Question about Polaroid PDM-0743 Portable DVD Player
Shows all disc as bad
It hasn't been played for a long time, using by battery pack. Every disc that is put in it says loading then shows bad disc?
    Genius:
  • Polaroid Master
  • 2,432 Answers
If you have a dvd lens cleaner tried to clean it first. if still no disc error, look for the spindle motor if it is rotating while you are playing with a disc. if not, check for motor worn out at this time you will need to remove the cover to access the internal part.
Posted on Nov 03, 2012
  • Peter s
    Peter s Feb 23, 2014
    Hi there how do I find if my spinning motor is worn ? My disc is not spinning ? I manage it with finger it worked for a minute
  • Peter s
My Daytona 3 scooter does not hold the charge very well. Few minutes after a full charge (takes about 11/2 hrs to get the steady green light), the green light starts flashing and the charge indicator is at...
Take your batteries out, and take them down to .a battery shop. Have the battery load tested, Reading the voltage under no load conditions will not tell you much, normally the batteries voltage gives you its state of charge. These batteries will show a full charge at no load, as soon as you put any load at all on the voltage drops off and you don't have much in amperage output. The amperage is what is important when you right down to it. When load testing your battery they will use an instrument that they punch in the cranking amps. The instrument will look for the voltage drop off at a load of what ever amp value you punched into the instrument. The instrument will give you a pass\fail indication for the cranking amps value the technician punched into the keypad. There can be a problem when load testing batteries. The technician doesn't key in a amperage value, This is what happened to me. The instrument when no value is entered will use a default value, Say the default amperage is usually set at around 200 Cranking amps. My technician was either rushed or just being lazy. He set the load tester to use the default values, my battery passed with the tester set up the way it was. My battery is a 35 amp\hr battery and puts out 480 cranking amps In actuality my batteries weren't putting out nearly that much. It would put out 265 cranking amps for about 2 seconds then die. He told me the batteries were good. When i brought the batteries back to him
i didn't let him take them into thee back room. THIS TIME HE DID THE CHECKS OUT IN PLAIN SIGHT OF ME. I asked to do a comparison between my batteries and new ones. We had to retest a number of time in order to find the upper limit of the new batteries. As it turned out my batteries were bad and all my problems disappeared with my old batteries. NOTE, scooters use deep cycle batteries only Glass mate batteries if you want to take your scooter on a flight.
Now if you had your batteries load tested and you know their good, its got to be the charger thats malfunctioning. Check the charger connection points make sure there tight. One connector should go to the negative battery terminal, the other connector should go too the positive terminal and read +24v. Make sure the connections are solid. Hope this helps
Aug 15, 2012 | Drive Medical Daytona 3 Medium Sized...
My E-scape Speed Boy doesn't hold a charge, I am wondering how far does a full charge go for. Also how long does a full charge take to charge fully?
How long does it take to charge a battery? There are allot of variables to this but generally speaking if a charger is a four amp charger and you got a 35amp/hr battery it will take roughly 8 hrs to charge. Batteries typically don't like to be cold. My batteries are 35amp/hr my scooter will go 25 miles @ a max speed of 6 mph. The run time is roughly 5.5 hrs with a draw of about 6amps
Aug 14, 2012 | Electric Health & Beauty
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
RED and green lights on battery charger blink alternatley even when indicator shows battery is full.Batterys are only 6 months old
Take your batteries out, and take them down to .a battery shop. Have the battery load tested, Reading the voltage under no load conditions will not tell you much, normally the batteries voltage gives you it state of charge. These batteries will show a full charge at no load, as soon as you put any load at all on the voltage drops off and you don't have much in amperage output. The amperage is what is important when you right down to it. When load testing your battery they will use an instrument that they punch in the cranking amps. The instrument will look for the voltage drop off at a load of what ever amp value you punched into the instrument. The instrument will give you a pass\fail indication for the cranking amps value the technician punched into the keypad. There can be a problem when load testing batteries. The technician doesn't key in a amperage value, This is what happened to me. The instrument when no value is entered will use a default value, Say the default amperage is usually set at around 200 Cranking amps. My technician was either rushed or just being lazy. He set the load tester to use the default values, my battery passed with the tester set up the way it was. My battery is a 35 amp\hr battery and puts out 480 cranking amps In actuality my batteries weren't putting out nearly that much. It would put out 265 cranking amps for about 2 seconds then die. He told me the batteries were good. When i brought the batteries back to him
Now if you had your batteries load tested and you know their good, its got to be the charger thats malfunctioning. Is your charger built in.check the connection points. One connector should go to the negative battery terminal, the other connector should go too the positive terminal and read +24v. Make sure the connections are solid. Hope this helps
Jul 19, 2012 | Electric Mobility Health & Beauty
I need new batteries on my scooter ?
i didn't let him take them into thee back room. THIS TIME HE DID THE CHECKS OUT IN PLAIN SIGHT OF ME. I asked to do a comparison between my batteries and new ones. We had to retest a number of time in order to find the upper limit of the new batteries. As it turned out my batteries were bad and all my problems disappeared with my old batteries. NOTE, scooter use deep cycle batteries only Glass mate batteries if you want to take your scooter on a flight. Hope this helps
Jul 03, 2012 | Health & Beauty
How to remove "Bad Disc" frtom my Polaroid portable DVD player
The unit has either a dirty optical pickup (it reads the disc) or a bad one--most of the time if bad cheaper to buy a new player.
Apr 18, 2012 | Televison & Video
The battery is charged, but there is no turnover, just a continuous clicking sound.
sometimes a battery will go bad even though it shows 12 volts it hasn't got the cranking amps to fully engage the starter. Try another battery and if you still have the problem you will need to replace or rebuild the starter
Sep 21, 2011 | Honda Shadow Spirit 750 Motorcycles
I have an APC XS1300. One year old. Very few
Mines, two or three years old and doing the exact same thing, you ever figure out what happen or how to fix it? I took the battery out and it reads 16 volts. I put a 2 amp load (fan) on it and it pulls fine, so I'm reluctant to buy a new battery pack for it now.
Feb 01, 2010 | APC BACK-UPS XS 1300VA LCD 120V...
Dvd "unknown disc" message coming up
Have you tryed to use a lens cleaning disc yet. The laser lens on these players and recorders alike, must have the lens cleaned every oince in awhile. If that does not help, most likly you have a bad laser pickup assembly and you will need to replace the plaer as to have that repaiered, you could buy a new unit. Good Luck
Mar 23, 2007 | Daewoo DV-6T955B DVD Player/VCR
Polaroid PDM-0743 Portable DVD Player Logo
125 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
