Question about Whirlpool Washing Machines
My washer was squeling every time it ran cold water for a few months, now the washer will shut off randomly in a cycle. I can sometimes turn the dial and restart the load but other times it wont start
Its an older whirlpool washer 10+yrs?
  • 38 Answers
You have a bad actuator/timer control google model number and find replacement part. probably around 80 bucks
Posted on Nov 02, 2012
aborcass
  • 2651 Answers
SOURCE: Whirlpool washer stops for no reason.
i would be concerned teh the door/lid switch is not being activated, or is loosing contact withthe swtch mid wash causing unit to shut off. unitll the lid is lifted and closed to make better contact.. tyhe activator for the lid switch is actually the underside of the lefthand lid hinge. so if your able toreah under the lid while open you feel the metal lever, as you push and pull hte lid youll feel the lever move as well. with a hollow shafted screwdriver/1/4 nutdriver. place the driver over the metallever andslightly bend it toward the rear of the uni, so it makes better contact with the switch mounted tothe underside of the main top assembly
Posted on Nov 20, 2008
SOURCE: WHIRLPOOL FRONT LOADING WASHER MODEL #GHW9460PL0
I have a Sears front load made by Whirlpool. It had a problem locking door. I replaced latch/switch assembly and still would not work. Took top of washer off 3 or 4 screws on back of machine lift up lid and slide back. Make sure washer is unplugged. Presto you can see wiring and control. Unplugged connectors on control and plugged them back in then tried washer and it works.
Posted on Apr 17, 2009
  • 91 Answers
SOURCE: The washer will fill up with water but won't complete the cycle or drain. This has happened before, and I would spin the knob a few times and switch the load size selection. It always randomly started
it sounds like a bad timer there....! if after you selected a different load it drained......!
if it didnt drain at all on any mode I would say a bad lid swtich.
Posted on May 28, 2009
blueextc3221
  • 15935 Answers
SOURCE: Whirlpool washer shuts off during cycle
Replace the timer - it is failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: asko 12505 (10 yrs old) front load washer sometimes wont spin
It appears your timer/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Posted on Sep 12, 2010
It will fill but once full the motor will only spin for a few seconds then stop
IT MAY BE DUE TO A RINSE PROBLEM?
WASHER WILL NOT RINSE:
If your washer doesn't go through the washer rinse cycle, the most likely cause is the water valve. What happens is the water valve will stop letting cold water into the washer; therefore, once the washer gets to rinse it will either stop or not do anything during the whole rinse cycle.
This is because when you selected your water temperature, you selected warm/cold or hot/cold. The hot water came in and you didn't notice any problems. When it got to rinse, the cold water the cold water won't come in. Therefore, the washer does nothing.
To check the water valve, first cut the water off and remove the hoses off the back of the washer. Then one at a time point the hoses inside the washer tub and turn the water back on. If you don't have good water pressure, turn the water back off and remove the strainer that should be in one end of the hose. Inspect the strainer to see if it is stopped up, clean it and reinstall it. Now repeat this test. If you have good water pressure now, reinstall hose and your problem is fixed.
If you still don't have good water pressure, the problem is in your house plumbing and you need to call a plumber. If you had good water pressure the first time you performed the test, the water valve is bad and needs replacing.
TIMER
If your washer doesn't go through the washer rinse cycle the timer may be the problem. Sometimes the timer gets stuck in the middle of the cycle or won't turn at all. If the washer runs, but the timer doesn't turn, the timer is bad and needs replacing.
Do you have anti-flood hoses leading to the machine. If you do there is probably a loose tube in the back causing a small leak. When the hoses detect that water is still flowing after a certain amount of time due to the leak it shuts down and causes the machine to turn off during the rinse/spin cycle
Apr 19, 2015 | Washing Machines
Amana washer will not go through rinse cycle
TIMER
Mar 28, 2015 | Amana Washing Machines
Model gfwn1100 front load washer
It shuts down because of time out, is the water turned on, sounds stupid but it has happened several times, I go on a service call just to turn the water on to the machine.
Feb 03, 2014 | GE Washing Machines
My washing machine stops at the rinse cycle everytime. it is a hand-me-down washer that worked fine at the previous owner's home. not to mention this is the second washer i have received as a hand-me-down...
when a washer goes into the rinse cycle it only uses cold water,i think you have a problem with your cold water supply and if it happened to two washers it's not the washer.shut down the water valve,remove the cold water hose off the back of the washer,stick it into the washer and turn it back on.if no cold water comes out this will be your problem.
Jan 23, 2011 | Maytag Performa PAV2200
I have a Whirpool FL AWM285 800. Half way through any cycle it stops ( usually before it is supposed to pump out or rinse any water ) by turning the dial it it starts again but stops again when it has to...
CHECK TO MAKE SURE BOTH HOT AND COLD WATER ARE WORKING.IF IT TRIES TO FILL WITH COLD WATER LIKE FOR A RINSE CYCLE AND NO WATER COMES IN, IT WILL SHUT DOWN. THIS MAY ALSO EXPLAIN THE POWDER NOT DISPENSING.WHERE THE HOSES CONNECT TO THE BACK OF THE MACHINE THERE IS SCREENS YOU CAN CLEAN.GOOD LUCK!
Jan 15, 2010 | Whirlpool AWM8143 Front Load Washer
Water level issues on the Whirlpool washer.
It's overfilling If your washer is overfilling, check these:
Water-inlet valve
Water-level switch
Water-inlet valve A defect in the water-inlet valve may mean that it's no longer able to shut off completely when the electricity has been turned off to it. If this occurs, the valve may leak and drip water into the clothes tub. In time, the water may accumulate substantially. If this happens, you need to replace the valve.
Water-level switch A defect--or an obstruction--in the water-level switch may mean that it can't tell the water to shut off. So the machine overflows. This switch senses the water level in the clothes tub. It's usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. You can either clear any obstruction in the tube or replace the water-level switch.
It's underfilling The water-level switch regulates your washer's fill volume. This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch.
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected.
If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
May 08, 2009 | Washing Machines
Hot water goes into cold water washes
It is normal for the machine to cycle between hot and cold water when filling even if selecting a cold cycle. The reason for this is because even a cold cycle requires the water temperature to be 78F for the soap to break up efficiently.
During the cold months the water in your pipes is probably less than 78F so the machine will need to add some hot water to bring it up to this temperature. Basically, it is adding cold and then hot water to maintain a temperature in the tub of 78F for cold water cycles.
Hope this helps, please rate my solution.
Jan 12, 2009 | LG WM-1832C Front Load Washer
No hot wash
If you shut off cold water the sensor will send message to computerized box the machine will not operate. it shut down the machine.
Dec 31, 2007 | Bosch Axxis WFL 2060 Front Load Washer
Washing Machines Logo
21 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
