Question about Pioneer 2012 Avh-p4400bh Double Din 7"lcd Dvd Receiverrear View Camera 4400
Pioneer error code 02-62 in iPod mode
Error code 02-62 comes up when using iPod mode and won't play anything..please help...!
4 Suggested Answers
  • 30 Answers
SOURCE: PIONEER AMP ERROR
Most probably you have one of the power amplifier modules bad. They are the PAC010 and PAC011 type. You can remove one and power up the receiver. If it powers-up normaly it's that one.... (50% chance) Otherwise remove both and it should power up normally. Beware that these parts are expensive... Most times just with a new part the problem is solved. YMMV. Good luck
Posted on Aug 02, 2009
  • 30 Answers
SOURCE: Pioneer VSX-D411 receiver "Amp Error" message
Unfortunatelly your receiver has failed. The front panel is telling you one of the power modules is probably bad. Not an DIY type of repair. These parts are near $40.00, plus cost of replacing.
Look at options to replace your trusted receiver with a new one.
Good luck
SOURCE: amp err
When standby light is blinking hold down ADVANCED SURROUND + ENTER, that will reset receiver. As soon as it resets hit the STANDBY/ON button, The receiver will shut off before the AMP ERR comes up. Then hold the TONE +STANDBY/ON button until the screen says reset. then press the TONE button, the screen will ask you to confirm, press TONE again. This will reset the controls and PROBLEM SOLVED. * the last couple steps need to be done fast, otherwise the AMP ERR will override the reset and you will have to start all back over*
Posted on Jul 17, 2012
Koolertron Mazda 3 ipod connection problems
common problem cause by the ipod screen turning off (going to sleep).
I bet it keeps going if you keep it active (awake).
No cheap fix sorry.
Apr 16, 2017 | Car Audio & Video
Sylvania imode ipod docking station plays ipod but won't charge it - why?
ipod touch has a light piece of plastic on bottom where it connects to the dock youtube has a video on how to remove it softly with a razor blade and once it is removed it will work properly although to be played through stereo i must have my ipod touch 4th gen on airplane mode
Jul 18, 2012 | Supersonic Audio Players & Recorders
IPad shows blank black screen & won't turn off ~ how do I fix?
Try reseting the iPad by holding the home and power buttons simultaneously until the iPad completely shuts down and the Apple logo appears.
Once the Apple logo appears you can release the buttons. If this does not work, you may need to connect your iPad to your computer and do a factory restore using iTunes.
Jul 16, 2012 | Apple iPad Tablets & eReaders
My cd's wont play and my ipod but radio works on my jvc kdr 520
Are you talking about just the audio coming from cd's and ipod? If so, are you using an amplifier? If you are using an external amplifier, you may be using the blue wire (power antenna remoter turn on) instead of the blue/white wire ( amp remote turn on) to turn the amp on. The blue wire turns off when leaving tuner mode, thus turning off the amplifier.
Feb 21, 2012 | JVC Car Audio & Video
My i pod touch is blank, i've followed the relevant stepr to restore it. after which an error code was given on i-tunes, i followed the steps given for the error but my i pod is still doing...
Try this:
Hold down the middle button (home button), the power button, and the volume DOWN button (make SURE that it's not the up one. It won't do anything, but it won't fix your iPod. Only the Down button will.).
Hold all of these down until the Apple sign shows up. Once the Apple sign shows up, it SHOULD work.
I hope this helps!
Jun 15, 2011 | Apple iPod touch
Hi. i've been having problems with my xp for quite some time. i've tried what i thought was a pretty good run of fixes, but nothing really worked. it's working better now than it has in a...
Hi.
Yes you can start the re-installation from safe mode although you can start the installation by changing the boot order to CD-ROM in the BIOS configuration.
Before you re-install XP it is a good idea to back up all your data to a slave or storage drive first as a clean install will wipe all your data.
If you would like to know anything else please post back.
Regards.
Jun 02, 2011 | Computers & Internet
I have the pioneer DEH-P7000UB in a Vauxhall Vectra. I put the head unit in the car, connected my IPhone (not the 3G version) set the head unit to USB mode and it try's to read my IPhone then comes up with...
error 19 is a communication error code with the ipod itself so either the cable is bad or the connectiontion on the ipod or deck is bad or the ipod itself may have a bad rom for external use. this info comes straight from the tech support manual for Pioneer that we car audio techs use (even if you call pioneer they will tell you mthe same thing).
try this :
Disconnect the cable from iPod.
Once iPod main menu is displayed, connect the cable again.
Reset the iPod.
Oct 31, 2008 | Pioneer Car Audio & Video
Error e-20. Doesn´t Work anything related to the Cd Players.
The system may need to reset. Unplugged the amp from the power source completely and let it rest for at least 5 minutes.
The illumination can only be controlled from the main remote. Adjust the prongs inside the remote and this should fix the issue.
Jul 28, 2007 | Nakamichi SoundSpace 9 CD Shelf System
Pioneer 2012 Avh-p4400bh Double Din 7"lcd Dvd Receiverrear View Camera 4400 Logo
3,512 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
