Question about Garden
Changing lawn tractor transaxel oil - Garden
  • 2 more comments
  • Leonard Mediavilla Nov 05, 2012
    The Craftsman Lawn Tractor Model # 917.237100 has avariable speed hydralic transaxel. The manual and Sears parts list a screw on filter (Expensive $30 plus) for the hydraulic part of the trans axel. Which should be changed as part of normal O&M. Neither the manual nor the Sears answer dept CANNOT provide guidence as how to refill the lost Hydraulic oil, how much, or what type oil should be put back into the transmission. Sears does list the Grease for the geared differential but nothing for the Hyd oil.
    The Craftsman Lawn Tractor Model # 917.237100 has a variable speed hydraulic transaxle. The manual and Sears parts list a screw on filter (Expensive $30 plus) for the hydraulic part of the transaxle. Which should be changed as part of normal O&M. Neither the manual nor the Sears answer dept CANNOT provide guidance as how to refill the lost Hydraulic oil, how much, or what type HYD. oil should be put back into the transmission. Sears does list the Grease for the geared differential but nothing for the transmission Hyd. oil. What type HYD. oil, should all oil be drained , how and how much oil should be put back in?
    The Craftsman Lawn Tractor Model # 917.237100 has a variable speed hydralic transaxle. The manual and Sears parts list a screw on filter (Expensive $30 plus) for the hydraulic part of the transaxle. Which should be changed as part of normal O&M. Neither the manual nor the Sears answer dept CANNOT provide guidance as how to refill the lost Hydraulic oil, how much, or what type HYD. oil should be put back into the transmission. Sears does list the Grease for the geared differential but nothing for the transmission Hyd. oil. What type HYD. oil, should all oil be drained , how and how much oil should be put back in?Add a Comment
5 Suggested Answers
  • 95 Answers
SOURCE: reset oil chang warning light
The oil minder light will blink for 2 hrs and then reset itself, i believe it starts at 49 and ends at 51 and then every 50 hrs it will do the same.
Posted on Jul 30, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 4961 Answers
SOURCE: I have modle number 917273201 riding lawn tractor I need the part number for the splined couppler that goes between the hydro output shaft and the transaxel input shaft? Thanks
You might want to post this in the lawn mower section so the proper experts will see your question.
Posted on Aug 18, 2012
WHAT LUBE GOES IN TRANSAXEL
I believe that's a tecumseh trans axle. They really aren't a serviceable part. But it you're brave... Yeah I've torn them apart to replace bearings and such. I never found a "spec" for the lube but it's really heavy. I used a nice sticky molly grease when ever I put one back together.
Aug 17, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
WHAT TYPE OF OIL DO I USE ON MY TRANSAXLE MOD 917.273080
Hydrogear transaxels take a multi grade oil 20-50 the filler is a brass plug on the top, there should be a 1/4" air gap at the top to allow for expasion, Tuff Torq units also take a multi grade oil 10-30, these units normally have a resevoir on the top with upper and lower fill marks.
Dec 10, 2012 | Garden
Dana Transaxle how to change grease or oil
some are not set up to service
May 22, 2012 | Poulan Garden
Hi, I have a Craftsman Garden Tractor 18HP Twin, model mo. 917.255919 that has a transaxle leak. The transaxle takes about 5 quarts of SAE 30 Motor Oil. I took the transaxle apart last summer to fix a gear...
I would drain transaxel out and refill with 80w90 gear oil. I think the 30 w is way to thin. You can try some lucas trasmisson sealer and conditioner and see if that helps.
If you have to remove the transaxel I would use hi-temp silicon sealer to seal all seams and arou
nd axel shafts. I have a six year old craftsman garden tractor 18 h.p. twin mod.number 917.2722751 and I'm nearly sure it uses the same transaxel so if you do have to get into the transaxel the oil seal part number is 788088A.I can not find the suggested quanity of oil but I just fill to top thru oil fill plug on top front of transaxel.Hope this helps you. Thanks
Jun 22, 2011 | Garden
The lawn tractor is smoking. what cAN I DO?
Try adding a little marvel mystery oil and change the oil.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 14, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Changing the oil filter on a lawn tractor
If it is a screw on type oil filter, apply a film of oil on seal, then screw on. If you want to, go ahead and pour some oil in the filter, in my opinion the oil will circulate faster if there is some oil already in the filter.
Apr 11, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
I need a transaxel for a troy bilt lawn tractor with brake on right side. It is a 42in/ 18.5 HP mower.
go to partstree.com put your make and model # in they should have what you need .hope this helps
Jul 28, 2009 | Garden
Craftsman ys 4500 lawn tractor change oil indicator won't go off
Being a reminder light it should reset itself after engine run hours increase from the programed reminder time
Jun 06, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
32 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
