Question about Water Heaters
Type and part no. for a RHEEM natural gaz water heater pn: pv75 CE-11
  • Water Heaters Master
  • 5,089 Answers
Parts sheet corresponds to model number of water heater.
Copy following link for large pdf file with Rheem-Ruud 2010 parts list.
http://waterheatertimer.org/pdf/Rheem-Water-Heater-parts-catalog.pdf
Posted on Nov 03, 2012
  • 2692 Answers
SOURCE: dripping from drain spout
If you are refering to the "Dripping coming from the preasure tempature valve,Then just turn off the valve where the water goes into the heater and open the P/T valve with a bucket below it draining only emought water to get below the level where it reaches.     Normally the drain valves are plastic with a Male hosebib attached.  Attach a  garden hose to the rain and run it out to a point lower that the vaslve in order for gravity to drain the tank.The valve opens counter clock wise. If the valve is stuck or does not drain,and you have a foor drain handy,remove the whole valve and replace it with a boiler drain valve.  If The tank is located below the drain level then you will have to either pump or carry the drain water to the higher level.     Replace the P/T valve  and reinstall the associated associated piping. I would use tefelon tape on the P/T pipe theads.    You may have to open a hot water faucet in order for the air to replace the water in the tank ,in order to drain.
Posted on Jan 31, 2009
  • 244 Answers
SOURCE: Rheem water heater turns off by its self
Flashing code 76 is lost communication between the remote and the burner control assembly CCA (circuit card assembly). The CCA is still under warranty if purchased within the last 3 yrs. Contact Rheem customer service and have your Mod. and S/N available....explain to the agent you are recieving - flashing code 76...they'll walk you through the process.
Posted on Nov 01, 2009
peterrance19
  • 399 Answers
SOURCE: Problem for Rheem Paloma PTG-74PVN / RTG-74PVN
hi pete here ill try and help this could be 2 things check the sensor on the unit the outher one is a qustion has the gas company changed your meter latley and turned off you gas and not come back to light your poilet because this code also means not enough gas or wrong type of gas
Posted on Nov 18, 2009
  • 454 Answers
SOURCE: I have a Rheem 50 gal. natural gas water heater
The most common reason a pilot light will not stay lit is a bad thermocouple. How old is the water heater? If the pilot light will light, but then go out when you release the safety button, that is a sure sign the thermocouple is bad. You can buy a replacement thermocouple at your local home improvement store. There is a small chance that the control valve has gone bad, but that is highly unlikely.
Posted on Feb 23, 2010
vincob
  • 718 Answers
SOURCE: I have a Model 41V50 Rheem water heater (50 gal.
You don't need to find the same exact model to replace your water heater, any 50 gallon water heater will do unless you have a brand specification that you like to stick with.
Posted on Jul 25, 2010
I am looking for a magnesium anode for a Rheem natural gaz water heater PV75
There are two types magnesium anode.
1) Hex-head that screws into separate port on top of tank, and comes either 44" long or 12" sausage links.
2) Combo-anode that connects to Hot water nipple, and comes in solid or combo.
Contact guys at following link to purchase anodes
http://www.waterheaterrescue.com/pages/WHRpages/English/OrderPages/XCart/sales-through-XCart.html
General instructions and types of anodes
http://waterheatertimer.org/Replace-anode-rod.html
Rheem 'preferred parts'
http://waterheatertimer.org/pdf/2011_Rheem-anode-rods.pdf
Purpose of resistorized anode is supposedly so magnesium performs as well as aluminum.
Rheem however had 'resistorized elements' years ago, and that turned out to be promotional gimmick so people would buy rheem-brand products.
Nov 02, 2012 | Protech Rheem/Ruud SP13901B - Anode...
Rheem tankless water heater error code 11
Error 11 is ignition failure, or insufficient gas, or defective sensor, dirty combustion parts.
Do the yearly required maintenance such as cleaning the combustion parts, and error code will probably be solved.
Problem is Rheem does not post service manuals for people to learn how to service their equipment without calling service tech.
Copy following link for Rheem troubleshoot resources
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
The cost of yearly maintenance will easily eat away the expected yearly savings of $100 for typical family of 4.
Aug 20, 2012 | Rheem RTG-66DVN Direct Vent Natural Gas
Error code 11
Open following link for rheem tankless resources, includingerror codes and typical maintenance.
Jan 28, 2012 | Rheem RTG-74PVN-2 Natural Gas Pronto Whole...
No hot water.Error code:C2 11 (Rheem GT 199-PVN-2)
Resourceful do-it-yourselfer will find following links valuable
1) C11 is 'no ignition'
Check following link for Paloma error codes:
http://www.palomastore.com/paloma_error_codes.html
http://www.palomatankless.com/owners/homeowner+trouble.lasso
2) Rheem offers on-line chat, which you rarely see for typical tank-type water heater
http://www.rheem.com/products/tankless_water_heaters/customer_support/
3) Typical Rheem manuals
http://waterheatertimer.org/pdf/DirectVentManualRTG-74PVN-1.pdf
http://waterheatertimer.org/pdf/TanklessOutdoor_95_84_64X_UC_AP15318.pdf
http://waterheatertimer.org/pdf/Rheem-RTG74IndoorOutdoor_owners.pdf
http://waterheatertimer.org/pdf/RHRheem-Hvy-Dty-IndoorOutdoor.pdf
http://waterheatertimer.org/pdf/Tankless_Condensing_AP15896.pdf
4) Rheem site where you can find and download your manual if it shows
http://www.rheem.com/hrc.aspx
5) Check following link for recall list:
http://www.tankless-recall.com/tanklessSearch.aspx
6) Contact Rheem
http://www.rheem.com/Contact.aspx
7) Search Fixya for Rheem questions and answers
http://www.fixya.com/tags/rtg_74pvn
8) Post question on pro water heater forum: This is where I go to catch up on always-evolving water heater industry.
http://www.thetankatwaterheaterrescue.com/forums/forum3/
9) Install DIY tank-type gas water heater and avoid the whole headache
http://waterheatertimer.org/How-to-install-gas-water-heater.html
10) Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 19, 2011 | Rheem GT-199PVN Heavy Duty Indoor Natural...
CHANGING AN ORFICE
This unit cannot be converted from gas type to gas type.
Feb 24, 2009 | Rheem RTG-53PVN Indoor Natural Gas...
Water Heaters Logo
87 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
