Question about Magic Chef CAV2004A Top Load Washer
How do i take agitator off washing machine?
How can i take part off that holds fabric softener?
  • 38 Answers
Pull off the cap and there is a bolt inside some times under second cover use socket kit and then pull upward
Posted on Nov 02, 2012
  • Debbie Viera Feb 06, 2013
    Got bolt out but can't get center to come out?
How to add fabric softner to the amana washer with locking lid
Check and see if there is a cup in the top of the agitator. Some machines have you put it there, turning back and forth during wash doesn't bother it, but the spin to empty the wash water causes the softener to go out through slots in the top of the cup and be held in the agitator. when it stops the softener drains into the tub, ready for the rinse cycle.
May 30, 2012 | Amana Washing Machines
HOW DO i REMOVE THE AGITATOR FROM maYTAG WASHER MODEL # MAV6457AWW
Gently remove the fabric softener cup off of the top of the agitator
Using a ratchet, an extension and socket; then remove the retaining bolt under the fabric softener cup.
The agitator will lift off after the bolt is removed.
Installation is:
Drop the agitator in place. Install bolt.... tighten bolt with ratchet, extension and socket. Install the fabric softener cup.
Fabric softener cup is item 14 this link:
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=5170378&diagram_id=28464917#d28464917
The bolt you need to remove is item 4 of the above link.
Thanks for choosing FixYa,
Kelly
Feb 05, 2011 | Maytag MAV6457 Top Load Washer
Remove agitator washing machine
Pull off fabric softener dispenser, then there will be a screw holding agitator in middle you will need a rachet, socket, and at least a 10" extension. Lossen and remove screw and pull from bottum of agitator.
Jul 05, 2010 | Washing Machines
Maytag MAV7000 AWW washing machine agitator won't spin freely.
When you grab the fabric dispenser and move the agitator "counter "clockwise you should hear the rachet noise,once you try and move it back "clockwise" the fabric dispenser should slide inside the agitator and the agitator should NOT move.
Apr 02, 2009 | Maytag Atlantis MAV7000
I've had an Amana Washer model ALW880QAW for about 6 yrs. Recently I've noticed old clumps of old detergent and fabric softener in the wash. I've already cleaned the fabric softener dispenser but the...
I couldn't wait for a rely on my posted question on March 6,2009. I was able to ask around to figure out how to clean this up. This Amana washer model has an agitator that is just clipped on. I just got my fingers underneath the agitator and pulled it off. After getting the agitator off, I was able to clean all of the old built up detergent and fabric softner with some old fashion scrubbing. Then I used some CLR to get what ever I missed. I pushed the agitator back until it clicked back into place and ran one washing cylce to clean things up.....Works great....No more old clumpy stuff showing up in the wash....
Mar 06, 2009 | Amana NAV8805EWW 3.3 Cu. Ft. Elustra Tub...
Gunk in middle of agitator
the fabric softener spins out of the cup after the wash cycle when spinning the water out of clothes, then the washer fills back up for the rinse w/ your softener having been dispensed. is there a nut at the bottom of your agitator where you see the gunk? If so you can take the agitator out by removing the nut but be careful of the little parts that make the agitator agitate. Do not disturb these little parts if you don't know about them. Does the gunk smell like grease or a mechanics garage? If so chances are it is a lubricant and should not be removed replace the cap and your softener cup and continue enjoying your machine.
Jan 05, 2009 | Kenmore 98702 Stacked Washer/Dryer
Does the agitator in our machine have a fabric softener dispenser?
softner only ..liguid bleach goes in dispenser on right front corner
Sep 07, 2008 | Whirlpool Washing Machines
My washer smells horrible. I know why, but not how to fix it. Help!
there is a bolt in the center of the spindle. Pull the fabric softener cap off to expose the center of the spindle and unscrew the bolt. you will nee an extenstion on the ratchet to reach the bolt. You will have to clean this every 2 months. I know--It sucks!.. I'm there myself.
Jul 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Maytag washer fabric softener dispenser is yucky
There is a 1/4" machine screw in a recessed hole close to the bottom of the agitator. Remove screw. Lift agitator off agitate shaft.
Nov 28, 2007 | Washing Machines
Fabric softener doesn't dispense
Fabric softener dispensers are notorious for getting all gummed up and clogged. Remove the dispenser cup and soak in some hot water to dissolve all residue. While you have the dispenser removed check under the dispenser cap in the agitator for gummy residue as well. Clean with hot water. There should also be an agitator seal cap under the dispenser. Make sure the cap and rubber o-ring are seated properly. Last of all, if the dispenser has a cone shaped cup inside, make sure it is inserted cone-side UP. The cup is designed to allow fabric softener to roll down the sides of it, NOT hold it. I hope this helps.
Apr 09, 2007 | Kenmore 24982 Top Load Washer
Magic Chef CAV2004A Top Load Washer Logo
277 people viewed this question
Top Magic Chef Washing Machines Experts
Ian Jones
Dan Webster
Dan Webster
Are you a Magic Chef Washing Machine Expert? Answer questions, earn points and help others
