Question about Acer (91.48R37.002) CD-RW/DVD-ROM (Combo) Burner
DVD Door Won't Open
Brand new Acer Aspire computer, but when I press the button to open door, green light flashes, but it won't open. I went into hardware section of my computer and pressed eject, but it said that it's (DVD) in use.
  • uni312 Mar 02, 2009
    All of a sudden, neither my CD burner nor my DVD burner/player will open. I even tried right clicking on it and clicking on eject, but that doesn't work either. They did work, but won't now they don't and I tried rebooting it also, but no luck. I can open it with a paper clip, but if I put a CD in it and close it, when I click on it, it says there is no disc in it. HELP!!!!
I have this problem with my DVD rom too. I don't know if we have the same ones or not. I took mine apart to try and diagnose the problem, and it turns out that there was this thing inside that wasn't dropping down all the way to allow the tray to slide out, it was staying locked in place.
I was unable to find a cure for this.
However, I found that when I press the button to open the DVD rom, when it fails to open, I give the top of mt computer a slap, and it un-locks the mechanism and the DVD tray slides out properly.
I hope this helps.
Posted on Feb 10, 2009
My dvd door the bottom one on my dell won't open. The bottom one opens though. There is no green light on either.
Thanks Mike
Posted on Apr 28, 2009
My Panasonic DMR E S45V just stopped working. The Error message is F04. The DVD door won;t open, the VHS door won;t close.
Check the servo unit to see if the actuator is changing modes when press the buttons. If one door is open the other will not function either.
Feb 02, 2015 | Televison & Video
The dvd door wouldnt open i got it open manually but the green light wont stop flashing
You need a new DVD drive; they are cheap and easy to replace. Try Newegg.com for better prices than a brick & mortar store.
Mar 14, 2014 | Acer Aspire T160 (AST160UA3400) PC Desktop
Push buttons on remotes won't raise/close lift master mod 81lm
Check to see if the light in the wall control is flashing. If it is press and hold the lock button for 3 seconds.
Jun 13, 2012 | Sears Craftsman LiftMaster Chamberlain...
My Liftmaster garage door won't open or close. I hit the button and it make a sound and clicks but won't close
Remove the cover and check the drive gear. It is a white nylon gear just in front of the motor. It will be obvious if it is bad. Tell me - if it won't open how do you know it won't close?
Feb 22, 2012 | Sears Craftsman LiftMaster Chamberlain...
Maytag maxima door locked
Similar problem here - pump was set for a 58 minute normal cycle, I look in and see it is now showing 67. Hmm. Attempt to shut it off because it is just sitting there pumping and pumping. Power shuts off but pump keeps running and add garment light flashing red. Cannot open door (to add garment or not) Unplug the unit and the door will not open. Anybody got a clue what's up? I have a wash in, service is closed due to a storm today. Just bugs me that it is 6 months old and seems to act up a fair bit electronically.
Dec 09, 2011 | Maytag Washing Machines
My keypad won't light up when door is locked whe you push lock won't light up green
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Aug 04, 2011 | Kwikset 909 909-L03 Lifetime Polished...
The number illumination has gone out. How to fix?
My keypad won't light up when door is locked when you push lock won't light up green:
Jan 07, 2011 | Schlage BE365-PLY BE365PLY626 Satin...
Drum light on HL2030 won´t go off!
Open the front door, and press the go button until the lights flash, after closing, press the go button 3 times for a printout showing the drum as full again. The instructions come with the new drum...
Jul 30, 2009 | Brother HL-2030 Laser Printer
Whirlpool gold start button flashing dishwasher won't start
press sani and heat back and fourth then after all lights light close door and hit start then wait about 3 minutes. worked for me
Oct 12, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Acer (91.48R37.002) CD-RW/DVD-ROM (Combo) Burner Logo
1,362 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
