Question about iwi Bingo .net
How do i open up sky rooms - iwi Bingo .net
SECURITY ALERT!
Zynga Poker previous sent you an email regarding possible unauthorized access to your Facebook and Zynga Poker account. This email was sent to k**8@yahoo.com. We recommend changing your Facebook password immediately.
Please verify your account by carefully following the instructions in the email.
Message Code: CA3
Posted on Nov 02, 2012
I cant view my sky channel on my tv
So you want to view your sky TV in a different room?
You can achieve this a number of ways.
Purchase the multi-room package from Sky TV. This will give you fully independent TV reception in each room. (Basically two sky boxes)
Purchase a TV sender which will wirelessly duplicate the output on the TV to another device.
Connect your Sky box to a second TV with high-quality co-axial aerial cable connected to the RF2 output on the back of the Sky box.
Mar 13, 2015 | Televison & Video
How do I get sky from my set top box to work in a different room, I am trying to get my sky to work on a TV in a different room ? I have wired up TV coax cable from my sky box in sitting room and run
Hi Jim,
Here In my place in India, you can attach only one tv to the sky set top box.That too with AV cables. The program or channel changing is done by box only. The tv works as a monitor and has no role in program selection. You can attach a second tv to the box not through antenna cable but through AV cables only. That too if the box is having second set of output sockets. In that case both the TVs will receive the same programmes. To watch different programmes on the second tv you will have to go for an additional box.
Feb 09, 2015 | LG Televison & Video
TV link not working with my LG 50PH660V 50-inch Widescreen 1080p Full HD 3D Smart Plasma TV with Freeview HD/600Hz. I connected coax cable to my Sky Box, switching on the RF on, but I can not get it w
Hi Jim, your nearly there, all you need to do is go into the tv menu and move from DTV to the old type channel numbers and then find the bit where you can manually tune the tv to channel 68.
Have a sky menu picture running and you will see it come in.
Feb 03, 2015 | LG Televison & Video
Sky Magic Eye not working over SLX 8 way booster/spliter
have you got it set on second out put on the sky box as number one is just normal. all cables have to be set to second output using a splitter box . so its like this.
arial in booster.
out booster to sky box.
out to tv/etc on first output on sky box.
second out put to spliter linc. ( eg 4 rooms out four way splitter)
each room with sky eye fitted to end of the aerial from number feed from sky box.
with each room with Eye sky can be controlled
also check that RF outlet power supply is set on sky+ or HD in settings menu.
access this.
settings
select ( remote)
type 01 (select on remote)
RF outlets.
RF outlet Power Supply ON
RF channel 25 ( is best for most areas)
Feb 01, 2014 | Televison & Video
How do i watch a program in another room got sky multroom but forgot how to use it
you gotta have a sky box in all the rooms you want to use it...they should all be wired up so all u gotta do is go to the av channel the sky box shows up on and turn on the box
Apr 05, 2010 | Toys
I WANT TO BE ABLE TO SEND SKY TV SIGNAL TO ANY ROOM, i HAD THIS IN OUR LAST HOUSE BUT CAN NOT REMEMBER HOW i RUN ALL THE COAX CABLES. i HAVE AN APLIFIER IN LOFT WHICH CABLES TO EACH ROOM, SO DO i NEED TO...
put coax from sky box output then into splitter in loft ampifier and conect all other coax that run down to other rooms to the outputs in amplifrer and turn on sky and put menu on then tune tv's in on anolog station
Dec 20, 2009 | Panasonic TH-42PX60U Television
How do I connect my sky eye? It arrived with no instructions and I am not sure what i need to do! I have a sky box in one room and now the sky eye connected to my tv in the other room - does it plug onto...
You need an aerial connection between the two units,the aerial will plug into the eye and then the eye into the tv.The cable connects into your sky box in the one marked output 2.You then need to go into service`s on the sky box,select 4,then press 0 1 select,goto rf output and turn on.
Nov 11, 2009 | Televison & Video
Have lost the link from sky+ to a second tv which was tuned to sky via channel 5 and majic eye on annolog since re tuning i cannot receive sky on second tv
Hello K Agate,
In the main room where the Sky + is locate. With the sky remote press the following.
Services.
0,1,select
4 (rf)
Ensure that the RF power to set to on, and take a mental note of the channel number the RF is set to. I normally set this to 38 it is upto you.
Now check that the coax lead that links the sky+ box to the 2nd room is plugged into RF out 2 on the back of the sky+ box.
Now go into the other room and make sure that there is a red LED light on your magic eye. If there is then great. If not there may be a fault with you eye. A good way to check this would be to connect it straight into the back of you Sky+ RF OUT 2 port. This would also check to see if there is any fault with the coax cable feeding the other room.
Assuming that there is a Red LED light on the eye when its plugged into the back of the TV in the other room (not the one with the sky box in), This means that there is power getting to it from the Sky + box.
Put your sky box on the TV GUIDE screen. This will make tuning it in a lot easier.
in the other room with your tv remote press the following
Channel 6 or which ever number you want it on.(analogue)
then MENU on the remote.
Go to MANUAL STORE
Then if you go down to where it give you a C ** number just type in what you retrieved from the sky RF menu.
That should bring your sky up then all you need to do now is STORE.
That should be you all sorted out now.
Hope all goes well. If so then please leave a Thumbs up
Cheers Little Dish Fitter.
Oct 21, 2009 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
iwi Bingo .net Logo
Top iwi Facebook Apps Experts
David Payne
David Payne
Bill Boyd
ray gallant
Are you an iwi Facebook App Expert? Answer questions, earn points and help others
