Question about Grilling
Need a regulator and propane tank whip - Grilling
  • 89 Answers
SOURCE: Propane tank with regulator
You're fine using a regulator, just keeps the propane 'regulated' : ) Since you already have it, I'd try the one you have. I'd figure your regulator for the big tank is set for low pressure, really may be fine by itself, but the additional one at the Webber end won't hurt anything. This is a YMMV, try cheapest way first using what you have, not much of a problem to change to the other one if it doesn't work.
Posted on Oct 29, 2008
TheMobilian
  • 8220 Answers
SOURCE: cannot conect regulator to small 16.4 oz propane tank
It must have some sort of packing spacer you need to remove from the hose to attach the tank. LOL
Posted on Apr 12, 2009
  • 139 Answers
SOURCE: Kenmore Gas Grill 141.155401 issue with Propane tanks
replace the regulator
Posted on Apr 14, 2009
  • 57 Answers
SOURCE: I have a Uniflame Model
it is the regulator go to home depot and buy one
Posted on Aug 25, 2009
  • 494 Answers
SOURCE: Propane was leaking between tank and regulator on
I would recommend you take the regulator, hose and 20# cylinder to your local propane co and have them check it out for you. Or if possible, just load the entire bbg in a truck and bring it all to them. Call first to schedule a time that can look at it. If you replaced the tank and the regulator, my guess is that you probably have a cracked fitting or the fitting is missing an integral part that seals it to the tank. Douglas
Posted on Jul 29, 2010
I hooked a thermador cooktop to a BBQ propane tank. The flames are large for a second and make a puff sound and the shrink to nothing. All 5 burners do the same.
It does sound like a faulty regulator, propane operates at 2.75kpa and if the existing regulator is for natural gas it is only 1.1kpa.
If you are operating off a bulk tank the regulator on the tank may be high pressure then the secondary regulator on the appliance may be to bring it down further. See if you can get a manometer and check it all out before doing any regulator removing.
Apr 05, 2014 | Thermador Cooktops
Need a control knob for : dyna-glo pro propane heater. model # rmc-tt 30dgp-01, # rmc-tt30dg, #rmc-tt30gd. serial: # 09 005720
Contact GHP Group Inc, (877) 447-4768 to order a replacement regulator - MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Replacement cost including shipping is a couple bits over $21.
When talking to the technician on the phone, he cautioned me against rapidly opening the tank valve, which hammers the regulator (the replacement one is more robust than the original), kinda' like how water-hammer can cause damage to water pipes and/or water appliances. Open the tank valve gently, don't just whip it open (like I used to), your regulator will last a lot longer that way.
Because of the press-fit and pins used in the regulator construction & assembly, self-repair is not possible or recommended since the regulator may not seal correctly afterwards.
Dec 17, 2010 | Garden
Propane was leaking between tank and regulator on my BBQ. Replaced with three new regulators and two new propane tanks but still get strong hissing from vent hole and strong smell of propane when I open...
Jul 29, 2010 | Char-Broil Grilling
What type of regulator do i need to connect my propane tank to the heater?
You need a regulator rated for the heater. Your propane dealer can provide you with exactly the right regulator.
May 24, 2010 | Hayward 100k Btu Propane Gas Pool Heater...
Propane is venting from regulator
Your propane regulator is defective and will need to be replaced. Do not use it. Contact your local propane co and bring it in for a replacement. Some retailers like K-Mart, Target or Wal-Mart will also have regulators, but if yours if not standard, it may need to be ordered by a Ducane grill reseller like Amerigas Propane, which is the largest propane co in the U.S.
May 23, 2010 | Ducane 30400040 Stainless Steel Grill
I need a new regulator with a low med high knob for two burner dyna glo tank top heater propane if tou have how much if not where can I get one thank you
If you don't have an authorized dealer to get a replacement regulator, contact GHP Group Inc, (877) 447-4768. MAKE SURE YOU HAVE THE PROPER HEATER MODEL NUMBER. Replacement Part Number: S2TT0001B for the RMC-TT30DGP.
Here's a link to the manual for eight of their tank-top heaters
Nov 20, 2009 | Grilling
Hooking up a pool heater to propane.
A pressure regulator and pipe or hose. Whoever is selling you the tank/propane should be able to help you size everything based on the tank hook-up and tank pressure. The heater nameplate will tell you the proper inlet gas pressure that the regulator will need to reduce the tank pressure to.
Sep 07, 2009 | Hayward H Series
Cannot conect regulator to small 16.4 oz propane tank
Apr 11, 2009 | Coleman Roadtrip Grill LXE 9949-750
Grilling Logo
32 people viewed this question
Top Grilling Experts
paulcarew
Dan Webster
Dan Webster
Are you a Grilling Expert? Answer questions, earn points and help others
