Question about Samsung Televison & Video
Samsung le40a656 hdmi picture bouncing
Just bought samsung le40a656. problem is wiyh hdmi inputs..pictures seem to slightly bounce up/down, sometimes break up. I use ps3 @ 1080p, virgin v+ box @ 1080i.
Shuttle83
  • 1139 Answers
SOURCE: HDMI Signal gone
The HDMI interface may have suffered a malfunction, this offten happens due to stray voltages on the ground plane. If you do not have electronics experience I would suggest taking the set to the shop and having it repaired
Posted on Sep 24, 2007
  • 346 Answers
SOURCE: Bowed picture
malfunction of the pinchusion circuit.check pinchusion diode and transistor and pincushion ic
Posted on Dec 23, 2007
MikeMaierTV
  • 206 Answers
SOURCE: picture stretch top/bottom for 1080i HD input
First thing to look at would be the source, make sure that this source whatever it may be is set to display a 16X9 format. Your set may simply be showing what it see's and it may be seeing the 4X5 format and giving you a problem
Posted on Feb 13, 2008
SOURCE: HDMI Monster cables
I had the same issue. I think you have to reset your PS3. I don't remember how I fixed it but I did find the anwser in the PS3 user manual "Trouble Shooting".
Posted on May 19, 2008
  • 3 Answers
SOURCE: Motorola DCH3200 Cable Box
Be sure that you took the time to force the output of the DCH3200 to 1080i. They do not seem to come set that way by default! This is true whether you are using either the component or HDMI output.
Power OFF the unit and immediately push the Menu key on the front panel. Using the remote, be sure that the 2nd line of the config is set to 1080i and not something less.
Posted on Feb 01, 2009
I have a rca HDTV model R61WH76 after being on for about 15 mins or so I will lose the picture but will stell be able to hear the program. I cleaned out all the dust bunnies etc. to see if this would
I haven't found a video for a 61" model but if your tv is a rear projection tv I suspect that your problem may be similar to this 52" model..
There are other troubleshooting videos on youtube too.
Even if your problem isn't the same you should get some idea of what may be involved.
Sep 26, 2014 | RCA R61WH76 61" HDTV
No picture on my Gateway monitor My Gateway FPD 22755W TFT LCD Monitor powers up but has no picture. The blue lights on the lower righthand side come on. It makes the little banjo strum, but absolutely no...
First of all disconnect the power & unplug the video cable from the back of the CPU & Monitor. Power-on the monitor & wait 10 secs. If the Monitor is functioning correctly, a 'No Signal' message appears & sometimes keeps bouncing around like a screen saver motion. This means your monitor is OK, if no signal message is not showing then either backlight or inverter(power) input has gone KAPUT. Replacing either or both may not turn out to be a cost effective soln. However if the damage is only in the cable then simply replace it or use the HDMI port..........................Sodeep63
Nov 11, 2012 | Computers & Internet
PIP function does not work, the settings is greyed out also! I have a wii, PS3 and freesat :)
Hi nikkicollier,
PiP for your TV works between two different sources. This means between a component source and an HDMI source or between an HDMI source and another HDMI source. PiP also works with a PC connection, e.g. when using the TV as a computer display. PiP does not work between two component sources. The setting will be grayed out when you don't have a configuration that is supported, as the Samsung TV's are usually able to automatically detect which sources are plugged in and available.
I'm not exactly sure what sort of configuration you want your PiP to work in, but try one of the following configurations.
  • TV Cable (through VCR or other via Component input) with Satellite in PiP (via HDMI input)
  • PS3 (via HDMI Input) with Satellite in PiP (via Component Input)
  • Wii via HDMI Input) with PS3 in PiP (via HDMI Input)
You can usually find an HDMI cable for much cheaper at an electronics supplies shop, Radio Shack, or on eBay or Gumtree.
To change your PiP settings:
  1. Press the MENU button on the remote control. Select Picture and press Enter.
  2. Select PIP and press Enter.
  3. Press the enter button again, and press up or down to change the setting to On and press enter again.
    Note:
    If PIP is activated the screen will display in widescreen (16:9 aspect ratio.)
  4. Press the up or down buttons to select the Source then press the Enter button.
    Select the source of the sub-picture by pressing the up and down arrows and then pressing the Enter button.
    Note: The sub-picture can serve different source selections based on the what the main source is set to.
    Note:
    You may notice that the picture in the PIP window becomes slightly unnatural when you use the main screen to view a game or karaoke.
You can download the full PDF manual for your TV here (large download at 26MB.) Much of the PIP information can be found on pages 13 and 14.
Good luck, I hope that helps.
Mar 01, 2011 | Samsung LE40R73BD 40 in. HD-Ready LCD...
I have the samsung LE40A656 and when i watch itv channel (footbal
well, you can call up the network and get the picture clear or another sd card maybe
Jun 04, 2009 | Samsung Televison & Video
TV screen bouncing up and down
look for the horizontal hold.
Jan 26, 2009 | Akai PDP4206EA Television
Intermittant disruption of Picture and Sound on View TV/HDMI only
If i am not mistaken you can select the HDMI signal going out on the 663, this means you should select to have only pictures to go out as sound will have to be reproduced by the 663.
So HDMI output setup on the 663 should indicate image only, no sound.
Jan 23, 2009 | Yamaha RX-V663 Receiver
Tube tv bouncy picture
I've seen this problem before, would need your model #, meanwhile is your picute bounce when you hit the if pack, or pip module, if it does that were your problem is. these or your silver cassing, standing upward.
Regards
What About Bob
Feb 18, 2008 | Televison & Video
Can't fire properly at 90 degrees
Did you buy this used? Maybe the following problems: wires inside are loose or cold soldered. Flash tube has coated with film coating or flash head(inside)is dirty. Alexander atdlee@netzero.com
Jan 13, 2007 | Metz Mecablitz 60CT4 TTL Flash
Televison & Video Logo
775 people viewed this question
Henry  Thomas
Henry Thomas
