Question about HP Printer Cartridges (Complete List): , HP 4836A (replaces HP 11) cyan ink cartridges
How to refill hp 818 inkjet cartridge Ink lavel is not displayed and black print not printed
    President:
  • 8,637 Answers
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 30, 2009
I REFILLED MY HP CARTRIDGE WITH BLACK INK 818. WHEN I REINSERTED THE CARTRIDGE IT SHOWED ME AN ERROR " INCOMPATIBLE CARTRIDGE" PLS HELP I HAVE TRIED CLEANING THE CONTACTS. IT DIDNT HELP :(
I suspect that your cartridge has a chip in it which is telling the printer that it is empty. You will either have to buy a new cartridge (or good compatible) or try to reset the chip
some advice on methods for resetting chips here
http://www.atlascopy.com/newsletters/Resetting_Cartridge_Ink_Levels.htm
http://www.ink-refills-ink.com/InfoPages/HP%20Resets/reset_57.htm
Mar 02, 2011 | HP Office Equipment & Supplies
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
Installed new hp black cartridge 56 ink but won't print
it shows if your using refill cartridge. & if you r using refill cartridge clear cartridge sensor with soft hands your problem would be resolved.
Jan 20, 2010 | HP PSC 1315 All-In-One InkJet Printer
My refilled ink cartridge still displays empty and will not print
The ink cartridge is most likely chipped & you would not be able to reset the ink level. Purchase an original or a good compatible cartridge. Refiling newer cartridges is not a good idea.
Oct 21, 2009 | HP Photosmart C4180 All-In-One InkJet...
i have injected 5 ml black ink in my 818 cartridge and inserted in my HP deskjetF2418 printer but it is not working and showing empty signal
Sep 30, 2009 | HP DeskJet F380 All-In-One Printer
Black ink won't print
check printer preferences and settings.
May 31, 2009 | HP PSC 1350v All-In-One InkJet Printer
Hp 818 print cartridge show incompatible after refill, or show problem with print cartidge. how to use them after refill without any problem
Whoever is doing refill for you should know that HP cartridges have electronic sensors that measure level of ink. They should have procedure with which they either reset the counter or "fool" the cartridge to work after refill.
Basically, you can't do anything yourself.
May 03, 2009 | HP DeskJet F380 All-In-One Printer
My hp deskjet f4288 suddenly stopped printing. so i refilled d cartridge(818) and replaced it. It wasnt printing still. I replaced a new cartridge in its place and the printer was working fine. Seems...
you can simply refill the 818 cartridge first you take the cartridge and then you must clean outer surface of the cartridge with a cotton cloth then fill the ink with a cyringe before you put into the carriege holder you must clean the inside path of the carriege holder then put it it will work very fast and perfectly.
Jan 12, 2009 | HP DeskJet F380 All-In-One Printer
Other compatable cartridges
Cartridge Description
Zone 1
small black inkjet print cartridge
HP 94
small tri-color inkjet print cartridge
HP 95
large tri-color inkjet print cartridge
HP 97
photo inkjet print cartridge
HP 99
Jan 15, 2008 | HP PSC 2355 All-In-One InkJet Printer
115 people viewed this question
Seeker5211
Seeker5211
