Question about Nintendo DS Lite Console
Lara croft underworld for ds
I'm stuck on a level - in Valhalla, The Ascent. I'm in a room with a mechanical lever which lifts a wall. I can see a couple of swing bars but can't reach the highest one - this one looks like it will get me onto a higher wall so that I an escape.
I found that lara would stand up on one of the swings, allowing her to jump up to the next one and on to the high wall.
Posted on Jan 05, 2009
On a slight ascent the gear lever jumps out of the 5th gear.
There is quite a long list of possible reasons and most of them require gearbox removal to fix.
Weak or broken selector detents, weak or broken synchrohub detents, loose, worn or maladjusted selector fork or mechanism. excessive endfloat in a shaft, gear or hub.
Worn synchrohub teeth is a very common cause.
It would be worth checking the external linkage for possible fouling or maladjustment first.
Apr 28, 2016 | Cars & Trucks
Tomb Raider III: Adventures of Lara croft script fail
I'm affraid you'll have to start all over.
1. Uninstall the game.
2. Defrag the hard drive.
3. Re-install the game.
4. Apply the patch (NO COMPATIBILITY MODE).
5. Start the game from the shortcut.
Aug 14, 2012 | Sony Tomb Raider III: Adventures of Lara...
I need help killing the creature that amanda controls?
You had to get all four circuts lit by hitting them with the tesla gun, and then get off the gun; grapple the sword fragment with your hook and then you have it. You can't kill the creature there's no way to.
Thanks,
Heather:)
Oct 07, 2009 | Eidos Interactive Lara Croft Tomb Raider:...
I am stuck on a boss on lara croft tomb raider legend
Its simple.Heres what you must do.When the large monster attacks, what you need to do is shoot the large statues beside the levers to get his attention. Pick a close one, either left or right and fire at it until the creature notices. When he does, his head will lower and look at it closely. When the creature does that, immediately use the grapple and snag the level. Pull it back and a set of spikes will drop down on its head. You need to do this three more times and the creature will be no more.
Mar 11, 2009 | Eidos Interactive Lara Croft Tomb Raider:...
Eidos tomb raider underworld
Leap onto the slab near the second spout, then climb up to a grip. Leap from the grip to the rod in the serpent head's snout to stop the flow. Climb down using the grips underneath the spout. Grapple on the screw in the center and yank it as you move counter-clockwise (with the Thor statue as 12'o clock) around it. It should screw into the ground, stopping the flow for good and allowing access to a chamber inside the Thor statue.
Mar 10, 2009 | Eidos Interactive Lara Croft Tomb Raider:...
Stuck on nintendo ds zelda game.
I don't know exactly where your at so I'll try to cover the whole b3 strategy.
Note: IF YOU HIT A REAPLING IN THE BACK WITH AN ARROW, IT'LL BE TEMPORARILY STUNNED.
Head east from the safe zone( the one you're in upon entering the floor ) while fighting the skulltula and poe, ignore the levers on the wall for now and continue moving east. A trap in the south-east corner causes blue flames to flare up, forcing you to battle the five skulltulas. After clearing out the skulltulas the blue flames will be extinguished. Go north, and then duck into a side passage with a safe zone. You'll see a crystal switch that when activated, it only releases a reapling so just ignore that switch completely. Get to the floor's far northern hallway, a small safe zone and a treasure chest are located in the northwest section. return to the floor's central safe zone where the the stone tablet is. The sequence 2, 4, 5, 1, 3 is the order in which the levers are pulled, not the order of which to pull them.
Here is exactly what you must do:
1. pull the 4th lever first
2.pull the lever farthest east (the 1st lever)
3. pull the 5th lever
4. pull the second lever
5. pull the middle lever (3rd lever)
In the right order, the levers drop the spikes to the north of the barrels. DO NOT rush up there immediatly, there's a trapdoor in the room's southern entrance. Loop around through the floor's east side to access the barrel room. make sure the reapling isn't close by and start moving the barrels in there. On the east side of the barrel room you'll find a pressure switch. Now you can access the safe zone in the north-west area. Avoid the reapling and skulltulas that you might encounter along the way. In the north-west safe zone you'll just find a few barrels, but one of them is wriggling. move it to find one of the cubus sisters. move slowly and kill the skulltulas that drop, like the others this sister is also scared of them. Reunite all the sisters,but before you do make sure you're ready for a tough battle.
Dec 10, 2007 | Nintendo DS Lite Console
Nintendo DS Lite Console Logo
103 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
