Question about Itochu C.itoh CI 500e Matrix Printer
Need settings for c.itoh 500 - Itochu C.itoh CI 500e Matrix Printer
Cant receive pictures on my palm 500 treo
hi...
please call your service provider and ask for the setting. they wil send you the setting.please save it and make that setting as default so that you can start using the feature.
Jul 16, 2010 | Palm Treo 500 Centro
Looking for a manual for a C.Itoh printer mod# c310
hi there, if you go to the printer manufactures web site, it is highly likely that you will find a PDF version of your manual for your printer.
Jan 20, 2010 | Office Equipment & Supplies
Need the XP driver for the citoh ci-5000. Was working well on old computer... it died, I connected it to another computer and I can't find the driver... please help, I need this asap THANKS Will
copy past this downbelow in your browser pick os
http://citizeneurope.com/drivers/dotmat.htm
Oct 06, 2009 | Itochu C.itoh CI 5000 Matrix Printer
Bsnl net manual settings for palm treo 500
my bsnlnet profile setting disturbed,how can i reset this setting
Sep 22, 2009 | Palm Treo 500 Centro
Printer head damage the printer ribbon
See if there is a pin sticking out of the print head. If so, you must replace the head. You can google and find a head.
Aug 04, 2009 | Itochu C.itoh CI 5000 Matrix Printer
How do you perform a self test printout on the Citoh 5000
Turn the printer on, press the ONLINE button to take it offline. Press and hold the RESET button and press the QUIET/SETUP button. This puts the machine in configuration mode. Now press the FWD LN FEED button once or twice, then press the ONLINE button. This will cause the printer to print the current settings
Jul 09, 2009 | Itochu C.itoh CI 5000 Matrix Printer
SOFTWARE FOR C.ITOH CI 5000 PRINTER
hi
you can download the driver for citoh ci 5000 printer here
for windows 2000 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_2000/17280.html
for windows nt - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_NT4/17279.html
for windows 85 and 98 - http://www.updrivers.com/getdriver/Printer/Citoh/CI-5000-Windows_98_95/17281.html
or you can choose your own...
http://www.updrivers.com/drivers/Printer/Citoh/17/86/page2.html
thanks bye
May 19, 2009 | Itochu C.itoh CI 5000 Matrix Printer
CI 5000 is adding garbage characters to print jobs
You need to chage the print drivers to post script
May 29, 2008 | Itochu C.itoh CI 5000 Matrix Printer
C.Itoh CI 5000 Matrix printer
Did you check the lines per page setting on the printer? For normal 11" length forms, the setting should be 66lpp.
Jun 07, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Home Error
A21 Home Error refers to the printhead not moving. Most cases, it is due to the fuse being blown on the main logic board. You have to remove the top cover. Open the clear cover, pop out the plastic pins, remove, then pull off the tractor knob on the right, remove the two screws at the top back of the printer, lift up the cover from the back towards the front. You will have to unplug an electrical connect ribbon from behind the control panel. Check the fuse and replace if necessary.
Apr 02, 2007 | Itochu C.itoh CI 5000 Matrix Printer
Itochu C.itoh CI 500e Matrix Printer Logo
24 people viewed this question
Top Itochu Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Itochu Office Equipment and Supply Expert? Answer questions, earn points and help others
