Hotpoint aquarius extra wms38 1200 spin We have a leak. It's still on spin but there is water on the floor at the front. Have taken off the small cover at the front at the bottom and the water is dribbling out from the joint where metal meets plastic. Any ideas??
SOURCE: Hotpoint Aquarius WMA56 wont drain properly water leaking onto floor
pump is working water is only a trickle coming out so wont final spin
Posted on Feb 27, 2008
Richie_asg1
  • 1036 Answers
SOURCE: hotpoint aquarius wf340
First remove the filter (if you can do this easily) - place a roasting pan under it to catch the water.
If you cannot get to any filter, remove the rear pipe from the waste pipe, and check it is not obstructed.
If it looks good enough, try a hot wash with 1 cup of soda crystals. This should clear any accumulation of grease in the pipes.
If still no good, you may have to open up the machine to clear any internal filter before the pump, and check pump vanes are still intact.
Posted on Nov 05, 2008
barkencoa
  • 3463 Answers
SOURCE: Water is leaking out of bottom of hotpoint aquarius wf445 wash ma
The filter is located behind the removable rear panel of washer.
Remove panel and on the right side you will see a large black hose, undo clip and remove hose, inside you will see the plastic filter, remove and clean.
Be careful, as their will be water run out when you remove hose..
Refit hose and make sure it is on securely..
Check for any leakage before you refit rear panel.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
  • 240 Answers
SOURCE: Whirlpool Cabrio Washer- When draining, water leaks out of hole
probably rubber hose from tub to pump broke, access from back or bottom, (cabrios are open bottom) pump in rear. there is a recent bulletin about tub ring not channeling water from dispenser completely into tub
Posted on Mar 14, 2009
barkencoa
  • 3463 Answers
SOURCE: hotpoint aquarius extra manual WMA44 can't find the waste pipe
Remove lower rear cover of washer, locate, and remove large black hose fastened to bottom of drum, remove and clean plastic filter inside hose.
Please rate my solution.
Thanks.
Posted on Aug 28, 2009
After a wash the water is not emptying out of the we64 aquariouse extra, hotpoint. how do i fix this? thank you
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Jul 17, 2011 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius extra 1000 spin washing but when spinning, clothes coming out still soaking wet. Help!
Check the machine filter, clean it and this problem might go away. Use manual for locating the filter.
Feb 28, 2011 | Hotpoint Aquarius WMA42 Front Load Washer
Hotpoint Aquarius Extra washer dryer WD64 will not drain water. Spin works ok.
Was it working before? You may have a blocked outlet hose. Try taking it off under the sink to look for a blockage. You could also try getting some water in from that end with another hose to see if it comes out into the machine. If it is not a blocked hose, then the pump may be faulty.
Dec 09, 2010 | Hotpoint Aquarius WD640 Front Load...
Leaking water from door during spin
Most likely door seal, check all around the seal, as often very small holes are missed, then they open up during spin
Mar 09, 2010 | Hotpoint Aquarius WMA56 Front Load Washer
I have a hotpoint aquarius WF250 1500 spin. The
I've just had this exact same problem. Can you tell me if you have had any success with fixing it please?
Thanks!
Dan
Sep 17, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Should there be a ball in the drain hotpoint
yes the ball should be in there,but shouldnt cause you any major problems if removed.
Aug 03, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Hotpoint aquarius WDL520 all lights flashing not spinning water still in bowl cant find instructions only bought it at xmas
There should be a small door at the front bottom of the machine, open it and unscrew the plunger. try that first as there could be a blockage.
The machine will not spin until the water is drained out.
Jun 17, 2009 | Hotpoint Aquarius WD63 Front Load...
Leaking washing machine
Hotpoint Aquarius WF210 Front Load Washer Leaking This video will show you how to find that leak on any front loading washing machine
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
And don't forget to like us on facebook
Apr 01, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Spin leak
The filter is located at the back of the machine.
Jan 01, 2008 | Hotpoint Aquarius WMA42 Front Load Washer
Nov 07, 2007 | Hotpoint Aquarius WMA56 Front Load Washer
Washing Machines Logo
56 people viewed this question
Top Washing Machines Experts
