of cooker or you will have to remove the cooker and gain access to the rear of the cooker.Once you have element check with a multi-meter for continuity and replace if blown. Relacement is a reverse of removal.
Hope this helps.
Aug 04, 2010 | Zanussi Ovens
My zanussi zbf360 will not heat up in the oven ,the fan works fine as you can hear it and the grill still works ,any ideas what it can be ,
  2. If you're Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
If this helped like us on facebook please
How to Video Tutorials on Domestic Appliances
Mar 14, 2010 | Zanussi ZBF360 Electric Single Oven
I need a new Grill Element for my Zanussi Built in double oven, Model no is FM5232
If you are in the u/k,then I suggest you go to the zanussi web site,
WWW.SERVICEFORCE.CO.UK
Altrnatively, you could try a local deaer,whoo repairs cookers etc, they often have these sort of parts in stock.
Feb 03, 2010 | Zanussi Ovens
Fan oven on zanussi electric cooker does not heat up
Thanks.
Dec 26, 2008 | Zanussi ZHQ575 Electric Double Oven
Zanussi ZHQ575 Electric Double Oven Logo
124 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
