Question about Magellan Meridian Platinum GPS Receiver
Unit will not turn on
My new meridian fails to turn on anymore. Even with new batteries. It has not been misused dropped or anything. After giving a signal that the batteries were low it stopped working and just will not start up again no matter what.
  • walter999 Aug 20, 2008
    I got the same problem. From one day to another the unit stopped working. No screen, nothing. The unit didn't fall, the batteries always inserted the right way.
I have the same problem. As with the other postings the car adapter did work. The metal arm that touches the integrated circuit board needed cleaning.. Unfortunately the metal here is very thin and cleaning it has rubbed it through. I am going to try soldering it next. Poor design really.
Posted on Apr 23, 2009
  • 3 Answers
I had my meridian platinum do exactly this.
First test on car adaptor if you have one, if this works the batteries are not making connection properly.
I took the six mounting screws out and opened the back, I cleaned the battery connectors up with an alcohol wipe, a pencil eraser is also good for this. Then I bent the battery connectors up ever so slightly on the battery holder side. Reassembled unit, do not over tighten screws. Problem solved.
Posted on Sep 14, 2008
Well you posted this a long time ago but I also have had this problem and I think i found the solution. Open the battery cover and then tighten the screws that hold the unit together (not to tight). This has worked for me and I think it may be a common problem with these screws loosening.
Posted on Jun 23, 2008
Doesn't turn on.
how old is it? sounds like the battery has failed
Sep 29, 2017 | Wacom GRAPHIRE (CTE630BTT3C)
Swift meridian caravan 1998, not charging battery.
Your battery does not hold a charge anymore. If its from 1998 then you will need to get a new battery for your unit.
Sep 25, 2011 | GPS
I replaced my battery 3 days ago the car was driving fine. When i have to turn the a/c on the car shuts off. When the a/c is off the car is running fine. What could this be.
2 things need to be tested 1. the battery. Even new batteries straight off the shelf can fail in 7 seconds. It happens. 2. The charging system. Make sure you getting at least 13.5 volts perferably 14.5 and that it stays up even with headlamps and all accessories are on. If at any point it drops below 13.5, the alternator should be changed and rechecked. I had 3 bum alternators one day in the shop so never take for granted because it was in a new box that it will work the first time. Electrical components are just that way. They can fail new, used, remanufactured, rebuilt, etc.. Let me know if you need anything else!
Jul 09, 2010 | 2002 GMC Envoy
Lens stays out- "Bip Bip" when i turn it on but no other reaction
If the camera has recently been dropped you may have lens damage that's preventing it from powering up. If it hasn't been dropped your problem may be due to weak/worn out batteries or corrosion on the battery contacts inside the camera - which can prevent the full power of the batteries from flowing into the camera. Try this free fix before you do anything else: remove the batteries and wipe the camera contacts firmly with a dry cloth (heavy corrosion may require cleaning with a wire brush, steel wool, or sandpaper). Remove any residue that may have fallen into the battery compartment during cleaning, then clean the battery contacts, place the batteries back in the camera and give them a full charge (assuming that you're using rechargeable batteries). This cleaning clears the problem about 80% of the time. If it doesn't work for you, it may time to replace the batteries, or the camera may have a problem that requires professional repair.
Jan 21, 2010 | Samsung HZ10W / WB500 Digital Camera
My Samsung E1070M mobile phone is not having a network signal since last night. The only thing I have done was charging it while turned-off. After it was fully charged and turned-on, the signal won't work...
remove battery then insert it again and check ,if same prevails change your sim and try .if new sim acquires signal ,replace old one and try ,even now you have problem contact service provider
Dec 20, 2009 | Cell Phones
My 1996 mitsubishi galant may have a bad ground. the battery is constently dead, even with a new battery, if it sits the battery will be dead in 5 hours. i get a jump and it starts right up, but if i fail...
you need to get the charging system and battery tested. Most places charge about $40 for this service. Only takes a few minutes to complete but it will be money well spent. Then you can do the replacement parts yourself if you inclined.
Sep 08, 2009 | 1996 Mitsubishi Galant
My camera won't turn on
Well theres yoiur answer. If you have banged it or dropped it you have possibly cracked the motherboard inside. Sometimes these work intermittently with rthis type of misuse. other timjes it just stops. Cheaper to buy a new one than muck around getting it fixed
Jul 31, 2009 | Kodak EasyShare CX7530 Digital Camera
Lens error. Restart camera.
this is very common has the camera been near the ocean??? it does not have to be dropped to give you this error. repair on you lens runs 85.00 for repair. or a new lens for 125.00
Jun 25, 2009 | Canon PowerShot SD1100 IS Digital Camera
Wont turn on!!!
My problem is this; i changed the battery after i had signal that battery should be changed. I changed the batteries with new one but when i press the on/off button, the camera will turn on.
I put in new batteries again and is still the same problem.
Mar 11, 2007 | Vivitar ViviCam 3765 Digital Camera
Magellan Meridian Platinum GPS Receiver Logo
2,322 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
