Question about RCA F27636BC 27" TV
Picture is to large for 27in
Veiwing is for large screen tv's top and bottom pic is showing half during ball games football baseball
    Top Expert:
  • RCA Master
  • 14,553 Answers
If model indicated here is correct either a problem in the Vertical circuit of the set or an adjustment.
Almost any shop can take the set into the service menu and adjust vertical size a bit to correct if not circuit problem.
Posted on Nov 03, 2012
  • 556 Answers
SOURCE: can only see half the picture
your problem is in vertical output section.
the ckt which is connected to vertical output section is called feedback ckt.
please check.
1 loose contact in feed back ckt.
2 mostly this problem is due to electrolytic capacitor failure.
3 vertical output  IC or transistor failure.
4 check for proper supply to vertical output.
5  low value resistor failure in v/output ckt  (.in rare case)
IF YOU ARE NOT TECH PERSON PLEASE TAKE HELP.
  1. hope this will help.
Posted on Oct 10, 2007
bhur
  • 85 Answers
SOURCE: RCA TruFlat Tv problem
YOUR TV HAS A RETRACE PROBLEM,FIND THE CAPACITOR 35V/100uf,1V/10uf AND COLDSOLDER FIRST THE MAINBOARD BEFORE YOU REPLACE THE COMPONENTS.
Posted on Jun 12, 2008
  • 121 Answers
SOURCE: My RCA 32", the picture seems to be riding up the screen.
hold menu botton in power once vol up once. vol up to76  ch top po3 aj pict size ith vol cont
Posted on Dec 01, 2008
  • 4234 Answers
SOURCE: RCA 24V511T Vertical problem
There is a problem with the vertical circuit. In many cases this is either poor solder connections or a defecitve vertical IC. If you can solder you should be able to fix this yourself. Please note that there are potentially dangerous high voltages present inside the set even when unplugged. Let me know if you wish to attempt the repair and I'll provide additional details and instructions.
Thanks,
Dan
Posted on Jan 30, 2009
  • 145 Answers
SOURCE: I have an RCA 27in. screen TV. Cannot program, all is fuzzy.
try unplugging and plugging back in 2 minutes later. go to menu and find channel selection. scroll down to where it says channel. then using volume up and down buttons. will add or erase channel. just play with it and you will see what im talking about. go to channel 4 and press volume up. this will save channel 4 in memory. if no work, try turn on video souce and do a auto program in menu. fixed. enjoy!
Posted on Nov 14, 2009
I've notice while watching Baseball and Football games that it cuts of the the box scores on the top left hand corner and also on the bottom of the screen I'm not able to see all the content...
This problem u must play with the tv orignal remote.Look on the tv original remote for a buttons like Aspect Ratio,Picture Sizes,VIEW MODES,ZOOM.Just pushes one of these buttons until u have the desire screen format for u.The screen will jump every sizes,u can't get evrythings u want,have to give and take as the tv pictures exspan or contract.
Aug 12, 2011 | Sony Bravia XBR-52HX909 52 in. LCD HDTV
Picture too big
It seems as if your tv is in "crop", "Zoom", or "full" mode. Select letterbox, normal, or full-screen mode. Look in the manual for exact instructions.
Jul 15, 2009 | Panasonic VIERA TH-65PV500 65 in. Plasma...
On CNN or during football games banner is cut off
It sounds like you're watching wide screen content on a 4:3 tv, so the screen may be zoomed in so that the bars that would normally be on the top and bottom are not showing. Because the picture is zoomed in, images that would be at the top and bottom are off the screen. If you're watching from a home receiver (Uverse, DirecTv, Xfinity, etc.) you need to change the video settings to let the receiver know that your TV's aspect ratio is 4:3 (full screen) and not 16:9 (widescreen). Also, if your channel lineup has the option of watching CNN on a standard definition channel, that would also help because the shape of the image would be what your tv was designed for. If you watch 16:9 programs, you will have to choose letter box mode (bars on top and bottom because the shape of the widescreen image does not match the shape of your tv), pillar box mode (bars on either side) zoomed, or stretched. Stretched will make the shape of everything appear distorted, as it squeezes a widescreen image on the sides to make it narrow enough, so that everyone will have tall and skinny heads like an old Kung Fu movie. The sharpest picture would likely be to watch 16:9 (hi def) content in letterbox mode (bars on top and bottom) so at least you get the proper aspect ratio that the sports were recorded in, and it comes from a sharper source (HD vs SD). I would just deal with the bars, because even with a widescreen tv, there will sometimes be bars because that's how programs are sometimes recorded, for different visual impact or cinematic effect.
Jun 16, 2017 | Mito Car Audio & Video
The TV is only showing half of the picture
Hi Bigtate,
There is not much for me to go on with your description but here goes,
I suppose you have a convential TV set with a glass picture tube and not one of the new types with the large screen slim style displays!!!
If it a glass type picture tube then the following assumptions are made.
I hope yopu have not shifted house recently and moved the TV around???
If you have its possible the Yoke (its a device on the neck of the Picture tube that controls magnetically the scanning dot) may have moved and only is letting you see half a picture...
This is a long shot but it could be the cause..
Now the picture is supplied to you by a fast moving dot of light (Black & White set) that scans from the top of the picture and moves very fast down to the bottom of the screen, then flys back to the top of the screen and starts all over again during this process the dot lights up the picture tube to provide you with
the picture you see... (On a colour set there are three dots)
Its quite a complex process and its all controlled by electronics inside the TV receiver.
If you are getting only half a picture then something is causing the dot to only turn on for the lower half of the picture during its write time to the glass screen,
You dont say if the half thats off is white or black, so there are many things that the service technician needs to know before even starting to look for this fault. During the dot doing its write cycle down the sceen, when it reachs the bottom and flys back to the top of the screen it receives a synchronous pulse from the TV station, and this TV signal is critical in making sure you see the same picture as is being sent from the TV station.
Sometimes this sync pulse from the TV station is very weak and so your picture may float up and down the screen trying to lock to the incoming signal.. this just may be your fault.. but you dont say if the half of the picture that you see is floating or not..
Your situation may be that your TV has partially locked to the station signal and your aerial may be problematic,
but then you dont say if its on just the one channel or all of your station channels. So there needs to be more analysis of your situation prior to a positive answer being provided....
Sorry I can be of more help...
From YUBEUT...
Nov 10, 2007 | GE 31GT660 TV
Moved the tv and now have a line on bar in top half with bend to it?
sounds like solder on convergence amps has hairline crack's
needs resoldering...
Oct 19, 2007 | Toshiba 51H84 51" Rear Projection...
Dark area on screen
If it's a circular area you might be delaing with magnetism. Check the menu and there should be a control for geomagnetic correction and adjust accordingly.
Feb 07, 2007 | Panasonic CT-34WXD65 34" TV
Televison & Video Logo
76 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
