Question about Frigidaire FEF336BC Electric Kitchen Range
Replaced bake unit in Frigidaire FEF366DCA yesterday and when I turned on to bake @ 350 I heard a "pop" and the oven would not heat past 300 in quite some amount of time. Is it a blown fuse? And if so where is it located? Or is it some other issue? Thanks! Mike
    Sergeant:
  • 311 Answers
The pop is most likely an electrical short it will be in the back of the stove,that is unless your new element shorted .when cool you can run your hand around it and you should feel no blisters,smooth only.other wise you are doing a visiual inspection and looking for an obivous burnt wire/connection.God bless ,tom
Posted on Jan 04, 2009
  • Peter Sullivan Aug 11, 2013
    Tom, Thank you. God bless you too. I opened the back and saw some charring around a ceramic insulator. I'm not sure where the short was. After the initial "popping" sound, the circuit breaker opened as well.
Motor working sound when our new Frigidaire electric range is heating to selected temperature. Is this normal?
some fan assisted ovens turn on the fan to get up to temperature, its an energy efficiency thing, also mean pre heat is quicker. if you need more info on this unit here is web page
http://www.frigidaire.com/Owner-Center/Product-Support--Manuals/?productCode=LGEF3045KF
hope this helps you.
Jun 11, 2017 | Frigidaire Kitchen Ranges
Frigidaire convection oven door flyes open during baking pop
I would contact the Manufacturer thru their website and ask for tech support .I have never heard of this type problem
Aug 23, 2017 | Electrolux Kitchen Ranges
I own FRIGIDAIRE ES100/105 (electric stove and oven). Yesterday I was using the oven and suddenly I heard a loud sound. I went to check it I found out the both the oven and stove were off. And not working....
HI. The actual issue will be with the main logic board, which is where the main element control relays are mounted. These very important relays are damaged. The main board will need to be replaced, asap.
With that said, if you could be so kind; Please post the entire model number so that i may pull up all necessary part numbers needed, as well as, service manual links and diagrams to help with your repair.
Dec 02, 2011 | Frigidaire PLEF398AC Electric Kitchen...
We purchased our Frigidare Double Oven, Model Number FPET3085KFA, October 2009 (15 months ago). We ran the self-clean process for the first time yesterday on the top oven using the 4 hr option and it...
try turning your breaker off for 20 minutes, then try it again,, if this does not help it could have burnt out a element or the main board has went out,,, also make for sere you are getting the full 220 volts to the unit,, this will involve taking the unit out
Jan 19, 2011 | Frigidaire 30 in. Electric Gallery Series...
When we bake everything burns even at 300 to 350.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 15, 2011 | Frigidaire PLEF398AC Electric Kitchen...
I have a frigidaire oven model number GLEF378CSB - won't heat up
Make sure your getting 240 volts to the unit if not it's the board...sorry. More then likely it's the board.
Jan 10, 2010 | Ovens
Frigidaire ES200/300 316257123
look for a shorted bake element .. you should be able to see where it poped. ( some times ) if you have ohm meter you can ck for an open element . **** //
Dec 04, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Oven and broiler will not heat elements have continuity when oven was turned on heard a pop after that the problem started
do you have voltage? you have to have 240 volts if you only have 120 this might happen check your breaker. does your bake element work? if neither bake or broil work always check the breaker first and let me know
May 28, 2009 | Frigidaire FEF336BC Electric Kitchen Range
Oven shuts off
It possibly incompatible heating element installed on the oven that's why it pops up when you try to turn on and heat it..
Feb 24, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Kenmore range
If this range has electric elements in the oven, you may have blown one of the heating elements. Do any of the oven functions work? If you were attempting to BAKE when this occurred, have you attempted to turn on the BROILER to see if it works? If the BROILER still heats up, you may just have a bad heating element. If both features quit working, the problem may be with your Electronic Range Control (ERC) board. Post back with comments and let me know.
Feb 18, 2008 | Kitchen Ranges
Frigidaire FEF336BC Electric Kitchen Range Logo
345 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Paul Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
