Question about Zebra S4M Thermal Label Printer
Ribbon in warning-E53.15.0
This warning has been flashing for some time now I cannot seem to get ti to go away!
Black vertical line
This seems to be a problem with some older panels. If you are prepared to tackle the problem yourself then try the following.
WARNING there are some very high voltages within the TV which can be LETHAL so the greatest of care should be taken.
With the back of the TV removed, use a hair dryer and apply warm air to all the ribbon cables in turn until you find the one which causes the fault to disappear. Now turn your attention to the faulty ribbon and remake the connections as necessary.
Dec 19, 2013 | Insignia Televison & Video
Hello, my A410 Pshot photos have fine lines and are overexposed. Movies ans flash seem to work OK. It started suddenly without warning. Tried changing settings without success. Would appreciate your...
Charles, First make sure that you're in the camera's automatic picture mode, and not it's manual mode. If so, then you're either experiencing a "stuck shutter" or a "broken shutter control ribbon cable" problem. Stuck shutter you can easily fix yourself, but fixing a shutter ribbon cable problem would not be an economical repair for your camera (in that case, would be time for a new camera). Please see this link that may help you sort out which problem that your experiencing. If you can't fix it with the listed stuck shutter troubleshooting steps (give it at least ten tries), then it's likely a broken ribbon cable.
Jun 24, 2011 | Canon PowerShot A460 Digital Camera
Where can i buy the ribbon replacements
http://www.heasterlawson.com/texintielcal3.html
heaster-lawson_2134_71062267
click image above to enlarge trans_1x1.gif quick-order.jpg Item No.: texintielcal3
Regular price: $6.99
Sale price: $4.99trans_1x1.gifSave 29%
Texas Instruments (TI) Electronic Calculator Ribbon Models - TI 320V/5317/5640/5650/5660
Sold as each
Availability: Usually ships in 2-3 business days.
texintielcal3trans_1x1.gifRegular price: $6.99
trans_1x1.gifSale price: $4.99trans_1x1.gifSave 29%
Jan 03, 2011 | Texas Instruments TI-5640 Calculator
My TI 810 printer has begun to error out. It prints a few lines, and the lines appear to "slide" to the left, until it is printing off the left edge of the paper, and then it stops printing, and the error...
Hello.
This is a ribbon problem, it needs to be changed. The fact that the lines "slide" to the left prove that the carrier is not going back to its original position every time.
So, the solution is to change the ribbon.
Aug 24, 2010 | Texas Instruments TI 810 Matrix Printer
MY TI 880 PRINTER RIBBON WILL NOT REVERSE
This is most likely the ribbon drive and Caltex has them.
call them at 1-800-959-5507 ask for linda.
Mar 18, 2009 | Texas Instruments TI 880 Matrix Printer
Zebra ZM600 - ribbon in error
Make sure the ribbon sensor is in the proper position and that there is nothing covering it, like a piece of label that came off and got stuck to the sensor. Here is a picture of where the sensor is located. Did you make sure you put the ribbon sensor plate back in? If not you will get this message. Make sure the Print Method is correctly set! Although I exclusively use Thermal-Transfer (ribbon is loaded along with label stock) my 140xIII had Print Method set to Direct-Thermal and printed labels just fine. The only problem I could see was that the Ribbon In warning would not go away.
After changing the Print Method the warning went away and printing continues as before
Oct 27, 2008 | Office Equipment & Supplies
TI-83 Plus Silver Edition 1.14
That means that you know your calc crashed. This can be caused by taking out the batteries durring running time, happened just randomly. Well nothing to fear just press clear and it should go away but if it stays on that screen you have problems and is best to try some of these methods. Take out all the bateries and press and hold the on button for 30 seconds. Put the batteries back in and it should have reset. Warning you should archive everything incase this happens. To archive go to 2nd mem and hit enter to put a astrick next to the app (meaning archived)
Sep 12, 2008 | Texas Instruments TI-83 Plus Calculator
"warning Ribbon In" error message
Had the same problem with a ZM400. As stated in the User manual (can be downloaded http://www.zebra.com/id/zebra/na/en/index/resource_library/manuals.results.html?FRRBarcodePrinters=6882), warning "Ribbon in" is usually caused by the wrong printing method (thermal direct instead of thermal transfer [which should be selected for ribbbons]). My error disappeared after choosing "thermal transfer" directly on the printer. For network printers this needs to be set by an admin in the network settings for the the printer to solve the problem permanently.
May 07, 2008 | Zebra 105SL Thermal Label Printer
Texas instruments ti-86 screen problem
The TI-86 uses a very small, very thin ribbon cable to connect the display board to the LCD. The cable is about 2.5 " wide and about 4" long, and is only slightly thicker than a piece of paper but has about 40+ leads buried inside. Over time the leads will break at the folds (there are at least two folds in this cable to fit it down inside the case). There is no cheap solution to fix this problem. You might have some "Mr. Fix-it" try to fix it, but he will tell you to throw it away after he renders it completely inoperable. The calculator uses two Torx bit screws at the bottom of the case (T-6 size) so you will have to get the correct screwdriver to open the case. Save your money, sanity and time and use it till you can't stand the missing lines and throw it out. Even the data cable looks like it is glued down so if it lifts off after being cooked or frozen a couple of dozen times in the back of your car you can't fix this.
Mar 28, 2008 | Texas Instruments TI-86 Calculator
Zebra S4M Thermal Label Printer Logo
116 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
