Question about LG Shine KE970 Cellular Phone
Battery on lg shine not charging and not showing how much battery life is left
I can still access the micro sd card on my phone but the battery will not charge
  • 580 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Nov 03, 2012
SOURCE: Im having problems inserting the mic ro sd card in the lg shine
First of all, remove the back cover. The Micro SD slot is located underneath the SIM card slot. Hold the SD card with the metal connectors facing you and slide the card into the slot, metal connectors first, until it clicks in place. A logo of an SD card should then appear on the top of the screen.
Then to remove it, push it in and it will click and then pop back out
Posted on Oct 19, 2007
  • 242 Answers
SOURCE: micro SD card
try to format it using your computer.
Connect the card with computer using a card reader
Then go to my computer right-click the micro sd-card and select format. Format it using FAT.
Posted on May 24, 2008
  • 11 Answers
SOURCE: LG shine: using my mp3s as ringtones
Make sure the file is mp3 format, 600 kb or smaller, and 30 seconds or less. You can make your own ringtones at the following sites:
www.cellsea.com
www.makeownringtone.com
www.ventones.com
www.myxertone.com
Once you have your ringtones ready, there are many different steps you can follow depending on what you have available on your phone.
1. If you have internet/text messaging: sites like cellsea and myxertone will provide you with instructions.
2. If you have a usb cable: connect your phone making sure it's in Mass Storage Mode. You can do this by going to settings, connection, usb connection mode, mass storage. Open the folder for your phone on your computer. It should be one of the choices of storage when you go to My Computer. Place your ringtones into the Sounds folder. And voila! It should be in the ringtone menu in your phone.
3. If you have a MicroSD memory card: Create a folder on the memory card. Name it anything other than Music (the phone will automatically create a Music folder which can not be used as ringtones). Once you insert your card into your phone, the tunes should come up when you open your ringtone menu!
Hope this helps! Good luck! :)
Posted on Aug 19, 2008
SOURCE: Install java games on LG Shine CU720
Wow, I've never been to this website, but it obviously sucks and I will never come back. Sorry sangmoua1, I have the same question. But these people are too busy helping themselves to help you.
Posted on Sep 15, 2008
  • 7 Answers
SOURCE: lg shine - cannot access micro SD card which i have inserted.
I just got a new LG shine CU720 to format the card you go to settings, reset settings, master clear, memory card, my security code was 0000. Hope this helps someone else looking.
Posted on Jun 03, 2009
LG 970 shine will not recognize SD card
THIS WILL MAKE YOU LOOSE ALL FILES!!!
(even password)
Take the memorycard out of the phone and,
put it in a computer.Use filesystem FAT-32
to reformat your memorycard.
Now the card will work again!
No password, No files will be left after a
complete reformat
This is your solution! Please vote!
Jun 10, 2009 | LG Shine KE970 Cellular Phone
I cant connect my lg shine with my pc
Yes you can. If you insert a Micro SD card in the LG Shine, you can access the memory card from your PC.
Jan 30, 2009 | LG Shine KE970 Cellular Phone
I cant load music to my lg shine from my computer.. HELP!!!!!!
The LG Shine is a nice phone, but it is very disappointing with the USB cable.
You may expect the cable would connect the phone to your PC for Calendar Sync, music, videos etc.
Obviously, this will not work.
It will only allow you to hook your LG Shine to your PC to copy music and video files ONLY if you have a Micro SD card in the phone inserted.
After you have copied the files to the Micro SD card from your PC, you can copy them to the phone memory.
There are nice websites with free management programs for also the LG phone, but the Shine is unfortunately NOT listed (yet).
http://www.bitpim.org
Jan 01, 2009 | LG Shine KE970 Cellular Phone
Lg shine - downloading music from my laptop
If you want to put music files from your laptop onto your LG Shine, you can either use a LG USB cable or a Micro SD Card.The Micro SD card will probably need an additional adapter to have it big enough for your Laptop or PC slot. Once the music files are on the Micro SD card, insert the card into your LG Shine and go to My Stuff". Then, select "Audio and ringtones" and select the file on your memory card. Press the "Options" button and select the copy function and paste it into your phone.
Jul 28, 2008 | LG Shine KE970 Cellular Phone
Micro SD card
May 24, 2008 | LG Shine KE970 Cellular Phone
Getting songs from the sd card to show on my phone
To find your music on the SD, go to my stuff, sounds, external memory, mp3 and you should see your music. Playing it, however is another matter. You can play only one song. Then you have to manually play the next one. Not what I'd call an MP3 player.
Mar 07, 2008 | LG Shine KE970 Cellular Phone
Micro sd
i think that you should use amemory card of lower memory.
Jan 31, 2008 | LG Shine KE970 Cellular Phone
How 2 insert Micro SD in brand new LG Shine?
remove the battery and its under there, slips down into the section below where the battery goes.
Jan 04, 2008 | LG Shine KE970 Cellular Phone
LG Shine KE970 Cellular Phone Logo
73 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
