Question about Microwave Ovens
My oster microwave model OM1201E0VG control panel does not work
The control panel buttons do not work and the display is lit up on the enter, amt, tim, clock, and mem. it blinks in the middle where the numbers should be. then after a few seconds it beeps, freezes and is only lit up on the clock and mem.any solutions?
SOURCE: Shuts off, must reset clock
I had this problem also, but what happened with mine is that it popped about 1/2 the bag and then the light popped inside the microwave and it shut down completely. My husband went out to see if the circuit breaker popped, it didn't, but he switched it anyway and the microwave came back on. So he put the micro on a power surge protector, and we tried again, but this time we used the minute timer and it just popped about 1/2 the bag and then blew. The surge protector still was working and so was the outlet, but the microwave was blown. About a 1/2 hour later, I looked in to see the micro and the clock had come back on. We just purchased this at Home Depot this past weekend, should we take it back and get another one? or is it our electical outlet?
Posted on Mar 12, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: can't use the microwave
To lock or unlock the keypad, press and hold the CLEAR pad for 5 seconds. If this recurs, you may have a power line problem or trouble with your controller. If you suspect trouble and it's under warranty, don't hesitate to contatc GE via ge.com. If you don't have your mower's manual, you can download one at: http://www.geappliances.com/service_and_support/literature/
Posted on Nov 09, 2006
  • 883 Answers
SOURCE: Oster Microwave/Convection/Grill
first, get your money back or get a replacement for no charge. now, unplug the oven for 15 minutes and try again. if no-go, then some device is faulty that only a tech can find
Posted on May 28, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave keeps shutting off
The magnetron is overheating, tripping the thermostat, which shuts off all power until it cools down.
This is usually caused by a blocked air vent, failed internal cooling fan, or failing magnetron.
If it's out of warranty, I'm sure you'll find it's uneconomical to repair, even if you could get parts for this brand.
Good luck.
Posted on Dec 30, 2009
SOURCE: My Galanz microwave WP800AP20-6 is beeping for no reason
I have similar problem
Posted on Jul 27, 2010
I have a Oster Microwave (OM1201E0VG), it's almost like new, works but suddenly has NO HEAT. I would hate to get rid of it, only had for a couple of years. Can it be fixable or should I toss it?
You might want to check the door microswitches for proper function. My microwave ovens have four separate switches on the door, one controls the actual heating, and if that switch goes bad, no heat. They're inexpensive and easy to replace.
Jun 17, 2015 | Oster Microwave Ovens
The touch pod on my microwavw 9je635 wont do anything when i press the boutos for timing fuction
follow this steps and fix it. God bless you
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_54_53_pm.gif1_24_2013_5_55_10_pm.jpg
Jan 24, 2013 | GE JE635 Microwave Oven
My oster 1000 watts microwave is not getting hot
There is a semiconductor device called a triac, if food is warm the microwave is not running at full power because the triac is defective.
Apr 09, 2012 | Microwave Ovens
Oster OM1201E0VG countertop microwave
It sounds like the thermal fuse may be defective, or the fan is not running, or the magnetron is getting to hot. If there are any heat issues the thermal fuse will cut power and reset in 5 minutes.
Mar 07, 2012 | Oster OGB61101 Microwave Oven
I have an Oster 1.2 cu. ft counter top microwave model OM1201E0VG. I purchased this model about a month ago. Every time we run it there is a grinding noise as the turn table rotates. I have checked...
There is still factory warranty on this and most stores wold even take it back if there is a problem. Please don't try and repair something that can be fixed under warranty or they will void the warranty. My advice is to put it all back to gether and then take it to the store you purchased it from and demand an exchange. They most likely will return it no questions asked if it is that new.
Apr 08, 2011 | Microwave Ovens
New oven model OM1201E0VG will not heat. Microwave worked at the store but I cannot get it to heat. Comes on but does not heat anything.
Call your dealer where you brought it. It's new purchase, you said it so, but read first operating manual.
That's the thing you need to do. I hope I help you.
Mar 29, 2011 | Oster Microwave Ovens
The oster model OM1201E0VG model, is not getting any power so the food is not heating in addition the adjustment of the power level does not seem to be operating. Please advise
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the capacitor can fail and go short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Jan 01, 2011 | Oster Microwave Ovens
Good luck.
Dec 26, 2009 | Oster Microwave Ovens
Microwave Ovens Logo
292 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
