Question about Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
Where is the starter switch located? - Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model
  • Craftsman Master
  • 2,478 Answers
YThe is right side under the dash.
Posted on Nov 03, 2012
Where is the 1992 Honda 750cc Nighthawk headlight relay switch located?
think fuse is located along with the starter relay. To locate the starter relay, follow the + cable from the battery terminal.
Jul 18, 2015 | Honda Motorcycles
Locating starter ignition switch
Ignition switches are where you put your key in.most of the time if its older then 2010
Nov 29, 2012 | Cars & Trucks
Where is neutral switch located
the neutral switch is located in the left side of the transmission and its connected to the shift cable.
Feb 13, 2011 | 2003 Ford Explorer Sport Trac
My husband just needs to know where is the location of the starter relay on our '97 chevy Blazer 4.3 engine, 4x4? Is it near the passenger side or the drivers side?
When you go to start the engine you are actually sending power from the ignition switch through a 20 amp fuse [crank fuse] then through the Park/Nuetral safety start switch and finally to the starter relay [located at the center rear of the engine compartment] This relay then sends a more powerful current flow down to the starter solenoid located on top of the the starter which then closes and allows full battery voltage from the large battery cable to energize and spin the starter. I don't think I've ever had to replace a starter relay on these but have replaced a large number of starters with bad solenoids and bad Park/nuetral switches. The "crank" fuse could also be bad but that is also pretty rare.
Jun 21, 2010 | 1997 Chevrolet Blazer
280 LX won't start. Won't even click or turn over. Battery is fully charged. The trouble shooting manual notes it could be an ignition system fuse, and to contact a Deere serviceman. Is there an in-line...
i am currently working on an old jd 111 and the fuse is located under the starter solinoid, check there. The starter solinoid should not be located on the starter, track back the thick red wire on the starter to the solinoid to locate, it will be systematically located between the battery and the starter, check the starter solinoid functional with a meter and if that does not find it at the fuse and solinoid you will need to check the ignition switch input to the solinoid, and work back to the switch and any interlocks
Jun 01, 2010 | John Deere 420,1020,2010,2020,2510,2520...
2002 GMC Envoy, i put the key in ignition and vehicle will not start sometimes and other times is starts fine. we have checked the starter, battery and battery connections, all fine. Changed the starter...
Ignition switch and neutral safety switch. Next time it happens wiggle thekeys in the ignition switch and try to restart.If it starts its probably the ignition switch. Then locate neutral safety switch on brake pedal and put meter on B+ wire from switch to starter relay and see if you get B+ on the would -be- crank. Next locate B+ wire from starter relay to starter hook a meter to it and see if you get B+ on the would -be crank.
Where ever B+ is missing is your problem.
Apr 14, 2010 | 2002 GMC Envoy
How do i wire in a alarm on my 97 suburban K1500 i need a wiring diagram to find wire colors for windows lights and etc........
1997 Chevrolet Suburban Car Alarm Wiring Instructions
Battery Constant 12v+ Positive Wire (+): Red
Battery Constant 12v+ Positive Wire Location: Ignition Switch Harness
Starter Positive Wire (+): Purple or Yellow
Starter Positive Wire Location: Ignition Switch Harness
Ignition Positive Wire (+): Pink
Ignition Positive Wire Location: Ignition Switch Harness
Second Ignition Positive Wire (+): Pink/White Or White (This wire must be connected as ignition #2 for remote starting.)
Second Ignition Positive Wire Location: Ignition Switch Harness
Accessory Positive Wire (+): Orange
Accessory Positive Wire Location: Ignition Switch Harness
Parking Light Positive Wire (+): Brown
Parking Light Positive Wire Location: At Headlight Switch Or In Drivers Kick Panel
Power Door Lock Negative Wire (-): Light Blue (Type A)
Power Door Lock Negative Wire Location: In Either Door Harness
Power Door Unlock Negative Wire (-): White (Type A)
Power Door Unlock Negative Wire Location: In Either Door Harness
Door Trigger Negative Wire (-): Purple
Door Trigger Negative Wire Location: At Headlight Switch
Domelight Supervision Wire: White (-), Requires Relay
Domelight Supervision Wire Location: At Headlight Switch
Trunk Release Negative Wire (-): Black (+) Or Black/White (Requires Relay)
Trunk Release Negative Wire Location: At Hatch Release Switch Or Low In Drivers Kick Panel
Horn Negative Wire (-): Black
Horn Negative Wire Location: At Steering Column Harness
Tachometer Wire Negative Wire (-): White
Tachometer Wire Negative Wire Location: At ECM. The ECM (electronic control module) is located on the driver side inner fender.
Wait To Start Wire: When hooking up a remote starter on a diesel, you will need to program in the 5, 10 or 15 second wait to start timer in the installation manual. On some vehicles the wait to start light on the dash is not a true (+) positive or (-) negative and the wire from the remote starter will not work.
Wait To Start Location:
Brake Light Positive Wire (+): White
Brake Light Positive Wire Location: At Switch Above Brake Pedal
Factory Alarm Disarm Wire (-): N/A
Factory Alarm Disarm Wire Location: N/A
Factory Anti-Theft System: N/A
Factory Anti-Theft System Location: N/A
Mar 31, 2010 | Brand Remote Start/keyless/car Alarm Very...
Need to know how to hot wire ignition.what color wires do i use?
1991 Ford F150
Vehicle Battery Positive Wire (+): Yellow
Vehicle Battery Positive Wire Location: Ignition Switch Harness
Vehicle Ignition Wire (+): Red/Light Green
Vehicle Ignition Wire Location: Ignition Switch Harness
Vehicle Second Ignition Wire (+): N/A
Vehicle Second Ignition Wire Location: N/A
Vehicle Accessory Wire (+): Gray/Yellow
Vehicle Accessory Wire Location: Ignition Switch Harness
Vehicle Second Accessory Wire (+): N/A
Vehicle Second Accessory Wire Location: N/A
Automobile Engine Starter Wire (+): Red/Light Blue
Automobile Engine Starter Wire Location: Ignition Switch Harness
Automobile Second Engine Starter Wire (-): N/A
Automobile Second Engine Starter Wire Location: N/A
Factory Anti-Theft System: None
Factory Anti-Theft System Type: None
Car Key Sense Wire (-): Black/Pink
Car Key Sense Wire Location: At Steering Column Harness
Car Neutral Safety Wire (+): N/A
Car Neutral Safety Wire Location: N/A
Car Tachometer Wire (-): Tan/Yellow
Car Tachometer Wire Location: At Ignition Switch Control Module in Driver Fender Well
Car Speed Sense Wire: Gray/Black
Car Speed Sense Wire Location: Pin #3 at PCM Mounted on the Firewall
Car Parking Lights Wire (+): Brown
Car Parking Lights Wire Location: At Headlight Switch or Driver Side Kick Panel
Car Brake Lights Wire (+): Green
Car Brake Lights Wire Location: At Brake Switch Above the Pedal
Car Reverse Lights Wire (+): Black/Pink
Car Reverse Lights Wire Location: At Switch on Transmission
Car Horn Wire (-): Blue
Car Horn Wire Location: At Steering Column Harness
Sorry friend, this is as far as i can go to tel you how to hot wire the ignition. But with the color codes you should be able to figure it out, Good luck and keep me posted.
Jan 23, 2010 | 1991 Ford F150
Can't locate the starter relay on 1995 merc cougar. replaced starter ,ign. switch,but starter won't engage.
On most Ford/Mercury auto's thre relay switch in on the starter, sounds you are not getting a good ground.
Jun 29, 2009 | 1993 Mercury Cougar
Can`t get starter to turn over
Next thing to try would be the neutral safety switch located on the trans
May 16, 2009 | 1992 Oldsmobile Silhouette
Craftsman 20 hp 42 in. Deck Lawn Tractor - CA Model Logo
20 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
