Question about Dishwashers
We're can we get a new latch - Dishwashers
  • 14,379 Answers
Call your local appliance repair shop,they should be able to order you one,they will need your brand name and model number.
Posted on Nov 02, 2012
Hood latch problems
you can purchase a new latch on ebay for about 20 to 25 dollars and replace it yourself it pretty easy to do .
Mar 23, 2014 | 2003 Chevrolet S-10
Older model (unknown) Whirlpool Dishwasher. Door latch failure. Dishes trapped inside.
You may have to break the little handle off to open it and order a new door latch mechanism. Just be careful. This is a lip latch so it wont be hard if you can get to where the latch connects. Use the internet and model to order new one.
Jan 23, 2012 | Whirlpool Dishwashers
I have a new epic 550 and the treadmill will not latch up, in fact I called and got a new latch lock installed it and this one doesn't latch up either. any idea
Did you make sure the incline is completely down? I had a similar problem and then realized the incline was on 2. I recalibrated and then it latched fine.
Dec 13, 2010 | Epic View 550 Treadmill
I close washer door but it wont go through cycle
Check to see if one of the two tabs on the door latch assembly are broken. If one is broken, replace the door latch. If the door latch is ok, you might have to replace the door switch and the door latch. To replace the door switch you have to remove the front panel. Remove the two screws holding the door switch assembly in place and drop the door switch assembly down into the bottom of the washer. Remove the wires and transfer to the new switch. Reach up and line up the new switch and install the two screws. Remove the two screws on the door latch assembly on the door, and remove old door latch. Install the new latch and replace the front panel. I hope this helps.
Jan 21, 2010 | Frigidaire Affinity ATF7000E Front Load...
Maytag MDBH950AWB handle/latch failed.
Replaced handle/latch unit. Killed power to the unit. Removed the inside door panel then unplugged the two switches on the latch. Removed old latch with broken handle (removing inside panel frees latch/handle). Installed new latch with handle reconnected the two switches, reinstalled inside door panel. Very simple. Note: Latches can be purchased with or without the handle. Less expensive to buy with the handle already installed on the latch.
Jun 24, 2009 | Maytag 24 in. MDBH950AWS Built-in...
2001 Chevy s10 door won't latch
you need to remove the door trim. Remove linkage attached to latch. Usually the latch will be secured with 3-4 large phillips or torx screws. Remove old latch and reverse procedure to install new latch
Mar 28, 2009 | 2001 Chevrolet S-10
I need to know WHERE to get a battery latch.
call Nikon parts replacement for a new latch, It's easy to install
Nikon Parts Department
7AM - 3PM (Pacific)
Monday - Friday
310-414-8107
Fax- 310-322-6979
Mar 07, 2009 | Nikon Coolpix S210 Digital Camera
The door will not latch
The latch head (with hooklike projections) have a spring to keep it pulled down. If the latch head can be easily pushed up and falls back freely, then the monting tab on the back of the latch head is broken and it will have to be glued or replaced. The new part is better. To get to the door screws inside, you have to remove the choke cover, as shown in the photo. You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Aug 31, 2007 | Sharp R-1480 Microwave Oven
Dishwashers Logo
Top Dishwashers Experts
