Question about Singer 8280 Mechanical Sewing Machine
Model 8280. The thread on the bottom keeps bunching up. It is a horrible mass of thread. Then, it stops moving. Can you help me?
  • stanhoff82 Feb 11, 2009
    how do you adjust the bobbin tension?
  • Anonymous Feb 18, 2009
    Thread still bunching on clean new machine
    Welcome Back:
    Visited the website for 2 consecutive days.
I had the same problem and I tried everything including removing the bobin case, cleaning out lint, changing the needle, adjusting the tension but it did not work. Then I finally tried reloading the bobin thread, making sure to load the bobin according the manual directions....and the problem was solved...no more tangles... just a nice even stitch...yeah!
Posted on Jan 09, 2009
I took the bobbin and casing out, then removed the hook race cover and hook. I cleaned it all and re-lubricated. When I put it all back together, it took care of the problem. I also adjusted the tension on the bobbin and removed the needle plate to clean underneath. I'm not sure what fixed it, but it works now.
Posted on Jan 07, 2009
I have a Bernina Activa 130. I tried to sew over some leather, started fine, then the needle got stuck and I stopped right away. Now, the bottom threads keeps bunching. I have re-threaded the machine, new...
You need a fatter needle. The skinny needle will not open the leather enough for a smooth flow of thread and that's why the bobbin is bunching up when the top thread is sticking. Make it easier on your machine by using an appropriate size needle while sewing leather.
Nov 04, 2013 | Bernina Activa 130
Singer 8280 sewing machine tension won't increase
Make sure your needle and tread match your project. There simply isn't such a thing as a "universal needle." Also try lengthening your stitch. Heavier fabrics typically need a slightly longer stitch. Upon commencing to sew always grasp the 2 threads and slightly pull as you begin your seam.
I assume your garage sale find has a manual. Be sure your bobbin is unspooling in the correct direction. If it didn't come with a manual.. http://www.singerco.com/uploads/download/430_8280_es.pdf
Good luck.
Jul 04, 2012 | Singer 8280 Mechanical Sewing Machine
The thread keeps bunching up near the bobbin and no amount of rethreading and lubricating is helping.
1.upper tension may be to tight--try 3 to 5
have you tried a new needle
2.the needle may be bent or damaged--try rolling the needle on a flat surface to see if it's bent or not
3.Correct needle insertion
Correct needle insertion is mandatory for proper use of sewing machine.
Raise the needle bar to the highest point, then loosen the clamp screw to remove the old needle, place the new needle in the clamp with the flat side to the back of the machine or if using a round needle--the groove in the needle should face away from the shaft.
Push the needle all the way up to the stop or as far as it will go, then tighten the needle clamp screw
4.also check to see if the thread has come off the thread take up lever
Sep 12, 2011 | Singer 8280 Mechanical Sewing Machine
When i fill the thread in a bobbin on top then the footer also moves up n down for singer model 8280
If you have released the stop motion and the needle still goes up and down it usually means you have a dry topshaft where the balance wheel is, you need to take it in for a service
Aug 31, 2011 | Singer 1507
Top thread bunching under fabric when sewing
tension could be too loose. start with bobbin tension- should allow thread to pass with SLIGHT resistance. then adjust top tension at about 2-3 to start.
Jun 01, 2010 | Singer 8280 Mechanical Sewing Machine
Mass bunching of thread in the bobbin compartment
it had nothing to do with the shuttle, it is the upper thread is not in the tensioner. lift the presser foot up and thread the machine even if you have to hold the thread on the top and pull on the bottom to make it go in the tensioner it will help, if a machine loops on the bottom it is the upper tension if it loops on the top it is the lower tension
Aug 22, 2009 | Brother CS-8060 Computerized Sewing...
Keeps "birdnesting", besides rethreading, how do I fix?
when you have bunching on the bottom, you have a problem with the top thread: no tension. (and visa versa) Make sure the thread runs through the tension discs, these discs are activated when you put the presser foot down, so you want to thread the machine with the foot up, also feel if there no burrs, hooks, or whatever, so your top thread comes smooth off the spool, no jerking.
May 24, 2009 | Singer Sewing Machines
Sewing machine
Simple solution..
take the thread off your machine, set your tension to the middle setting. rethread your machine up to the needle. before threading the needle, put your presser foot down. If your thread pulls hard, then the machine is threaded right. If it pulls easily, you need to chead the thread thru the tension wheel.
Kelley
Rule of thumb.
Loops on the bottom, problem on the top.
Loops on the top, problem is on the bottom.
May 02, 2009 | Singer 8280 Mechanical Sewing Machine
Singer 8280 lower thread tension not consistent and not even
clean the lint out with canned air (best thing going) then I hope the tension is still back to where it was.never change this with out going back to the first setting and keeping it noted so you know where the problem is not. try changing the needle it may be bent
Feb 28, 2009 | Singer 8280 Mechanical Sewing Machine
I have model 8280 and the bobbin thread keeps bunching up on the bottom. I have tried to rethread it but it keeps happening.
i think your putting in your bobin backwards,
to check put your bobin in and hold bobin , and bobin case by thread if it unrolls its backwards,
hope this helps!!
Jul 26, 2008 | Singer 8280 Mechanical Sewing Machine
Singer 8280 Mechanical Sewing Machine Logo
484 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
