Question about Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET
I have a Utilitech 3/4 HP jet shallow well pump #0003134. On start up, it hums a long! time before turning, sometimes tripping the 15 AMP breaker. Anything I can do?
It's wired for 115V.
  • Anonymous Mar 13, 2014
    Utilitech 1-HP 21 GPM Shallow Well Jet
    Sergeant:
  • 293 Answers
Try replacing first the capacitor. If it will not solve your problem, check the integrity of the motor winding insulation by doing a line to body resistance measurement. If it is okay, replace the motor bearings.
Posted on Nov 06, 2012
Can the pressure switch on the Utilitech 1hp convertible shallow well pump be changed from 20/40 to 30/50?
Yes, if the plumbing can handle the extra pressure. There should be a nut in the middle of a large spring inside the pressure switch. Turn that nut clockwise to increase the pressure. You may need to run some water to keep the pump cycling while you do this.
Jul 24, 2014 | Utilitech 1-HP Cast Iron Shallow Well Jet...
How do I replace the bearings ? can I get a manual on this ?
Yes you can get a parts diagram, a manual(usually downloadable version) At ultitech.com then select: parts/ manuals /schematics.
May 11, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Low water pressure how do i increase the pressure
The water pressure is adjusted with the pressure switch, which turns the pump on and off. The pressure switch is typically set for a cut-in and cut-out pressure of 20-40 psi, or 30-50 psi. Usually there are adjustment directions on the inside of the switch cover. But, there are several other factors that may affect the house pressure. If there is a pressure tank that is pre-charged, the tank pressure may need to be reset, or the tank bladder may be ruptured. Have the entire system checked out.
Apr 21, 2014 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
How to turn on
Need to know at what stage of the pump installation you are at.
Dec 18, 2013 | Utilitech 3/4-HP 15 GPM Shallow Well Jet...
Pump humming breaker trips I can turn pump by hand which is free
Sounds like the pump motor is locked-up and that could be a lot of problems. What model of pump do you have? More needed.
Oct 19, 2013 | ACE JET PUMP For shallow well
Need manual for utilitech 43467
You might be able to obtain this directly from the supplier
Jan 15, 2013 | Utilitech 1/2 HP Convertible Jet Pump...
I have a Utilitech 1hp shallow well jet pump which turns off and on rapidly while using water. I have 25 psi in the air tank. I replaced the pressure switch and still have problems.
Good you got it working. Please post again if you have more trouble on this or another item. Also be sure and check what I mentioned just in case you are operating at the margins, don't want a failure right after you got it going!
Sep 15, 2012 | Utilitech 1-HP Cast Iron Shallow Well Jet...
Utilitech 3/4-HP 15 GPM Shallow Well Jet Pump 3/4-JET Logo
911 people viewed this question
Top Utilitech Plumbing Experts
Dave
J.D. Browning
J.D. Browning
Boyet Soriano
Boyet Soriano
Are you an Utilitech Plumbing Expert? Answer questions, earn points and help others
