Question about Kitchen Ranges
Kenmore elite dual fuel range model 41103 manual
fridgetech
  • 473 Answers
SOURCE: Owners Manual
You can get the use and care guide at http://www3.sears.com/.  The part # is 318200838 and cost is $2.99.  Looks like there is a video available also for $35.56 and that part # is 316124202.  Would appreciate a solved rating for the advice.
Posted on Oct 17, 2007
Techsim
  • 59 Answers
SOURCE: how do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Posted on Dec 28, 2008
jtbjtb
  • 135 Answers
SOURCE: Kenmore elite dual fuel range top ignitors clicking like lite mode is on, but it's not.
You probably have a shorted spark module. send model # for more help. Hope this helps!
Posted on Feb 16, 2009
jyackle5
  • 8197 Answers
SOURCE: i need an owners manual for kenmore elite range
You can get the manual here at the bottom of page. But you need to register.
http://www.wigix.com/item/733569/Kenmore-Freestanding-Electric-Range-98003
Posted on Sep 23, 2009
blueextc3221
  • 15935 Answers
SOURCE: Our range started giving us the error
Here are some juicy pearls of appliantology wisdom from our friends at Maytag for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Posted on Sep 25, 2010
How can I get a user manual for my Kenmore Elite 30 inch Electric slide in range with ribbon radiant elements model number 46804
Kenmore Elite Electric Slide In Range 30 in. 41053 - Sears
www.kenmore.com/kenmore-elite-30inch-slide...electric-range...
Kenmore
Rating: 3 - ‎30 votes
The slide-in Kenmore Elite range 41053 has a true convection oven for faster pre. ...Kenmore Elite 30" Slide-In Electric Range w/ Convection - Stainless Steel ... Owners manual - English (Warranty) .... I called SEARS repair to look at my range and the repairman told me that this range has flaws with the oven fan and there is ...
Kenmore Elite 30" Double-Oven Slide-In Electric Range w
www.kenmore.com/kenmore-elite-30inch...slide...electric/p-02...
Kenmore
Rating: 3.5 - ‎30 votes
The exciting Kenmore Elite double-oven slide-in range 4111 offers all the feature. ... Versatile cooktop options include a 12-inch triple-ring element, a 9-inch Turbo Boil Flex™ element, and a ... Owners manual - English (Warranty) .... Ovens are both conventional or can be set to convection, my first bake was a cheese cake.
Nov 28, 2015 | Kenmore Kitchen Ranges
How do I override the sabbath feature on the elite dual fuel range?
since each model and each manufacturer operating procedures are different, it is best to read the instruction direct from your owners operating instruction booklet that came with the unit. If you don't have one, you can usually order one from sears parts direct for your specific model.
Sep 30, 2014 | Kenmore Elite Stainless Steel 40" Dual...
I continue to get code F11 on my Kenmore Elite Gas Range Oven and therefore, I am unable to unlock / open my oven door. I have pressed and held down the STOP button as well as the oven light button.
Your model number should be much longer than 790 30 Open drawers and doors to look for the whole model number around the frame.
With the whole model number you can get more information at Sears Parts Direct. There are parts diagrams and user manuals and you can order parts.
http://www.searspartsdirect.com/
This site gives instructions for repairing F11 and recommends checking the temperature probe and tells how to do it.
How to fix Frigidaire oven error code F10 F11 F30 F31 etc AskGene com
Sep 10, 2014 | Kenmore ELITE 790 30 FREESTANDING DUAL...
Kenmore elite dual fuel range - all burners' igniters are clicking without being in use /trying to ignite the burners
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Sep 06, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Sear elite model 790.31043800
bought new orffices and then the gas company converted it.
Sep 05, 2009 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Feb 16, 2009 | Kenmore Kitchen Ranges
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
