Question about Magic Chef CAV2004A Top Load Washer
Washing machine wont spin checked belt already, its fine
  • 38 Answers
Sounds like lid switch for starters
Posted on Nov 02, 2012
If i replace the belt on my washing machine model LSW21AW-3062 will my machine spin again as it washes but not spinning because the belt was worn
Make a troubleshooting first
1. remove belt then turn it on
2. if the motor spins then change the belt
3. if the motor did not spin:
a. motor might have been damage
b. check the wiring for cut outs.
c. the timer wont switch
Jun 28, 2017 | Washing Machines
I am looking for wa10r3 samsung washing mahine washing but wont spin,sounds as if is spinning but wont spin.please help me
check underneath for a solenoid that engages a lever or clutch to connect the belt drive to the base of the tub
it it is not slapping in when it goes to spin , it will not spin
Dec 18, 2015 | Samsung Washing Machines
Machine worked fine to start with . Then stopped. Will fill water but drum wont turn on a wash cycle. And wont spin on spin cycle.But Belt seems fine. Can you help.
The pump needs to be replaced. The pump controls the agitation for the wash cycle, also controls the tub for draining & spinning after the wash & rinse cycle. The belt has nothing to do with it. Pump is very simple to remove & replace, and not too expensive, it's plastic.
Jun 03, 2015 | Washing Machines
Hi i have a hoover washing machine hnf 6127 it functions perfectly but wont spin the drum goes round on the wash cycles but will not pick up speed on the spin i have checked the filter is not blocked
If it is not picking up speed on the spin cycle then it is the motor or the belt. check the belt first for proper tension and make sure the motor has the proper output. I think something is slipping and not transferring torque to the tub.
Mar 12, 2014 | Hoover Washing Machines
My washer starts of just fine but when going in spin cycle its slow and wont drain belt looks good,its just looks like the motor wont go into high speed
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Sep 06, 2010 | Westinghouse WWS833ES Super Capacity Top...
My washing machine wont spin with clothes in it
Hi, you will find either the drive belt has stretched slightly so when the unit is under a load the motor pulley slips on the belt. The belt should have some sort of tensioning or you would need it replaced.
The other reason it will not spin is if the motor brushes are worn and need replacing.
Hope this helps.
Mar 22, 2010 | Washing Machines
Washing machine GLWS1649ASO wont spin on spin cycle. motor and pulley turn, but belt doesn't move. Is it the belt?
no it will not be the belt more so it will be a bad transmission.or something stuck under the agitator i have seen drill bits and keys get stuck under the agitator and cause the transmission to stop
remover the agitator first and check it is there is nothing there the transmission needs to be replaced
Oct 02, 2009 | Frigidaire GLWS1649A Top Load Washer
Washing machine drum wont spin or even move.
Have you checked the Transmission? it is either at the other end of the belt, or what the belt attaches to, and connected to the motor, it may spin freely by hand, but if wornout inside will not turn anything, if you can set the machine to spin and look under where belt is at the same time, (without getting hurt) do so, and see what isn't turning....... that will tell you a lot right there....
Sep 15, 2009 | Washing Machines
Washing machine clothes dry
Is the belt broke? Have you checked during the wash cycle if it is agitating.
Mar 28, 2009 | Washing Machines
Magic Chef CAV2004A Top Load Washer Logo
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
