Question about Universal "Old Fashioned Crank Wheel Cofee Grinder"
Mr. Dudley hand-crank coffee mill-is there a way to adjust the grind size?
Hi - I purchased a vintage Mr. Dudley hand-crank coffee mill - the grind size appears to NOT be adjustable - is there a way to adjust the size of the grind - the coffee is "chunky" - large grind. What am I doing wrong, or is there possibly a part missing? Thanks!
How can we fix a nutri-mill wheat grinder?
can you see the grinding wheel /blades . if so try to rotate it /them slightly by hand
Dec 17, 2015 | Nutrimill Grain Mill Grinder
It only grinds about 3 oz. each time i ask for 15 takes forever to get enough for a pot of coffee
no- but you should be able to adjust the grind fineness by moving the setting to make it larger
Sep 13, 2015 | Cuisinart Burr Mill Grinder
How do i pull out the short cord?
I just now took a flat blade screwdriver, turned the coffee mill (Mr. Coffee) upside down, pushed the little bit of cord back in until I saw the cord wrapped around the base. Gently lifted it over the base and kept hand unwrapping it. Worked fine, will not retract, but this is not a problem for me. Hope this helps.
Jun 14, 2014 | Mr. Coffee Coffee Makers & Espresso...
Can I grind coffee in an electric grain mill?
Electric grain mills were not designed to grind up oily grains like coffee, you would be better off getting either a hand grinder or a coffee grinder.
Jan 23, 2014 | Kitchen Appliances - Others
How do I clean my burr mill (Models BMX3, BMX4, BMX5 and BMX6)?
Clean your burr mill before using it for the first time. Then, to ensure optimal mill function and durability, clean it regularly following these simple steps.
  1. Always unplug your burr mill after use and before cleaning.
  2. Open the hopper lid. Empty any whole beans from the hopper. Remove the top burr mill by rotating it clockwise. For better results hold the grind setting button while rotating the burr mill clockwise. This will allow you to clean the grinding wheel and the grinding compartment.
  3. Clean the interior recesses with a soft brush. Note: Never use water or liquid for cleaning the lower grinding section of this appliance. BRUSH NOT INCLUDED.
  4. Wipe the whole bean hopper, its lid and the mill exterior with a damp cloth.
  5. The ground coffee chamber and lid can be washed in mild detergent and water. They both are top rack dishwasher safe. Do not immerse the mill or the whole bean hopper in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  6. After completely drying the whole bean hopper and top burr mill, replace the burr mill in position by aligning snaps with receptacle and rotating counterclockwise to lock it in position. For better results, hold the grind setting button while rotating the burr mill counterclockwise. Once the burr mill is in position, pull gently to check it is properly locked in position. If the burr mill comes out, repeat this step again.
  7. Replace the ground coffee chamber and lid, making sure both snap securely into place.
  8. Fill the hopper with whole beans.
Sep 02, 2011 | Bunn NHB Coffee Maker
How do I clean my burr mill (Models BM1 and BM3)?
  1. Turn the whole bean chamber to the right until it can be lifted off the base. This will allow you to clean the grinding wheel. NOTE: Never use water or liquid for cleaning the lower grinding section of this appliance.
  2. Clean interior recesses with a soft brush (not provided).
  3. Wash the whole bean chamber and lid and the ground coffee chamber and lid in mild detergent and water. These items are only dishwasher safe on the top rack of your dishwasher. Wipe exterior with a damp cloth. Do not immerse mill in water or any other liquid or place in dishwasher. Use only non-abrasive cleaners to remove stains.
  4. After completely drying, replace whole bean chamber. Important: when replacing whole bean chamber, screw on completely before setting grinding rate. Turn chamber clockwise (as viewed from top), until it will not turn. Fill with whole coffee beans for grinding and replace lid.
  5. Replace ground coffee chamber and lid, making sure it snaps securely into place.
Grind size cannot be ajusted
On the side of the machine is a rotary dial, this adjusts the grind size. The other dial adjuster only increases or decreases the volume not the grind size.
Oct 20, 2010 | Breville Fresca BES860 2Cup Coffee Maker
Grinding adjustments does not stay, but loosens during grinding. What should I do?
use a small abount of your ladyfriwenjds nail varnish on the adjustment nut or screw to prevent vibration from lossening it.
Please rate my help++++Thanks for using FIXYA
May 28, 2010 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Don't know how to use Mr.Coffee IDS57 coffee grinder
Typically you load in the beans, replace the cover and then either press down on the entire cover or the black knob on the front of the cover. I would hold the lid down with your other hand just to be safe. Grind for about 4-6 seconds depending on how strong you like your coffee (the longer you grind the finer the coffee will be...this means STRONGER)
Jun 09, 2009 | Mr. Coffee IDS57 / IDS55 Electric Blades...
Zassenhaus knee coffee mill grinds too coarsely
I have a Zass and sometimes have a problem with it self adjusting, but when I do need to adjust it, I find that I have give it a good tap on the top to make sure it adjusts. So, just turn the knob counter clockwise as far as it will go, then give it a good knock on the top and bottom and try again. My mill offers the full grinding range, from a fine powder to large chunks.
Feb 04, 2009 | Zassenhaus Knee Mill Hand Crank 156 Manual...
Universal "Old Fashioned Crank Wheel Cofee Grinder" Logo
320 people viewed this question
Top Universal Coffee Makers & Espresso Machines Experts
Kolbrun...
Are you an Universal Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
