Question about Zyxel P660HW-D1 Router
Cannot connect to internet with a mac.
I have a problem getting internet even using a direct ethernet connection to my i-mac.is this router compatible with mac? if yes,what is the procedure to follow? brian johnson
  • 192 Answers
To use eathernet on a mac you would need to change you conecsion under system profernces. I hope this would help you.
Posted on Jan 04, 2009
My linksys w/2phone ports cannot hook up with the ethernet
Most Cable Internet Service Providers (ISPs) use Media Access Control (MAC) Address authentication to establish Internet connection for end-users. MAC address is a unique identifier assigned to the network adapter/s of the computer.
To set up your Linksys router to work with a Cable ISP, you have to enable the MAC Clone feature of the router. MAC Cloning is a procedure which enables a router to copy the MAC address of the computer registered with the ISP.
To set up a Linksys router with Cable connection, you need to perform four steps using the computer that's been registered with the ISP:
i. Verifying Internet Connection
ii. Connecting the Devices Together
iii. Checking the Router's LEDs
iv. Setting Up a Linksys Router for Cable Internet Connection
Connect the computer to the Broadband modem using an Ethernet cable without the router installed. If you cannot get online, contact your ISP. If it's online, use the computer to set up the router.
NOTE: Some cable modems use the USB port. If the physical connection is via USB port, you may not be able to go online via Ethernet connection. Contact your ISP to have the Ethernet port of the modem configured.
kb17251-001_en.png NOTE: The image may vary depending on the computer and modem you're using.
After confirming the Internet connection through the modem, connect the modem to the Internet port of the router; connect the computer to any of the four Ethernet ports at the back of the router. For instructions, click here.
After connecting the devices together, check the lights on the front panel of the router. Ensure that the Internet light, as well as numbered light corresponding to the Ethernet port where the computer is connected, is lit. For further instructions, click here.
Step 1:
Access the router's web-based setup page. For instructions, click here.
NOTE: If you are using a Mac computer to access the router's web-based setup page, click here.
Step 2:
On the Setup tab, click the MAC Address Clone sub-tab.
Step 3:
Select Enabled then click Clone My PC's MAC.
Step 4:
Click Save Settings.
Step 5:
Click the Status tab.
Step 6:
Check the Internet IP Address. If the Internet IP Address has numbers, this means the router has been properly configured. You should now be able to access the Internet. If you're still unable to access the Internet, powercycle the modem, the router and then restart the computer.
NOTE: If the IP address is still 0.0.0.0, click IP Address Release then, click IP Address Renew. If this does not change the IP Address, powercycle the modem, the router and then restart the computer.
Nov 14, 2010 | Linksys WRT54GX2 Wireless-G Broadband...
My first Mac: a used Powermac G5 and I cant connect to internet
Hi Christine.
With a cable plugged in The Mac should automatically connect.
Try this. Leave the ethernet plugged into the mac and shut down the mac. Power it back up and see what happens - does the light on the router (1,2,3 or 4) come on to signify that the mac is talking to the router?
If not then I would think that there may be a problem with the ehtenet port on the Mac.
Also, open system preferences and then select network. Make sure ethernet is selected and then click on the TCP/IP tab. You should see a bunch of numbers listed - starting 192.168. or 10.0. and a line with lots of 255. If you get these and the top number differs from the bottom number then you should have a connecttion. If on the other hand you only have one line of numbers and it starts 169. then the mac is not talking out of the ethernet port at all.
If that is the case you should get someone in to look at it.
Post back and let us know what happened.
Apr 26, 2010 | Apple Power Mac G5 Desktop
I have linksys wireless-G 2.4Ghz broadband router connected to a pc. My wife bought a MAC and wants to get rid of the PC. Is the router compatible with a MAC? If so how do I download the software to set it...
Hi! Absolutely, the Router is OS independent. All you need is a computer with a properly configured Ethernet LAN adapter and a web browser to configure the Router. Any platform that supports Ethernet & TCP/IP is compatible with the router. You may need to provide additional hardware & software (i.e. Ethernet cards and/or software drivers) to ensure that all clients operate with the router.
By default of your mac computer it has already a buil-in LAN port same as your pc and it should be properly configured. just connect the cable from the mac lan port and the other end goes to your port 1 to 4 of the linksys router and it should give you an internet connection. if there is no internet access, pls check the ff:
1. Go to system preferences, network
2. It will pop up the network window
3. location set it to automatic
4. show - set it to built in ethernet
5. once you set it to built in on the lower portion it should set to tcp/ip and the ip address should show, once there is an ip address, you should get an internet connection, sabe or apply the settings
6. you are going to do the same thing if you are going to set the pc on a wireless connection.
if you have any querry pls feel to get in touch..
Aug 16, 2009 | Linksys Wireless-G Broadband Router
Can not connect to Internet wireless or through router to Ethern.
call service provider (isp) to insure they have routers mac address. I cannot stress this enough
Mar 01, 2009 | D-Link DIR-625 (790069292637) Wireless...
No internet when using router
Your modem has already registered itself with the MAC address of your computer, so it doesn't recognize the MAC of your router. In cases like this you have two options:
  1. Configure your router to clone the MAC of your computer
  2. Connect the router to your modem and do a soft reset so the modem registers itself with the MAC of your router.
Clone MAC - Go to your routers Admin web interface and on the main page you should see the "Router MAC Address" section at the bottom. Select "Use Computer MAC Address" and click "Apply" and your router should reboot and you'll be back in business.
Soft Reset
- Plug the modem into the router via the ethernet cable then do a soft reset.
To do a soft reset, do the following:
  1. pull the power cord from the modem
  2. count to 5
  3. hold down the Reset EMR button on the modem
  4. plug back in the power
  5. count to 30 while holding the Reset EMR button (the modem should be blinking a lot)
  6. release the Reset EMR button and see what happens.
Jul 07, 2008 | Computers & Internet
Office Networking problems
Where does the cable from the wall jack come from? A switch that is connected to the Internet?
For the Internet to work with router, you need to have a modem that is connected to Internet already, meaning ISP knows about the router via MAC address, and from the modem use an ethernet cable to connect router port called "Internet" or "WAN". then from an open port in back of router another ethernet cable to your NIC in back of computer.
Jul 03, 2008 | Computers & Internet
Adapters Compatible with the Westell E90-610014-06 Router?
run the modem to the router with Ethernet cable and then use one of the other Ethernet ports on the router and another Ethernet cable to connect desktop
Mar 04, 2008 | Westell Wirespeed LiteLine 6100...
Can this be used with a MAC?
Any router will work, TCP/IP is a network standard, definately double check the cables. Your DSL modem is usually 192.168.254.254. and the router is usually 192.168.1.1. Check your documentation for the default IP. Once you know it type it in to the broswer in your Mac. Before doing so connect with an ethernet cable, purchase a new one if necessary. Connect from the <--> labeled port on the mac, or ethernet port. These wires are not like phone lines, they have 8 wires instead of 4/6. The router usually has ports on the back labeled 1, 2, 3, 4, and WAN. the 1-4 ports are LAN and that is also labeled on there. Plug the mac into port 1 and any other computers in after you get internet. once the physical connection is recognized. Go to your browser in the mac and proceed. if you get a web based router configuration page your router is working, then make the WAN connection to the ethernet port on the back of the dsl mode. Be sure your cables are good. Also go to your control panel and make sure your internet is enabled in your network section.
Jan 06, 2008 | Siemens SpeedStream 2624 Router...
No Internet With New Router, Computer, or Adapter
This document is relevant if you had an Internet connection, but lost it when: * Adding a router to your network, or * Using a different Ethernet adapter card or computer than the one your ISP used during installation. Use ISP Configuration to see whether you need to "spoof a MAC address" to connect to your ISP. If so, follow the instructions in this document. If the Ethernet card that was used during ISP installation is not available, you may need to register the new Ethernet card's MAC address with your ISP for the following to work. MAC address stands for Media Access Control address (not "Macintosh computer"!), a unique number built into modems, routers and other network hardware. It ensures that one piece of equipment is not mistaken for another one. Some ISPs validate your connection by checking the MAC address of the Ethernet adapter in computer that was registered during ISP installation. If you add a router or change computer or Ethernet adapter, these ISPs will drop your Internet connection, because they find the MAC address of the newly added router or adapter, instead of the one they expect. To fix this, change the router to report the Ethernet adapter's MAC, instead of its own. This is called "spoofing the MAC address". To find a PC's or Macintosh's MAC address, see How to Find an Adapter's MAC address : http://www.fixya.com/ThreadView.aspx?prdid=252225&thid=102075. To Spoof a MAC Address 1. Connect the computer that your ISP's installers used to establish Internet connection to the router. If you are unsure which computer was used, call your ISP, and ask what MAC address was registered. Then, using the instructions in the box below find the computer whose MAC address matches their records. 2. Disconnect other computers from the router. (If you do not want to disconnect other computers, you need to know the adapter's MAC address, as described in the box below. Then, in step 6, type Use This MAC Address, entering the adapter's address.) 3. In an Internet browser type the address 192.168.0.1. 4. Type admin for the username, password for the password, and click OK. 5. Go to the Basic Settings > Router Mac Address. 6. Select Use Computer MAC Address. 7. Click Apply. This automatically gives the router the computer's MAC address. 8. Click Test to make sure you are connected. If you are not connected, contact your ISP.
Feb 19, 2006 | NetGear CG814M Wireless Cable Modem...
Zyxel P660HW-D1 Router Logo
91 people viewed this question
Top Zyxel Computers & Internet Experts
Prashant M
Prashant M
Justin
Justin
mark
Are you a Zyxel Computer and Internet Expert? Answer questions, earn points and help others
